Question about Kenmore 54512 / 54514 Side by Side Refrigerator
Water dipensor working, but ice not making(used to) on my kenmore
Kenmore model 10654514300- we had it and ice maker worked great for 2 years+ then it suddenly stopped working. Yes, the door is closed tight, and the ice bin is put in securely, and wire on/off is on- we also can get water from the dispensor just fine- but no ice.
I looked and water is not coming into the trays at all.
I looked and this is style 1, so it doesnt have any optical LED blinking lights or anything like that that I can use to help troubleshoot.
Can't see any tubes from the inside- so if there is a solution, I probably will need to unplug and move the refridge out to access the back side of the refridge.
Freezer itself works great - water valve (for water) works(to the drinking cup) but the ice cube trays are not getting water in them???
Any help would be grateful!!!
tborn6
  • 700 Answers
SOURCE: Ice maker not making ice
Sounds likw the water fill tubs is frozen shut, look where the tube comes into the freezer compartment and take a hair drier and thaw it out. Good Luck
Posted on Jan 11, 2009
  • 531 Answers
SOURCE: Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Posted on Apr 07, 2009
  • 3 Answers
SOURCE: ice dispensor only dispensing crushed ice - not cubed
The spring coming off the rod will also cause this problem, also the bypass flap may be stuck open, always check the simple things first, hope this helps.
Posted on Apr 16, 2009
Maytag317
  • 1136 Answers
SOURCE: water dripping from water dispensor -fridgidair sid by side
Hi, If the water is a constant drip, you will most likely need to change the water inlet valve. This valve will be complete with the icemaker valve also. Sounds like the plunger in the valve is starting to stick open.
I hope this helps. If I can acwer anymore questions, please ask.
Thanks
Vic
Posted on May 14, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
I have a Kenmore refrigerator model 106.56542400. The ice-maker does not work though the cold water works fine. How much it will cost me? Trying to see if buying a new one is cheaper. Thanks.
The cost depends on where the problem is. For example: If the ice maker is NOT getting water to make ice then it is probably the 2 line water valve solenoid or the sensor on the ice maker that would tell the 2 line water valve solenoid to send water up to the ice maker tray. Both of those replacements will cost you in the neighborhood of $25.00 - $40.00 plus a service call if you aren't able to do the work yourself.
If water is getting to your ice tray, but not kicking out the ice into the bin - that is usually a motor problem. And cost you as much as what a replacement ice maker would cost you.
To give you an idea of the cost of parts here is the layout for your unit: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10656542400/0582/0165000/K0707001/00012
Jun 24, 2011 | Kenmore Refrigerators
Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker will not make ice
Water fill tube above I/M is probably frozen up. Remove I/M and see. If so, use spray bottle to melt out ice. Unplug and replug in ref when done to reset ice level sensor or it still won't work. If no ice blockage then I/M is bad and needs replacing.
Nov 28, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Ice maker not working
Most likely the motor module and ice maker thermistat needs to be replaced. Look at this link: http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34. It is very helpful for diagnosis and replacing parts.
Nov 11, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore side by side refrigerator
Check the water valve in back of refrig.. u have a double valve... one side for water the other side for your ice maker.. make sure ice maker valve is working.
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 54512 / 54514 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
