Question about Samsung Televison & Video
Samsung 42'' colour problem
I have a samsung 42'' model PS42A456P2D. The colour has darkened when i use the AV and RGB ports for my xbox 360 dvd exc. The normal tv picture is ok.The connections are all ok and the cables are fine. I have also reset the settings on the tv.
  • 19 Answers
SOURCE: No Sounds when connect XBOX 360 to HD port
you need to run the white & the red to the aud. input
Posted on Sep 16, 2007
  • 3 Answers
SOURCE: LG 47" 47LG50
Most likely it is not the TV; it's a grounding problem. Are all your devices plugged into the same power strip? They should be. Can you plug that power strip in to another outlet in the wall (even with an extension cord, just for testing purposes)? If that removes the lines, leave it plugged in there. If you can't leave it plugged in there, you'll need an isolator like the Jensen VRD-1FF or similar.
Hope this helps!
Posted on Jun 12, 2008
v4ndre
  • 148 Answers
SOURCE: samsung, xbox problem
Try to change the hdmi cable...
set your plasma hdmi input...
Good Luck
Posted on Dec 10, 2008
johncaman
  • 201 Answers
SOURCE: connecting a wii system to a sanyo DP26648 tv
It has to do with the type of input - Video2 and 3 are Component video inputs, requiring a 3- wire component video cable (Red,blue,green for video, red/white below for audio). Video 1 is for analog equipment (Yellow for the video, red and white for the audio). Unless your Wii comes with a component video out cable and jacks (same red blue green), you'll have to use video 1 for the Wii, and use Video 2 for the dvd. You'll need a component video (3-wire) cable for your dvd, which should have the jacks for it. You can use the present cable you're using for the dvd, but you'll have to change the connections on the back of the dvd to component video out, and you'll still need another 2-wire cable to connect the audio out on the dvd to the audio in on Video 2 on the tv.
Here's the manual for your tv - look on page 8 for these connections. the Wii will be an analog connnection, the dvd will be a digital connection.
http://www.sanyotv.com/DP26_32648%20Owners%20Manual.pdf
Hope this helps!
Posted on Mar 13, 2009
  • 114 Answers
SOURCE: Our 42" Vizio will not display/play sounds when
Hello
One board takes in the HDMI as well as the other signals. Sometimes part of the board breaks and that is what sounds like has happend in your case. This is a fairly common problem and most people tend to just live with it. Others sell thier tv and a few find the number of thier board to see if one is available on ebay or shopjimmy. If you are comfortable with electronics the board is not hard to replace.
Im sorry your HDMI broke....
I hope this helps
Posted on Nov 28, 2010
My yellow auxillary cable wont work for my xbox 360
jcjohnson001
Do you have just the yellow AV cable or do you have the RGB connections as well. If so you might test them as the problem my be with the cable.
Also another thing to check is if you have the cable with the RGB connnection you need to make sure the switch is not set to HD because if it is the yellow connection with not work.
Let me know if you have any more problems or questions.
Issken
http://www.fixya.com/users/issken
Sep 30, 2011 | Microsoft Xbox 360 Console
Ive plugged my xbox into a plasma using the rgb cables, but when i turn my system on the screen only shows thin lines of colour, i tried just using the normal video cable, but the same thing happened....
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console...
click here to download repair guide
Jan 03, 2011 | Microsoft Xbox 360 Console
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
Hooking up vga cable on hdtv cannot get any sound
okay in the back of your tv there should be 3 rows of places you can put the things in the top should have 3 colours and if you plug the av cable in to them slots you get a great picture but no sound in the row below there should be a red port plug the red one in from the other set of colours (white, yellow,red) and you will get solund hope i helped please give me a good vote =]
Dec 24, 2008 | Microsoft Xbox 360 Console
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
Samsung, xbox problem
Good Luck
Dec 10, 2008 | Microsoft Xbox 360 Console
Xbox 360
if it is under warranty maybe you can ask the manufacturer if they can replace it or yuo can try to check this forum website also:
http://forums.xbox-scene.com/index.php?s=a80517f4a3a729e4ea6e710fc69b944f&showtopic=656926&pid=4316084&st=0&#entry4316084
Aug 22, 2008 | Microsoft Xbox 360 Console
No picture
crazyerchris is right. and if that's not the problem it might be either your DVD/VCR player's av ports arn't working or the ports in you tv arent working. but it is probably the switch on your av cable. it's right by the plug by your 360
May 28, 2008 | Microsoft Xbox 360 Console
BadColour
switch the av cable to hd setting
Mar 25, 2008 | Microsoft Xbox 360 Console
Sony PFM-42V1N 42 in. EDTV-Ready Plasma
Yea the TV supports Pal 60
I had to use the bnc connection to AV. but yeah the tv supports Pal 60 you need to go into the menu and select it
just the colours arnt very good on this TV
Mar 04, 2007 | Sony PFM-42V1N 42 in. EDTV-Ready Plasma...
Televison & Video Logo
61 people viewed this question
Henry  Thomas
Henry Thomas
