Question about Canon ZR45MC Mini DV Digital Camcorder
Cannon ZR 45 mc Multimedia card and tape problems.
I got an "In Card Position" when trying to record on my Cannon ZR 45mc camcorder. The manual said " Appears when you press the start/stop button in CARD CAMERA mode. The image in't recorded on the cassette or memory card". It does not shows me the fix nor tells me what to do next. I tried to searh for a resolution on the net to no avail. This is just one of the two problem I have. The other is on the tape's side, which prompts me to "eject" the tape and it seems to "eat" up my tape without able to record. Please help.
Thanks,
Tony
  • d_bubbles_13 Dec 21, 2008
    i have the same problem with the IN CARD POSITION
SOURCE: Cannon ZR 60 camcoder Cassette copartment does not open
Try these steps: 1. Open the tape cover fully until it clicks open. 2. Turn the camcorder on to "VCR Mode." 3. With the cover still open and the camera in "VCR mode," take out the battery. 4. Put the battery back in--out should pop your tape. Although this worked for me, I then inserted and used a head cleaner tape which then became stuck as well. Tried the same trick to eject it, and it did come out after several tries. I will take it for a repair estimate before inserting any other tape.
Posted on Mar 25, 2007
SOURCE: Message reads eject. won't eject
My camera did the exact same thing. I called Canon tech support and they advised to unplug power cord, remove large main battery, and remove smallbackup battery. The small back up battery is under a small door under the main backup battery. With everything disconnected, turn camera to "camera" and then to "vcr" and then to off. Wait a few seconds. Put everything back together and try to eject again. The tech said that resets all the mechanical parts. However, it did not work for me. They now want me to send it to them for a paid repair. I have done some research on the internet and this is a VERY commom problem and it usually costs about $150 to correct via Cannon. Many times the problem occurs again. I am very very frustrated. I pulled my camera out last night to get it ready as my wife is 9months into her pregnancy. Now, I have to send my camera away for 5-9 days. Really really upset.
Posted on May 29, 2007
SOURCE: IN CARD POSITION
A properly functioning camcorder will report this if it has both a card for recording and a tape mechanism for recording, with a switch set "in card position" when you press the movie mode record button. If you have a camcorder like this, look for a button marked "photo" that is used specifically for snapping still photos.
Posted on Jun 15, 2007
SOURCE: Canon Elura 100 won't eject tape
I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
Posted on Jul 08, 2008
  • 102366 Answers
SOURCE: I have a Canon ZR
You can download the manual (and more) from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/camcorders/minidv_camcorders/zr45mc#BrochuresAndManuals
Posted on Jan 14, 2011
Canon zr 45mc driver for win 7
Canon provides Windows Vista-compatible software and drivers (link) that should be installed in order to facilitate the connection. Some makes/models will 'just work' while others require the extra install first.
Jul 29, 2012 | Canon Cameras
I have a Canon ZR 45MC camera for which I need a manual. How do I obtain one.? S Sayger Hernando, MS
Jan 05, 2011 | Canon ZR45MC Mini DV Digital Camcorder
My playback video jumps after recording on tape also audio lever rises and fall i does not have this problem when record on the memory card i have a canon Zr camcorder
I have seen this problem many times, the recorder unit needs to be replaced, either something in the tape path has become out of alignment or dirty like a capstan motor or gears or the video head assy is defective. I hope this helps.
Sep 04, 2010 | Canon ZR200 Mini DV Digital Camcorder
I need sdc 8m 8mb sd Memory card for Canob zr 300. Can't find it.
if you still need it, i'd be happy to offer you mine. almost brand new (canon SD memory card sdc-8m).
Mar 19, 2009 | Canon ZR300 Mini DV Digital Camcorder
Canon ZR 45 Won't Eject Tape
That would be the take up or supply reel fault. It may also be a mode position error. Try here for advice but I don't advise tackling this job without full service instruction manual for the deck. No idea of your country so try here first;
https://www.usa.canon.com/internet/portal/us/home/support/details/camcorders/support-minidv-camcorders/zr
Apr 15, 2017 | Video Cameras
Can't get my Cannon zr 90 to work, there's a flashing red light in viewer
yes, I found the manual downloads on Canon's webpage. I wish I could figure out how to transfer my tape videos to a computer. I bought the $50,00 DV-1394 cord and nothing happens--computer doesn't recognize the camera.
Mar 15, 2008 | Canon ZR90 Mini DV Digital Camcorder
Connecting zr85 to vcr to record vhs tape to dv or sd card
I also have a Canon ZR-- left of the lens and the built-in microphones, there is a small panel that opens to reveal several ports. The middle yellow one is the AV In/Out. You can plug in the cable that came with your camera. One end looks like a microphone plug, the other has 3 RCA type plugs- red, white and yellow. These get plugged into your VCR's OUT plugs on the back of the VCR. Place a tape in the camcorder, open the LCD panel and push the REC PAUSE button. On the VCR, press the Play button. When the tape reaches the point you want to begin recording, press the camcorder's Play/Pause button. When you want to stop recording, press the Stop button on the camcorder.
This is also detailed on page 82 of your manual, manuals are available online at Canon.com. Your specific manual is at: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=174&modelid=9739#DownloadDetailAct
Hope this helps.
Nov 20, 2007 | Canon ZR85 Mini DV Digital Camcorder
IN CARD POSITION
May 18, 2007 | Canon MV530i Mini DV Digital Camcorder
Canon ZR45MC Mini DV Digital Camcorder Logo
91 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
