OK, I am incredibly impatient, so I just figured out how to disassemble the bodygroom on my own. The button issue is fixed quite easily as there is no spring.
To disassemble, I simply removed the silver/gray side plates. Then put an instrument in the blue hole and torqued it a bit and the fittings popped out of place and the top released. I recommend using some sort of plastic tool so as not to mar up the casing. Then, the guts are fairly straightforward. The button is just a piece of rubber with a rubber knob on the bottom. When you push it, it simply pushes a really small button on the motor. When it gets stuck, I am guessing the rubber knob has somehow gotten stuck next to the motor button. After you take off the top cover of the motor, the button should be back to where it is supposed to be. Just put everything back together in reverse order.
That fixed mine! Good luck!
Thanks a lot you saved me from breaking all the plastic parts cause I'm also very impatient xD your post-guide came with first search and that was seconds before i start breaking it apart on my own!! I found the device working just when I came home, it was fully charged and the neighbour made fun of some ''vibrating'' noise coming out of my home while i was unlocking the door looooooool
Excellent! After reading this I had my problem fixed in less than 10 minutes. Disassembly was as you described and then using the bit of knowledge further down that says it's a vacuum problem in the switch, I found a little rubber tab just below the switch that looked pretty liftable, so I pulled it out, there was a little pop and the switch was back to looking/working normally. I reseated the tab and reassembled the shaver and I just saved a buncha bucks. Thanks!
Thanks to Dallas2008 on how to open the device.
I found out that my button was stuck because of the air pressure. I heard the sound of the air coming in the inside unit as soon as I opened it. The rubber thing on top of the button pop out instantly.
Conclusion, the lower pressure inside the unit "pulled" the rubber against the button therefore creating the problem (I couldn't stop it anymore...)
So I could have solved my problem by taking the smallest needle I could find and pierce a little hole in the rubber to release the pressure. Then I would have filled the hole with some kind of glue (water getting inside is not an option here...) and the problem would have been solved without even opening the device.
No need to do that, better remove the outer casing as per the instructions of dallas2008 and then just fiddle the hinges of the internal water proof casing a bit to allow the air back in so that the button can come back to its original position.
I contacted Norelco customer service and they said there is a 2 year warranty on the unit. They are sending me a new unit and asked that I return the old one to them once the new one arrives. They were very helpful and extremely pleasant.
I took it apart (per Dallas2008's instructions) and then I put some electrical tape on the underside of the rubber button. Hopefully this will prevent the button from sticking to the small mechanical button.
I've owned 2 Bodygroom shavers and had problems with the buttons on both. The first went bad shortly after Christmas when I had a gift card to a local store and just replaced it. I had the same problem twice now with this one, the first time it may have just been stuck.
The second time, the tiny button inside broke right off. I was able to very carefully solder it back on, but I'm not sure how long it will last.
The button is fairly easy to access, dallas2008 provided decent instructions to get at the shaver mechanism. Just be careful with the clips on the bottom of the shaver, they seem to break easily. Once you remove the casing, the shaver mechanism should come right out, and you will just have to release a few more clips to open the inner case to get at the electronics.
This shaver is supposed to be waterproof (though I've never tested that claim), but I wouldn't recommend using it in the shower after disassembling the interior shaver mechanism.
I would recommend being VERY VERY gentle with the button on your shaver or you are very likely to have the same problem as it is a design defect that will likely never be fixed. Quite a shame really, besides this not-so-little issue, it's a really nice shaver.
I have acquired a bulk lot of the Bodygroom razors. Most are new in
boxes but a few have obviously been opened and of the opened ones a few
of them have some sort of damage to the thin foil shield that covers
the cutting head. I have removed the heads from the ones with damaged
foils. I can get new heads for around 10 to 12 dollars, but would
prefer to just sell off the bodies.
For $10 I can send you one of the new units. You just have to snap your
cutting head out and put it in the new one. These are not the black
and blue ones but the newer two tone sliver and gray models.
They also come with matching charger stands. The chargers and units are
totally compatible with the older units, just a diffrent color on the
handle and stand.
For more info see this thread "Phillips-Norelco Bodygroom ( Body Groom BG2022 )" On the Thong Wearers Message Board
Having a whole new unit will solve the button problem without having to
open it up and it gets you a fresh unit with a new battery to boot.
Instead of trying to fix it I've found the easiest way to turn it off is to put the unit into the plugged in charger. It turns off as soon as it makes contact.
I followed the instructions of dallas2008. I removed the plastic top casing like he said. But I did not disassemble the interior. The button gets stuck because when you press on it too hard, air escapes the casing but is unable to get back in due to the water tight nature of the inner casing. When you have the inner casing out of the outer plastic casing, just fiddle with the hinges in the corners, this will allow some air to enter back into the casing, allowing the button to come back to its original position. Better not to open the water tight internal casing because then it might not remain water tight any more. Good Luck.
same in mine
Same problem with power button stuck in "on" position. Seems like a spring or something may have broke. Do I need to throw it away or will Norelco offer some sort of remedy for its customers?
Exact same problem
what if your product is not under warranty still?
does anybody know how to disassemble the bodygroom properly? It is all plastic snaps that can break easily so I don't want to use force.
The exact same thing happened to mine which is why I am searching the forums. Anyone with any luck?
Button got stuck after half-a-years' use. Got a new one from warranty which also broke after 6 months of use.
Thank Dalla2008. Your instruction fixed my problem
Thank you Dallas2008. Your instruction fixed my problem
