Question about Konica Minolta magicolor 2430 DL Laser Printer
A vertical, geared moving part in the main body of the device has stopped working
And as a consequence the paper scrunches up just as it exits (or, would have exited) to the output tray. It appears the geared plastic rod below is intended to be enabling the final set of brushes to sweep the paper through the slot and out of the machine. Instead, the brushes have become a barrier against which the duplex unit jams the paper sheets, producing something not unlike a paper fan. My question is: whether anyone knows of a source for such a part? And advice on how to install it, if that's advisable (the K-M warranty is now a year old, but the store where I bought the machine has written a 'performance guarantee' contract for it. Anyone know of a source of parts and a detailed service manual? Many thanks in advance for any suggestions!
    Genius:
  • 1,003 Answers
Go to precisionroller.com they have all service manuals & parts
Posted on Jan 07, 2008
  • DENNIS MITCHELL Jan 13, 2008
    You need a new fuser assembly go to www.precisionroller.com
    type in you printer model an select all parts in the fuser area this is the area the paper exits just before the brushes (by the way the brushes are antistatic brushes).service manual is available also
    the gears you decribe are part of the fuser assemblypart that moves paper out of machine when fuser pressure roller it causes paper to jam or come out looking like an accordian
SOURCE:
LEXMARK x 2650 -- PAPER WILL NOT FEED INTO PRINTER CORRECTLY- WILL STOP AND SCRUNCH UP ON THE LEFT SIDE OF PRINTER FEEDER
Look very carefully inside where it scrunches up. you'll probably see another small piece of paper from a previous jam... remove it
Jan 23, 2011 | Lexmark Office Equipment & Supplies
I am getting an error on my Samsung SCX 6320 saying that there is a paper jam when there is no visible paper in the machine. It had jammed, I removed the paper with no tears or rips, but it still has the...
its may be the problem related to Two causes....
pls. check the Main Frame paper feeding gear was brokned or not ?
check the paper exit Pully in the exit area....
Jul 09, 2009 | Samsung SCX-6320F All-In-One Laser Printer
Scrunched paper
How old is the printer? It sounds like the rubber rollers have gotten hard and no longer can pull the paper through the vertical as quickly as the tray rollers do. I had a similar problem with a LaserJet4 printer and I had to obtain a repair kit (available online) and replace the old parts. Hope this helped.
May 28, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
13 Paper Jam - but there is no paper inside!
I have a long solution (possibly) to your issue:
Error 13 Paper Jam
  • Paper jams can occur in 3 places: Entry, registration and exit.
  • If the paper isn't picking up out of the paper tray, visually inspect the pickup roller. If it looks shiny, replace it. You should also replace the separation pad as they work together. On the 4L/4P/5P/6P the pickup roller has a plastic shaft that breaks. You'll have to replace the whole pickup assembly. This requires major disassembly of the printer. Check our printer repair kits for your model printer. If you don't see it listed, email us.
  • If you have an HP 4/4+/5 with an optional 500 sheet feeder that's jamming, check the balance knob adjustment. Center it with a full **** of paper for proper operation.
  • If the paper is jamming at registration or anywhere between pickup and exit it could be a number of things. Check the paper path for torn bits of paper or label residue. On the II/III series, remove the metal registration guide plate (2 screws) and check underneath it. If the pickup rollers are moderately worn, the paper will stop just short of the registration roller. On the 4L/4P/5P/6P remove the screw holding the oblique roller assembly (Inside front of printer) and pull out and inspect the assembly and the area under it. On the HP 4/4+/5 pivot up the metal plate and check underneath it. Check the roller assembly on the left side for torn scraps of paper (a flashlight or torch is necessary).
  • Make sure paper cassettes are firmly seated, corner tabs aren't bent. Some trays have lifting springs that could pop out if tray has been dropped.
  • On HP IIP/IIP+/IIIP printers if the paper scrunches up at the toner cartridge you'll need our Inside Accordion Jam Repair Kit.
  • Check your software settings in the program you are attempting to print from. Do you have the correct paper size specified? If you have a different paper size than what is in the tray, you'll get a paper jam.
  • Exit jams are frequently caused by exit sensors. These sensors are typically mounted on the fuser assembly or adjacent to it. They are plastic arms that block and unblock an optical sensor. The arms can get stuck or knocked out of place when clearing paper jams. The optical sensors can also get dirt blocking the photo cell. Clean the sensor and check for free movement and proper installation of the sensor arms.
