Question about Canon Pixma iP6000D InkJet Photo Printer
My printer will not print
My printer will not print and I did the nozzle checks on it and cleaning and it still does not print
  • JoanUmphrey Feb 11, 2009
    I also do the nozzle checks, and won't print. I even got new printhead and still won't print. What should I do?
  • chopper999 Mar 22, 2009
    Canon Pixma iP6000D InkJet Photo Printer have changed the Black printer ink tank cleaned heads ect but still will not print in black
  • 37 Answers
If the ink is ok , than it can be printer head .
Posted on Dec 16, 2008
Printer is blacking everything out
The print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Now you will be able to print in colour.
Hope this helps.
Shane
Dec 21, 2011 | Dell 926 All-In-One InkJet Printer
My back ink is not printing on cannon mx700 all in one eventhough I changed a new black ink
You may have to clean the print nozzles.
Print a Nozzle Check Pattern
  1. Confirm that the printer is connected to the computer and the printer is turned on.
  2. Complete or cancel any print jobs in progress.
  3. Open the Printers folder.
  4. Right-click the printer icon and select 'Properties'.
  5. Click the Maintenance tab. (The Maintenance window opens.)
    Note: The layout varies depending on the printer and version of Windows you are using.
  6. Insert a piece of letter-sized plain paper in the paper tray.
  7. Verify the desired paper source for the Nozzle Check is selected on the unit by changing the <Paper Feed Switch> if necessary.
  8. Select 'Nozzle Check'.
    Memo: By clicking 'Initial Check Items' before clicking 'Print Check Pattern', you can see the specific confirmation items in Nozzle Check.
  9. When the confirming message is displayed, click 'OK'. (Nozzle Check printing will start.)
  10. Examine the Nozzle Check output.
  11. Determine whether the pattern is normal or not normal.
  • Click here if the pattern is normal.
  • If the pattern is not normal, perform a Cleaning.
    Note: Perform this step first to clean the print head.
  • If the pattern is not normal after two Cleanings, perform up to two Deep Cleanings of the print head.
    Caution: Cleaning consumes a certain amount of ink. Perform cleanings only when necessary.
If this doesn't work, go to the same maintence menu and pick nozzle cleaner and then try again
Feb 28, 2011 | Canon MX700 Office All-In-One InkJet...
HI, can you tell me the procedure for 'cleaning the ink heads' on my EPSON STYLUS DX4400, Please. thank you, MARK
  1. Open the Printers or Printers and Faxes folder.
    In Windows 7, click Start then Devices and Printers. In other versions of Windows:
    • Click Start > Settings > Printers, or
    • Click Start > Printers, or
    • Click Start > Control Panel then double-click on:
      • Printers, or
      • Printers and Faxes, or
      • Printers and Other Hardware then View Installed Printers.
    • See How to open the Printers or Printers and Faxes folder in Windows in the Related Articles section for detailed instructions.
  2. Right-click on the icon for your printer and select Printing Preferences.
    Example: Windows Vista
  3. This will display the Printing Preferences window.
  4. Click on the Maintenance (or Utility) tab.
  5. Click on Head Cleaning. This will launch the utility.
  6. Click Start and wait for the printer to finish the first cleaning cycle.
    caution.gif Caution: Never turn off the printer while the On light is flashing. Doing so may damage the printer.
  7. Click Print Nozzle Check Pattern. This procedure will confirm the effectiveness of the head clean. You can also access the print Nozzle Check option from the Maintenance or Utility menu.
  8. Click Print.
  9. The printer will print a nozzle check. Compare the print out with the next window. If there are gaps, the print out is faint, click Clean, and then Finish when the procedure is complete.
    • If the nozzle check prints correctly (showing no breaks in the pattern), but the text is still broken you may need to run the Print Head Alignment utility - see How do I use the Print Head Alignment utility? for assistance.
  • If the nozzle check is complete, click Finish.
  • If there are gaps or faint print on your printout click Clean.
If gaps are still present, perform another head clean (without printing a nozzle check between the cleans). Once the second clean is complete, power off the printer.
Wait one minute before powering it back on, then print a nozzle check. Compare the printout with the example window (above).
  • If it is complete, click Finish.
