Question about Toshiba Satelitte M45-S355 Notebook PC w/ MobilEdge Express Tote (KITS00019) PC Notebook
Can't connect to internet with public wireless connection
Last week when I tried to connect to a public wireless connection that I used frequently without any problems, the computer showed that it was connected, but it wouldn't go to any websites giving me the same message it would have if I weren't connected. I tried checking the connection and the adapter by running diagnostics, but everything got an okay. The troubleshooting guides didn't help either. A few days later I tried to connect on two different public wireless connection, but the computer did the same thing. I tried to repair the connection but couldn't and received the reply: unable to disable connection adapter. I also tried disabling some add-ons with no luck. What do you think the problem is, and what can I do to fix it? Thanks!
Lenovo G550 running Windows 7 won't connect to internet. "Default gateway is not available" message displays. I have 4 Vista computers using wireless connections all functioning fine, but this...
Wow youve done almost everything here.How about the firewall? is it blocking any connections?
Next,Go to control panel,network and sharing center.Look and see if the pc or laptop in question is on the same network,meaning home or public.
Set all your machines to the same network.Either home or public.I do know this has been a win 7 problem.
Mar 11, 2011 | Lenovo G550-29583AU Notebook
My toshiba satellite laptop want connect tothe internet
It could be a couple things: 1. Try connecting using the wired connection if you can. If it works, then problem most likely with wireless. 2. Try connecting wirelessly maybe using a public WIFI hotspot or a friend's connection. That will rule out your router. 3. It could be a browser issue: Start / Run / Inetcpl.cpl and then check the Internet settings. Make sure there are no proxy settings set.
Feb 20, 2011 | Toshiba Satellite A105-S4022 - Laptop...
Frequent disconnection using wireless router
if you live in a heavily populated area you might be experiencing interference try switching the wireless channel on the routers config page. if there's a choice for auto-channel try that.
Jun 28, 2017 | Trendware TEW-432BRP Router (S4432514)
Other routers taking over my router connection even when password
Its possible you have no authentication setup on your router. At the very least, please setup your router and all devices in your network to have WEP authentication. If your router and devices can handle it, please setup WAP or WAP2 authentication (instead of WEP). This should make your environment a lot more secure and prevent others from taking over your router.
Jan 02, 2010 | Zyxel NBG318S Kit Wireless Router
I'm having a problem with my NETGEAR WGT624v3 router. I have it connected through a SPEEDSTREAM 4200 modem and have experienced no problem with the internet connection. However, after approx. 3 to 4 hours...
yes set the speedstream modem to log in. it is uner advanced, usually address. It is most likely set to "bridged" mode and using the router to login. set login to ppoe on speedstream on one p.c. only 1st. with login ang password filled in and "smart keep alive" on.
Oct 31, 2009 | NetGear WGT624 Wireless Router
Excellent Wireless Network Connection, cannot access internet
The unsecure public network nay be using mac address filtering. In this case, the network will show as being unsecured, and will even allow you to connect in some cases, but then will not allow you to surf once connected.
May 28, 2009 | D-Link Air DWL 650 802.11b Wireless...
Low signal from my wireless adaptor / router
Have you tried connecting the laptop in a different wireless network? Try changing the channel in your router and you may also upgrade the firmware of your router.
Oct 04, 2008 | NetGear WGR614 Wireless Router
Internet connection lost..
Firstly try the Off Line option, sometimes this can be ticked. Or go into the Netword Card settings and try to force the speed to auto config, this will enable different speed connections
Jun 02, 2008 | D-Link DFE-528TX Network Adapter
Computers & Internet Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