  • On HP II/III series exit jams are mostly caused by worn gears. The best way to troubleshoot this is to defeat the door interlock (see door interlock photo on troubleshooting page). Press down on the arm on the top right of the fuser. Initiate a test page. While holding down the arm, press one of the metal cartridge detect switches just below the door interlock. Watch the movement of the gears. You will get a 51 error because the door is open. Recycle power to get rid of error. There is an arm gear on the lower right of the fuser that can shed teeth. There is also a 14 tooth gear below the large gear on top of the fuser. You can also manually rotate the large gear and check for binding or crunching. If that happens, then replace the 14 tooth gear. On the door, there are some delivery coupler gears that mate with the fuser and drive the exit roller. Check the gears for excessive wear. Replace if necessary. If the paper gets almost all the way out and jams, replace the exit roller or the exit roller assembly. If the error occurs after fuser replacement, check and see if the connector on the left of the fuser is properly mated with the one in the printer.
  • On HP IIP/IIP+/IIIP printers if the paper has accordion folds on the bottom and jams on exit, order our Top Output Accordion Jam Repair Kit.
  • On HP 4/4+/5 printers the most common cause of exit jams is the exit assembly. Order our 4/4+/5 Exit Jam Repair Kit. Exit jams in the fuser can be caused by a broken fuser drive gear or a broken gear on the fuser. Remove the fuser and check the gear inside the printer for broken teeth. Manually turn the gears on the fuser and check for smooth operation. Check the paper exit sensor arm for proper mounting and free movement.
  • Check to make sure the rear door is closed on the printer. Open doors can cause 13 paper jam indications.
  • On the 5L/6L check the registration sensor arm below the pickup roller. Also check the exit sensor arm (bottom center of the fuser). These arms frequently get stuck or dislodged clearing paper jams. On these printers, if you are experiencing frequent paper jams, order our 5L/6L Multi-Sheet/No Feed Repair Kit
All this comes from:
http://www.fixyourownprinter.com/reference/errorcodes/hp
Good luck with it, I love the HP LaserJet 4 series of printers. I used to warm my coffee on the top of the fuser when I was doing large print jobs :-)
If this information helps, please give me a rating, thanks!
OpenSource13
Apr 07, 2009 | HP LaserJet 4 plus Printer
Photo paper stops feeding
please verify that the main roller that is moving the paper out while its being printed upon is moving....if its not or it moves a bit verify that the gear teething are all intact at the gear assembly end....
check to see that you don't have worn out rollers.
Nov 02, 2008 | HP PSC 750 All-In-One InkJet Printer
Paper Jam at exit
This happened with an old HP Laserjet 1100A of mine.
I had apparently dropped a screw in the paper-out slot and it was jamming the paper on just one spot.
As you know, the entire sheet is connected, so It is most likely a similar situation in which a previous jam has left a small wad of paper under one of the rollers, and this is preventing the paper from exiting the slot.
Best bet, print something and see where the paper is scrunching up. This is most likely the roller that has the paper stuck under it. Remove the toner block and blast some compressed air into the spot the jam is most likely originating and see if anything else flys out.
Also, if that does not work, you might try manually rotating the rollers backwards, which will often eject the lodged paper chunk.
Note- Please be careful inside the printer! Do not touch the bright green drum, or anything that dosen't look like it is rubber and rolls paper around!
It is very easy to mess things up in there ;)
Sep 28, 2008 | Samsung CLP 300 Laser Printer
X1195 feed problem
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Aug 01, 2008 | Lexmark X1195 All-In-One InkJet Printer
Can't adjust screen
HAI,REPLACE MAIN FILTER(CAPACITOR)IN VERTICAL SECTION.
Jul 05, 2008 | Zenith Televison & Video
Will not feed paper
Sounds like the gears are out of alignment for the paper pick up tray.
May 28, 2008 | Brother HL-2070N Laser Printer
Paper not moving forward
please confirm that nothing droped inside in your printer (pins-stapler-small pieces of torn paper)-double a piece of paper roll and try to insert it while you press paper feed button to remove any object in paper path- apply light grease in gears and test your calculator.if the problem exist pass it to service center.
Sep 18, 2007 | Sharp EL-2630P Calculator
Konica Minolta magicolor 2430 DL Laser Printer Logo
147 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
