Question about Motorola Mobility RAZR V3
Voicemail how can i set my razr to go to voicemail after only 4 rings? mine rings about 12 times before voicemail picks up
  • nelz Nov 04, 2007
    my phone rings 3 times before my voicemail answers.... but i want it to ring 5 times.. how do i change that?
See this link: http://www.motomodders.net/Default.aspx?tabid=68&articleType=ArticleView&articleId=14
Posted on Jun 03, 2007
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
Why does razr goes to voicemail too quick
It could be that the phone is delayed in ringing. Try placing a test call and see how many times it rings in the phone you are calling from before it rings on the phone. Then you can determine if the phone is delayed in ringing. If you hear ringing and the phone rings once and then it goes to voicemail then there may be a setting on your phone that is causing this.
Mark
Motorola Support
Jun 01, 2014 | Motorola Mobility DROID RAZR MAXX HD
Why does my driod go right to voicemail
Mark
Motorola Support
Jun 01, 2014 | Motorola Mobility DROID RAZR Maxx 4G...
M7310 voicemail
You need to access Admin programming in the phone system and navigate to Capabilities and change the Forward No Answer to the DN of the voicemail....if unsure of any of this you need to be calling your vendor that handles the system for all issues or questions.
Dec 06, 2012 | NorStar Meridian M7310 Phone
My co-worker's voicemail doesn't pick-up until it rings 12 times. how do we change it?
From his phone, on the intercom, dial *71324 You'll hear a tone and that makes his phone ring 4 times (24 seconds) and forward.
Carl
Aug 24, 2011 | Panasonic KXDT343 Phone
Our DECT2015 phone only rings 4 times and then stops.How cane I adjust the ringing time of our phone? Thanks Peter
Do you have voicemail or an answering machine? This is usually a sign that another device (fax, answering machine or voicemail service) is set to answer the call after 4 rings. You will need to lengthen to number of rings before the service/device in question picks up. (The method to reset this will depend on the service/device that is picking up.) Another possibility is a call forwarding service that is enabled at 4 rings.
I hope this helps. Please write back with details on the device that could be picking up for details on setting the number of rings. If you have voicemail or call forwarding, check with your telephone service provider to lengthen the number of rings before the service kicks in. (There are too many for me to know all of the providers instructions.)
Apr 16, 2011 | Uniden Lands Phones
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
Phone won't go to voicemail before 10 rings
You have to reprogram this locals cfw no.# of ring .
Go into progaming set type in local step to cfw and # of rings
Mar 12, 2009 | NorStar M7310 Corded Phone
Incoming calls
i would got into your voicemail settings and check to see if you have it set to ring once then straight to vmail.. i'm not sure how your phone is set up completely but i would assume you can adjust the amount of rings before vmail picks up.. is this phone new to you?
hope this helps..
d
Feb 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3 Logo
222 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
