Ok I have an LG ENV2, and all of the audio, ringtones and videos, aren't working. I have the volume up full blast, and the only thing I can hear is the keypad beeps. I tried holding down the power button for 30 seconds as well as leaving it off for 30 seconds, and removing the battery but nothing works.
SOURCE: LG Shine key pads not working at all!
Possible any of your keys are sticked. may be on keypad or in side keys. Check those first.
SOURCE: env2 got wet, front keypad having problmes,
This just happened to me last night. I FIXED IT!
The bottom half was working, the top keyboard was not working. The only button on the top that worked was the power key. Today, I got a screwdriver and took the whole entire thing apart. Start by removing the battery, then take out the 6 back screws. Gently pull the back apart - this will be tough, do it evenly around all sides instead of getting just one side and yanking or you might break it. two of the screws on the top are accessible readily, but the two near the hinge are only accessible once the back is apart. Take the front apart with these 4 screws. dry it out with a q-tip. There should be four more screws inside - take those apart and dry clean. Pull the face off and dry the large white plate that receives all the button action. I put it all back together and my buttons worked again. I didn't even feel like I did anything to fix it because it wasn't really wet inside, i think there was just a micro-dot of moisture on that white plate. I hope it works for you. I was so excited about mine that I got on here to tell others. But hey - I also prayed about it and God cares even about the little things!!!!! Now - I've got the battery out and am leaving it out for a couple of days just to make sure that its totally drive because any water in there could still damage the phone if there is a power source. GOOD LUCK!
SOURCE: front keys will not work on my lg env2
Mine does the samething. Call customer support and let them know your phone is not working and you need a replacement. Mine is getting replaced. Mine started as just the "ok" button now it's moved to the 4-5-6 row. very frustrating.
SOURCE: External "ok" button not working, can't access my env2 unless I open it and use internal keypad.
this IS NOT a solution... but for some reason it works for MY INDIVIDUAL PHONE... and i was wondering if anyone can repeat it for me to see if its universal or at least more common than i think it is.
I pressed 9 then # then 0. [like i said.. this is just my phone. im pretty sure if you put another number besides 9 as a first number it would still work..] anyways... when i pressed it and then pressed the okay button... it worked!!
however... i find this to be a little temporary.. it only works for about 24 hours and then it goes back to not working. and of course i redo it and it works.
I HOPE THAT SOMEONE CAN BENEFIT FROM THIS OTHER THAN ME
SOURCE: my LG lotus won't turn on.
Mine started doing the same thing yesterday. In doing a bit of research I found on the LG support forums that the phone is probably fried. The good news is that it's covered under the 1 year manufacturers warrenty and can be returned to the sprint store, or your carrier and they will replace it on site. I've already talked to Sprint and they said as long as there's no water damage or other visable signs of shock that would have caused the damage that they'll provide me with a new phone. This was a huge relief to me, I loved this phone before it went batty and really can't afford a new one.
Hope it works out for you as well.
I also have this phone. None of the sound works! The only thing it will do is vibrate when set to that
