Question about Estate TEDS840JQ Electric Dryer
Dryer plugged in, but no power
My whirlpool estate dryer is plugged in, but is not working at all. The light inside is NOT on, and there is no response from trying to start it. yhe dryer was just installed after 2 years in storage. where do i start?
  • Linda Austin May 11, 2010
    the picture didn't come through. Is it white plastic?
  • Estate Master
  • 8,220 Answers
The fuse is located on the rear under the dust cover on the blower housing near the vent pipe. Looks like this: dryer plugged in, but no power - 608d7d9.jpg
Posted on Dec 16, 2008
We have an estate by whirlpool dryer that quit working. During last cycle it made a loud bang noise that ended the dry cycle and the clothes inside were dry. When we tried to restart it, it wouldn't...
The fuse is tied into the door switch circuit and looks like this:
Unplug the dryer and remove the rear cover. All the heater components is back there.
Service manual and more info are HERE at my FixYa tip.
Jul 17, 2011 | Estate TEDX640JQ Electric Dryer
Change cord on estate whirlpool dryer to fit outlet in wall
If this is an ELECTRIC dryer, the following link explains how to install either a 3-prong or 4-prong power cord:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If this is a GAS dryer, the standard color code for a three prong grounded plug is:
BLACK - HOT
WHITE - NEUTRAL
GREEN - GROUND
If you have any questions, please post back and let me know. I hope this helps you.
Jun 23, 2011 | Estate Dryers
Dryer not working at all have power light works
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
check these and replace the one part that has no continuitly
Jan 18, 2011 | Whirlpool Dryers
No heat to dry clothes. Dryer is 4.5 years old. The dryer is made by Estate (by Whirlpool). Model # TEDS740PQ0
By far, on that machine the "thermal fuse" accounts for more than 50% of all heating problems.
Unplug machine and remove back cover. On the air chute in the middle back of the dryer you will see a small narrow bakelite device with 2 wires connected to it. It is held in with 1 screw.
You will need an ohm meter to test it, or remove it and have an
appliance parts house test it for you. If bad replace.
Whirlpool part #3392519.
The second common problem on that dryer is the heating element and can be checked with an ohm meter as well.
On rare occasions one side of the 230 volt supply is out.
The side running the motor is o.k. but the heater side has lost power.
Caution: your dealing with 230 volts here. remove plug receptacle cover and check with a volt meter for power.
Nov 03, 2009 | Estate Dryers
Dryer spins no heat?
Inside the tub in the dryer itself is a heating element behind the screen. Try replacing it. Unplug the machine first though.
Aug 22, 2009 | Whirlpool LGB6300 Gas Dryer
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
No puilot on.
U must rmove the whole front of the dryer to get to the pilot. Good luck.
Oct 17, 2008 | Estate TGDX640JQ Gas Dryer
Estate TEDS840JQ Electric Dryer Logo
248 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
