Question about Miller Syncrowave 200 Tig Welder Cover 300059 New
Miller syncrowave 200 makes buzzing noise from spark gaps.
Makes buzzing sound when tig welding in both ac & dc polarities.also, when cooling fan kicks on the machine boggs.
  • 169 Answers
Odd noises other than the normal sound of the spark gap working are often the result of dust and junk inside the case of your welder. That it also bogs down when it gets warmed up (fan comes on), also points to a need for some "annual maintenance" stuff being done.
Completely isolate the machine from the building power supply, pul the plug, open the circuit breaker, do whatever it is that makes the machine have no connection to any power.
Take off the covers with a 10mm or 3/8 inch socket (can't remember which)
Use a shop vac to **** out all of the dust and debris out of the machine. Low pressure (40 psi) air can sometimes be helpful to dislodge caked on dirt. Avoid any metal tools near the capacitor bank inside the welder.
Wipe off the fan blades.
Clean the spark gap electrodes by inserting and removing a matchbook cover, a business card, or a piece of white cardboard several times. Inspect the electrodes and adjust them according to the manual that came with the welder.
Check all of the power wiring connections for tightness by gently tugging on them. Look for signs of overheating on the power connections and on the internal connections to the welding terminals. Check the range switch for heating too.
With the cover still off, reconnect the power and turn the welder on. Look for obviously vibrating laminations on the main input transformer. If you see one buzzing back and forth, or if you notice lots of wear and tear on the varnish coating of the laminations, shut everything down and repair the loose laminations with some anti-fungal high voltage varnish.
Turn the welder off, disconnect the power, and put it all back together. Then turn the power back on and weld something, if htere is still a buzzing noise you'll need a Miller tech to solve the problem, you likely have a bad input transfirmer.
Regards,
Carl
Posted on Jan 26, 2009
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
Can't set up syncrowave 351 to tig weld aluminum. I can not seem to get the settings right to melt the aluminum. It just leaves a bif spot on the aluminum plate.The plate is about 1/4" thick and...
Set the "arc balance" control between 40-50, also. You need to be up around 200-220 amps too. Make sure you're using 3/32 tungsten (green, red) and running about 25-30 cfh on your argon. Ball that end on the tungsten.
Oct 08, 2011 | Miller Electric Manufacturing Electric...
I have a Miller Syncrowave 250 DX and it has 3 fans, 1 come on as soon as machine comes on and after welding for about 10min the other 2 come on but they are not
Do you mean to say that the other 2 should come on, but are not? Perhaps you are welding using lower settings than before, and the machine just isn't heating up as quickly. Is there a point at which the fans do come on? Say thirty minutes into the job instead of ten? Maybe you were afraid to run it too long without the cooling fans on and so stopped prematurely, before the thermostat turned them on? Check fuses and breakers.
Sep 01, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
How too set up a tig welder for welding thin steel?
DC current, electrode negative (DC Straight, DC-), High frequency for start only (really don't have to use high freq at all for steel but it helps establish the arc without scratching), 1 amp per thousandth of material thickness is a good setting to start, adjust from there for the job. 1 amp/thousandth also applies to aluminum- it has a lower melting point than steel but conducts heat much better so power to weld is very nearly the same.
Use a sharp tungsten, don't ball it at all (as you would for AC work).
lp
Dec 01, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Syncrowave 250 dx fan not comming on
I have a Miller XMT304 in for repair at the moment and it will run full load (250A) on a load bank for 5 minutes before the fan comes on. By the way the fan is 24v DC. I couldn't be sure but your fan may be similar
Hope this helps.
Jun 09, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Syncrowave 180 sd. I was welding when it shut
Sounds like a bad thermister on the rectifier or a bad control board.
Aug 12, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Miller Syncrowave 200 Tig Welder Cover 300059 New Logo
1,266 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Robert Monigold
Robert Monigold
wadingriver
wadingriver
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
