Question about Maytag PAV2300 Top Load Washer
Washer doesn't spinn
Washer makes a noise and doen't spinn
  • jlk4701 Dec 22, 2008
    My washer stopped in the middle of a load and I could smell something that smelled like burnig rubber coming fron the wsher
  • Anonymous Dec 28, 2008
    Won't spin. Close lid when set to spin, water seems to partially drain (sound in drain line) but never begins to spin.
  • 750 Answers
Defective Lid Switch
Hello
jimen6lWelcome to Fixya
My name is Huum,
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
Faulty Direct Drive Coupling
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
Water Level Switch
If the water level switch is not resetting once the water is drain, power will not be available to operate the motor during spin. Check the water level switch for proper operation.
Thank You For trusting us with your question
Please remember to leave a rating before you leave!
Posted on Dec 16, 2008
3 Suggested Answers
  • 235 Answers
SOURCE: makes a horrible noise when spinning out
Changing the belt should help.
Posted on Jul 02, 2009
SOURCE: kenmore washer started making banging noise in
Having same problem with my Kenmore 500. Tomorrow will be the second time a repair man has visited the house. Washer on 5 weeks old. Drum bangs every other load. Load not unbalanced. Avoid this washer, it is a POS.
Posted on Mar 30, 2010
The washing machine has become very noisy in spinn mode
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 22, 2011 | Washing Machines
Spinn cycle made LOTS of noise won't spinn any longer
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,<br />When my washer did that, I found that the shocks that hold the tub were bad...<br /><br />Check out this tip I wrote about the noise and vibration that front load washers can make..<br /><br />Washer Problems Washer noise when spinning<br /><a href="http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when" target="_blank">http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span><br />
Aug 25, 2010 | Frigidaire ATF6000ES Front Load Washer
The drum will not spinn?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | LG WM1814CW Front Load Washer
Kenmore washer started making banging noise in last spain cycle. Now unable to spinn drum by hand.
Mar 20, 2010 | Kenmore 24902 Top Load Washer
Very loud banging noise when front load washing machine spinnning
Ensure that the appliance is balanced/level on the floor. Contact an appliance service company.
Feb 22, 2010 | Kenmore HE2 Plus Front Load Washer
Washer sounds like marbles are in it when it spinns
look for an underwire bra wire it will be sticking in the drum
if you cant find it through the drum you may be able to reach whatever is causing the noise through the heater element opening in the tub
Feb 16, 2009 | Bosch WFMC 3200 Front Load Washer
Does not agitate or spin
listen for a "clicking" noise when opening nad closing the lid, sounds as if the lid switch migh tnot be making contact, but if it is running, just not agitaing or spinnning, you may have a problem with the motor coupling, this machines equivelent of a belt
Nov 24, 2008 | Whirlpool LSQ8000 Top Load Washer
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Very loud squealing noise in spinn.
If your Maytag is a top loader equipped with a vertical transmission under the tub, the squealing may be coming from, either the brake assembly, or the snubber which the entire pedestal rides on.  Could you please post back comments and let me know if this is the type of washer you have?
Oct 18, 2007 | Maytag Performa PAV2200
Maytag PAV2300 Top Load Washer Logo
121 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