  • If there are gaps or faint print on your printout carry out another set of head cleans.
  • We recommend only a maximum of six head cleans.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 10, 2011 | Epson Office Equipment & Supplies
How do I print the nozzle check pattern?
Dear Sir,
plz flow this step for solve your probelm
These are the 2 important features for maintenance of your printer.
Nozzle Check
If your printouts are unexpectedly faint or have some missing dots or lines, it means that certain colour ink does not flow out nicely and consistantly. This is when you need to perform a nozzle check. If your nozzle pattern is good, then, your printouts will be good and nice as well. If your nozzle pattern breaks at certain parts, it means you need to clean the print head. Here's how to perform a nozzle check:
1. Click Start
2. Click Control Panel
3. Click Printers and Faxes
4. Right click your printer icon
5. Click Printing Preference
6. Click Maintenance
7. Click Nozzle Check
8. Click Print
9. Click Finish (if the nozzle pattern is perfect) OR
10.Click Clean (if the nozzle pattern breaks at certain places)
The following is the sample of good nozzle pattern and a bad nozzle pattern:
Good nozzle pattern:
Bad nozzle pattern (Head Cleaning needed):
Head Cleaning
Head cleaning is required when the nozzle pattern is not perfect. Usually, this action is needed when you have printed a lot or you have taken out the cartridge for refilling or for other purposes. Here's how to perform a head cleaning:
1. Click Start
7. Click Head Cleaning
8. Click Start
9. Click Print Nozzle Patterns (to check the ink flow after cleaning)
Thanks For Your Time,
Apr 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Color differences
i apologize for the inconvinience.
the possible reason why its printing the right color, is bec. some of the nozzles might be clogged by dried inks, so when inks come out, the combination of colors are not balance. try printing a nozzle check first, if the nozzle check have gaps or breaks, try head cleaning, nozzle check after it so you can see if it improve or still w/ gaps, just do nozzle check, head cleaning, then nozzle check, head cleaning alternately until no more gaps then try to print.
Printing a nozzle check pattern
Load paper in your printer
In SelecType mode, press the Paper Feed (fontu1.gif) or Paper Feed (fontd1.gif) button until TEST PRINT is displayed on the LCD panel, and then press the SelecType button.
Press Paper Feed (fontu1.gif) or Paper Feed (fontd1.gif) button to display NOZZLE CHECK
Press SelecType button to display PRINT
Press the Enter button. The nozzle check pattern is printed as shown below. After printing, printer exits the SelecType mode and return to the READY status.
Nozzle check pattern examples:
good
yoi.gif head cleaning necessary
headcleaning: press the cleaning button for 3 seconds
Feb 10, 2010 | Epson Stylus Pro 9600 InkJet Printer
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
Have an iP90, but the color ink won't print.
When Printing Becomes Faint or Color are Incorrect, the Print Head Nozzles are probably clogged.
Follow the procedure below to clean the nozzles.
Print the Nozzle Check pattern to determine whether the ink ejects properly from the Print Head Nozzles.
a) Using RESUME/CANCEL button.
I) Ensure that the printer is turned on, and then load a sheet of Letter Paper.
ii) Hold down the RESUME/CANCEL button until the POWER lamp flashes twice, and then release it immediately.
b) Windows
i) With the printer on, load a sheet of Letter-sized plain paper in the printer.
ii) Open the Printer Properties.
iii) Print the Nozzle Check Pattern.
Click the Maintenance Option from the Menu.Then click Nozzle Check from the pop-up menu. Then click Print Check Pattern.
iv) When the confirmation message is displayed, click OK.
v) Confirm the nozzle check pattern.
Examine the Print Nozzle.
Step 2 : Cleaning the Print Head.
a) Cleaning the Print head using RESUME/CANCEL button.
i) Ensure that the printer is on.
ii) Hold down the RESUME/CANCEL button until the POWER lamop flashes once, and then release it.
b) If you pressed the Cleaning button on the Examining the Nozzle.
Check Pattern screen displayed after the nozzle check patter was printed, start the Print Head cleaning procedure.
i) Ensure tha that the printer is on.
ii) Open the Printer Properties dialog box.
3) Start Print Head Cleaning,
- Click the Maintenance tab.
