Question about Motorola MU21CV (1 Channel) 2-Way Radio
Motorola CP200, radio just beeps when im pressing any button.
I Just hear a Hiss Noise when it turns on
  • jpie64 May 11, 2010
    The cp200 is old if i am not mistaken. Where did you get it? What are you using it for? Was it damaged? So many things could be wrong with it. The speaker could be bust, the rubber duck could be broken. I really need more than its just nosie.
  • Anonymous Mar 22, 2014
    I dont ear any sound when im pressing the talk button on one of my two radius cp200 but my other cp200 make a sound when im pressing the talk button do i have something to activate ?
  • Motorola Master
  • 1,654 Answers
It is possible your radio is not programmed, or has a bad/old battery.
It is normal for the side buttons 1 and 2 to beep when depressed to indicate you turned the feature on/off. Each of these buttons has the ability to be programmed a long and a short press feature.
If your radio beeps when your press the PTT button, on any or all channels, it indicates a low or nearly dead battery. Check your battery date code to see if the battery needs replaced.
If your radio emits a long tone on a channel, that channel is not programmed to function.
If your radio beeps a single beep when you turn it on, this is normal.
Charge your radio completely overnight, with the radio turned off. See if this solves the problem. If not, try a new/different battery to see if it will solve the issue. If not, drop by your local dealer and let them look at the unit.
Posted on Dec 16, 2008
6505 +112 has a bad hiss with nothing plugd in
Some hiss at high gain settings is normal. If you get objectionable hiss at 1 o'clock settings of gain, that is too high. Electronics has noise that is "statistical" in nature due to physics that we can't get around in design. Most hiss is created in the preamp area and swapping tubes in the first stage might help. By varying the volume controls and observing the level of the hiss, we may be able to analyze the offending staage of amplification. ALso turning up the treble controls will increase the hiss, as it is mostly in the higher pitches.
Jun 26, 2011 | Peavey 6505 Plus 112 60w All Tube Combo...
I have a hissing noise by my upper intake. Codes of p0171and p0174. Rough idling down and then eventually turns off
Your O2 Sensors are reporting a lean fault codes
So you have a vauum leak where you hear the hiss
V6 or V8 ?
Mar 09, 2011 | 2001 Lincoln LS
I have a Peavey 8600 amplifier. It sounds great but when only operating vocals, in order to get the highs of your voice just right, the speakers put off a large amount of white noise. While singing, you...
There is not enough info here to provide a complete answer, but let me give you some background:
There will always be some hiss. This is due to general amplification where a small amount of noise is amplified along with the general signal. In most cases, the signal is strong enough to overpower any noise that is present (vocals in your example). This noise should not be that noticable in normal cases. If there is an automatic gain control in the line, this could account for it as with "silent" times, the gain will automatically be increased potentially to the degree where the noise is noticable.
Barring that scenerio, if the input signal is too low, the overall gain necessary to produce reasonable volume at the speakers will also be such that the noise is noticable. In order to track this down, please provide details about the current setup including:
1) Microphone make and model being used
2) Input being used on the mixer
3) Gain level being used for the mic channel
4) Gain level being used at the master level.
Dan
Jan 07, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
My swr workiongpro 15 suddenly has a very noticable hiss even when the amp is muted, and when I play the high end is more prominent than it was before.
If you are having the treble/high turned up there will be hiss. This is due to the statistical noise in electronics, including semiconductors. It is a matter of degree. The hiss should be 30 Db below your program level or so.
It is very common for one to change settings and suddenly start to notice hiss or hum at certain settings.
IF YOU CAN, go to a music store and COMPARE the amp to yours at the same setting with NOTHING plugged in. (cables and guitars can generate hiss or other noise themselves).
There is very little in your amp that would have changed to suddenly start generating hiss, so FIRST compare. This will minimize the chance of spending money at a shop to be told it is normal.
Sep 14, 2010 | SWR WorkingPro 15 200 Watt 1x15" Bass...
No sound from radio in 97 ford explorer already r...
Turn the radi volume up high
Can you hear any hiss or noise?
If Yes..then the problem is your radio or aerial.
If NO , then the problem will usually be the speakers
Check connectors+wiring
May 21, 2010 | 2002 Ford Explorer
Hiss
If trim controls or gains are set near maximum, HISS is normal as electronics generates a thermal type noise.
If gains are set in normal operating area, the noise SHOULD be minimal.
Other sources of interference like nearby radio transmitters, welders, arc lights, etc. can create noise.
Start with ALL gains turned down and find which if any cause the noise to be unacceptable.
MAKE SURE all power to this and ALL the other connected equipment come from a single receptacle to avoid ground loops.
Jan 02, 2010 | Yamaha Mg82cx Stereo Mixer
Hiss in new fender frontman 65R. Can't seem to dial it out in either input.
A certain amount of "hiss" is present in electronic amps due to the statistical noise in electronics.
The hiss should be WELL below the level you get when playing. If you put you ear to the speaker, expect to hear some hiss with nothing plugged in. Ten feet away it should be very faint.
Dec 30, 2009 | Fender Music
Technics amp crackle and ''hiss'' noise
in my car when I press the accelerator there is hissing sound,did check the air filter by disconnecting the plumbing but still the sound is present any idea what could be causing this sound.
May 25, 2009 | Audio Players & Recorders
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
Hissing Noise
this is a common problem and all you really can do is to turn the speakers off when you are not using them which is also good for your energy bill!!!
Jun 11, 2008 | Sony DAV-C990 System
Motorola MU21CV (1 Channel) 2-Way Radio Logo
1,466 people viewed this question
Top Motorola Radio Communications Experts
Steve
Steve Allison
Steve Allison
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
