Question about Belkin (F5D5231-4) Router
Lose connection after reboot and...
...cant then commnuicate with router through control panel; 192.168.2.1 etc.
I am quite experienced with the Belkin ADSL2+ Wireless G Router, and know most tricks to get them working, however this latest problem, I am stuck.
I have to do a full reset everytime to get it working again.
Also, I did check the Power save featiure on the Network card and it is disabled. Its a Nvidia Nforce onboard.
Any help I would really appreciate,
Best Regards
Ritchie
    Genius:
  • 1,061 Answers
CONTACT BELKIN FOR A FIRMWARE UPDATE.RICHARDM69
Posted on Dec 16, 2008
  • 41 Answers
Hi Ritchie
Have you tried installing firmware for router again? Could be a glitch in the firmware.
Give your network card a Static IP address, gateway and set dns to router's IP? Found that some times this happens on auto asign.
If tried all above take in to repair centre phisical hardware problem or replace it.
Feel free to Search the Repair Service Directory on this site for a centre near you.
Regards
Go-Tech
Internet keeps dropping
check your router signal strength ,if it is low then it can drop internet connection..
you can try to reboot..its a good option....:))
if everything fail then try to connect using cable and ping with proper IP address and check router signal strength .......
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 29, 2012 | Linksys Wireless-G WRT54G Router
Cant connect to internet with intel pro wireless router. I use a belkin54g to connect, no issues in the past but now i get a "unable to connect". The connect is good but i cant connect.
There could be quite a few reasons why you can't connect, but if you are sure the router is connected and past experience indicates it could be your browser. Click start and goto control panel. Double click internet options, click on the advance tab at the top, near the bottom of the window is a reset button, click that select everything then ok. When finished try to connect and all should be well.
Good luck.
May 28, 2011 | Computers & Internet
Dir-601 wireless router isn't giving us internet connection. We are able to connect to the internet using only the modem directly.
Try
START
RUN
CMD
PING
192.168.2.1 or 192.168.1.1
if it works you have a connection to the router .
Now try
Ping bbc.co.uk if it works you have internet connection but cant find DNS SERVER. In this case;
START
CONTROL PANEL
NETWORK CONNECTIONS
RIGHT CLICK WIFI ADAPTER
choose PROPERTIES
select "this computer uses..."
INTERNET PROTOCOL (TCP/IP)
PROPERTIES
"OBTAIN INTERNET ADDRESS AUTOMATICALLY" tick
also tick OBTAIN DNS AUTOMATICALLY
SAVE and Close network properties
REBOOT ROUTER and PC
recheck PING bbc.co.uk ...if successful ensure or use internet explorer
Mar 25, 2010 | Office Equipment & Supplies
I cann't connect to some specific web when using the NetGear router. I never have this problem before. I have try bypass it by connect my internet directly to the modem then the web get in is ok, by when I...
a lot of times its the sequence of the reboot for each device. what happens is, the modem connects to a particular device (computer, router, etc.) and then establishes that connection as a relationship. if you try to plug the ethernet cable into a different device without rebooting the modem, it will never connect. that being said........make all of your connections modem ethernet to router input, then router output to computer ethernet input. then, reboot the modem (with no power plugged into the netgear...its next, just no power yet). once the ready or cable light goes solid and the modem is up, plug the power supply into the router and let it do its thing, then you should see the "i" with a swoosh under it light up, it will be orange for a bit until it connects to the modem, finally turning green. from the router to the computer ethernet.......click your start button on your desktop, click the "run" near the control panel button....a little window pops up down by the start button....type the letters cmd (short for command) and then hit ok button...........black screen for dos pops up with a blinking curser.......type ipconfig then hit enter. the first stages of numbers for the default gateways etc should read close to this 192.168.0.1 (this is the ip of the router). if you see these numbers, you should be able to surf the web. you must do the reboots in the sequence as stated above.. give each interval a minute to do its thing. some newer operating systems need you to physically acknowledge the "new network detected" and select home away office...... so once the reboots and the ipconfig stuff is done but you still cant surf, restart the computer, hopefully when it comes back on it will detect the new network.
i am a senior tech for charter cable and have installed over 5000 internet connections.
you can also email me thru my website
yostamplifier.com for further questions.
Jan 21, 2010 | NetGear RP614 Router
Belkin n150 F6D4230 wireless router. lose ability to
try to upgrade the firmware of the router. that will help you.
For this you will need to connect the computer to the router. Do not upgrade the firmware of the router using the wireless computer.
You will need to download the new firmware from the manufacturer's web site. Then open the router set up page and upgrade the firmware of the router.
Click here for more information about routers and network
Jan 14, 2010 | Belkin Computers & Internet
When I connect my router i lose internet connection, even though my modem still shows connectivity. I have followed the instructions to connect the router to my computer and the modem to the router. Any...
firstly, connect your modem to the router and your pc to the router. Next, reboot your PC. try to access the net. If you now can, great. If not, you may need to switch on DHCP and NAT in your modem. DHCP means Dynamic Host Control Protocol and NAT means Network Address Translation. Both of these services are required to allow your PC to access the net through your router. I am assuming that you have a modem and a separate network switch. If you have a modem and the router is another modem with a network switch built in, then you cannot use them both at the same time. If the router has a modem built in, remove your old modem and set up the router according to its manual. Entering your ISP login details either through the routers setup software or through the routers own browser page. The manual for the router will tell you how to do this. If the router is a netwrok switch, then you will need to log into your modems browser page and turn on DHCP and NAT. Then save and reboot the modem and reboot your PC. Once everything has rebooted, go into your control panel, Network connections and check that a valid connection has been made. If yes, then access the net using your browser. If no, try the Network Setup Wizard to repair or replace the existing setup with an updated one. Just run through the wizard choosing the correct or most appropriate options from the menu's..
Oct 31, 2009 | Linksys WRT54G2 Wireless Router
Asus eee pc 900a wireless connection not working
I've experienced the same problem with my ASUS netbook. Uninstall the wireless hard - remove hardware in control panel, reboot the machine and allow it to auto find the adapter again. This should correct it. If there are still problems verify that you have the most current driver for the wireless adapter, either from Asus, or the wireless adapter chipset manufacturer (i.e. Intel, broadcomm, etc.)
Sep 01, 2009 | ASUS Eee 4G Notebook
Router reboot too often needed?
Try testing it using a differrent router and monitor the connection period of that router during the week. If you still experiencing the same problem using the tes router. It indicates that it may be a adsl line related problem.
Jul 28, 2009 | Computers & Internet
CANON IR C3200
Hi there, your printer is experiencing a shortage due to a lose connection that's located on the backside of the control panel. you will have to disassemble and remove this control panel to find this lose connection. this connection seems to be linked to the power board which explains why the screen turns black.
Feb 18, 2009 | Canon imageRUNNER C3200 Color Printer
Continuously lose connection
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware.
For the Firmware update go to :www.linksys.com
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Belkin (F5D5231-4) Router Logo
55 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
