Question about Miller Welding Tools
When trying to do spot welds, does not stop
When trying to do quick spot welds, my machine seems to not shut down the welding action, as reradily as it did, when first bought. It seem to continue for a second or so after the trigger is released. I have a miller 210 that I bought a little over a year ago.
It is one of two things. (1) the spot timer my need to be cleaned or re-placed.(2) ckeck and clean the ground clamp and ground wire hook-up. you can clean the the timer by blowing it out with compressed air or nitrogen
Posted on Dec 18, 2008
I need tips for my stud welding gun. How can I replace them? Thanks John
https://studweldprod.com/
Stud Welder - Stud Welding Equipment, Gun - Stud Welders Machine
www.eastwood.com > Welding & Fab
  1. Cached
  2. Similar
Stud welding makes more sense. Our stud welder systems each have a stud gun welder that spot-welds a series of pins onto the surface of the dented metal.
What is Stud Welding? ' Sunbelt Stud Welding
www.sunbeltstudwelding.com/studwelding.htm
  1. Cached
  2. Similar
Weld studs come in a variety of designs, threaded, unthreaded, tapped, etc., ... The welding gun is activated and the fastener is welded in a fraction of a second.
Stud Welding Machines and Equipment ' Red-D-Arc Welderentals
www.red-d-arc.com/rental-equipment-subcategories.aspx?sub_cat=180
  1. Cached
  2. Similar
Red-D-Arc offers a range of fully regulated, user-friendly stud welders, stud welding machines and equipment available in single or dual gun versions and ...
Jan 30, 2017 | Welding Tools
How do I fit legs made from same 25mm square tube as top section from moving from 90 degree angle as I weld ?
couple of methods
use a section of the square tube as a block across the frame and clamp to the leg and to the frame the leg is being welded to ( that holds the leg square to the frame
now tack weld along the length and not across the frame
the problem is that when you weld across with out tacking both sides first , as the weld cools down it pulls the leg in that direction and the trick is to prevent that action by tacking both sides first before welding properly
welding across the tube will tend to bend the frame as well and by welding along the sides of the frame after tacking inside and outside first that stops the from from bending
mostly a weld on both sides of the frame rail onto the leg will be sufficient as it is not really necessary to weld all the way around the leg
Apr 25, 2016 | Welding Tools
I was welding and it quit feeding the wire now I don't hear relay clicker nothing when I pull the triggerwhat could be wrong
first thing to check is the over load reset button as all welders have a duty cycle for welding if that period is exceeded , the machine shuts down until it is cooled down
the duty cycle is the time of welding allowed in relation to the amps required to weld
for example with a 200 amp welder set at 200 amps with a 20% duty cycle for every 20 minutes of welding you have to allow 80 minutes to cool down
if however you have a 200 amp welder with a 20%duty cycle but it is welding at 20 amps then the duty cycle is extended dramatically other than that check for a fuse or take it in for a service
Dec 15, 2015 | Welding Tools
Craftsman 100ac infinant amp arc welder just stopped working ....the fan still runs. anybody know what's wrong with it????
probably over heated and blew the reset button
100 amp welders have a duty cycle ( time in actual welding use ) of less than 20%
that means for welding for five minutes you have to let it cool down for 20 minutes
the lower the amps the longer you can weld for
beware tat the total amperage of the welder does not mean that you can weld for a long time at that amperage
on the plate on the welder is the duty cycle and you have to be aware of it or the machine will shut down
Apr 18, 2015 | Craftsman Welding Tools
I have a miller bobcat 225 is lower power while welding, any idea?
First off, check all of your welding cables to make sure they're in good shape, then check for tight cable connections. Is your machine staying at low idle speed while trying to weld? If so, Switch the idle select into the 'weld' position and make sure the high RPM's initiate. Try welding again. Better? Could be a number of things, if not.
Dec 12, 2014 | Bobcat Miller 225 Welder Generator 907209...
Wire will not feed ,I was welding with my weldpak 100 and it just stopped feeding the wire so I shut it down to look at the next day when I tried it the next day the wire fed like it was suppose to until...
Your weldpack 100 has a duty cycle of only 20 t0 30%, meaning that your machine will weld for 2 to 3 minutes and then you need to let it cool down for the 8-7 minutes, then start again.
If the problem continues let me know.
Jan 03, 2011 | Welding Tools
Welding machine wont start
there might be a low oil shut down switch that is open, look for it and jump it out, and then try to start it
Nov 15, 2009 | Lincoln Welding Tools
Welding machine stops working after a few minutes of welding.
there is probley nothing wrong its called duty cycle.which means that if you are welding long periods or welding at max amps the welder will kickout to cool down.Look on your unit for the tag that tells imformation about your unit.It will show something like 30% duty cycle so that means you can weld 3 minutes at full power before the unit shuts down.
Mar 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welding Tools Logo
91 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