- Click Cleaning.
- Select the Print Head to be cleaned, and then click Execute.
Print Head cleaning starts when the POWER lamp starts blinking,
Important : Do not start any other operations until the Print Head Cleaning finishes. This takes about 60 seconds.
4) Check the Print Head condition.
i) Click the Print Check Pattern in the nozzle Check dialog appeared after cleaning are done. When the confirmation message is displayed, click OK. A nozzle pattern will be printed. Do not perform any operation until printing is completed.
ii) Observe the printed nozzle check pattern to check the Print Head condition.
iii) If the problem persists after you perforned Print Head normal cleaning 3 times, execute Print Head deep cleaning.
Step 4 : Print Head Deep Cleaning.
If print quality does not improve by standard Print Head cleaning, try Print Head deep cleaning, which is a more powerful process and comsumes more ink.
1) Ensure that the printer is turned on.
2) Open the Printer properties dialog box.
3) Start Print Head Deep Cleaning.
i) Click the Maintenance tab.
ii) Click Deep Cleaning.
iii) Select the Print Head to be cleaned, and then click Execute.
iv) When confirmation message is displayed, click OK. Print Head deep cleaning starts when the POWER lamp starts blinking,
Important : Do not perform any other operations until the Print Head deep cleaning is completed ( about 2-3 minutes).
i) Print a nozzle check pattern to check the Print Head condition.
ii) If the problem persists, perform step 3 again.
iii) If the problem persists, the printer may have run out of ink.
Replace the ink tank.
iv) If the problem persists, the Printer Head may be damaged. Contact your dealer or Canon Customer Care Center.
Hope this helps.
Have a good day.
Dec 04, 2009 | Canon PIXMA iP90 Mobile Printer
Photos printed come out faint and lines andblack streaks across the photos how do i solve this/
lean The Print Head Nozzles (Windows) The following contains instructions to check the nozzles for poor print quality and perform cleanings of the print head nozzles as necessary. If print results are faint or streaks are printed, the print head nozzles may be clogged. Print quality can be improved by performing print head cleanings or print head deep cleanings. aution: Only used the approved methods below to clean the print head. Use of other methods may further clog the nozzles on the print head and may cause permanent damage the print head.
Note: It is important to check the cleaning results by printing Nozzle Check Pattern after each cleaning. Cleaning and Deep Cleaning consumes a certain amount of ink. Only perform a cleanings when necessary.
  4. Click the Maintenance tab. (The Maintenance window opens.)
  5. Insert a piece of letter-sized plain paper in the paper tray.
  6. Verify the desired paper source for the Nozzle Check is selected on the unit by changing the Paper Feed Switch if necessary.
  7. Select 'Nozzle Check'.
Aug 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Can you help? After changing the cartridges, I keep getting a message about the ink head being incorrect...I am directed to press 'OK' which does not help; then to turn printer off and on again, which...
Cleaning your head might resolve your problem. Perform the below steps to clean the head:
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head (Cleaning) or print head deep cleaning (Deep Cleaning). Note:
  1. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
  2. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
Overview:
Step1:
To check whether the print head nozzles are clogged, print the Nozzle Check Pattern.
downicon.gif If the print quality is poor, perform print head cleaning.
Step 2:
Perform print head cleaning.
This unclogs the print head nozzles
Print the Nozzle Check Pattern again.
If the print quality is still poor, perform two print head cleanings.
downicon.gif Print the Nozzle Check Pattern again.
Step 3:
Perform deep print head cleaning.
This is a more powerful cleaning.
Displaying the Maintenance screen
  1. Ensure that the printer is powered on.
  2. Press the <Menu> button.
  3. Press the left or right cursor to select [Maintenance/settings], then press <OK>.
  4. Press the left or right cursor to select [Maintenance], then press <OK>.
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
New ink cartrage
Note:
    Note:
    Note:
    Note:
    Ifthe printed result does not improve even after doing print head deepcleaning, turn off the printer. Then, after 24 hours or later, do printhead deep cleaning again. (After a given time interval, ink coulddissolve itself, resulting in ink unclogging.
Jan 08, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma iP6000D InkJet Photo Printer Logo
158 people viewed this question
old marine
old marine
