Question about Toshiba Satellite M115-S1061 Notebook
Toshiba m115 will not power on
I have a toshiba m115,at first it would lose ac power till you wiggled the ac adaptor...one day ac power quit working and the battery continued to power the laptop just fine until it went dead. ive checked the ac adaptor and its good but to make sure used a buddies with same laptop but nothing,no lights,,,,nothing i opened the laptop and it has a connecter thats connected via wires and not soldered.......i jumped around the plug and hooked up the charger via the wires but still no power...please help
  • mrsjudkins Jan 10, 2009
    How can the charging circuit be blown if the laptop powers on? The led lights are on? The screen is just black and I can hear sounds from the speakers like something is in a loop. I can't truly fix this without being able to see
  • prettyeyedmf Jan 20, 2009
    I had the same problem I have spent over $300 on ac power cords replacing them and the 1st ac power cord I had actually cought on fire one night and almost burnt my house down!
  • 41 Answers
Hi kipdidy23
You have eliminated all that you could with the fualt finding. You will unfoertunetly have to take the notebook in to a repair centre. The charging circuit on the motherboard is blown. Please feel free to search he Repair Service Directory on this site for a repair centre close to you.
Regards
Go-Tech
Posted on Dec 16, 2008
My hp pavilion dv6-2117ax laptop won't power up (no power light on where adaptor meets laptop). Replaced power adaptor / charger and laptop powered up and operated for a day and then next day woul
The laptop probably isn't charging. Could be a bad d/c connector on the laptop or the battery is bad. Remove the battery and plug in the a/c adapter and see if it powers on. Wiggle the a/c plug in gently while pressing the power button on the laptop. It powers on and off briefly then I'd say it's the d/c jack on the laptop, bad sodder joint.
Dec 04, 2012 | Computers & Internet
I can barely see the screen, its very dark. Its a toshiba satellite m115 s1061
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 05, 2010 | Toshiba Satellite M115-S1061 Notebook
Ac power doesnt work only in battery mode,adaptor output is ok
sounds like the power connector (where you plug into pc) is going bad. try twisting / wiggling connector. pause for a few seconds between twists to give circuitry chance to reconize power input. sometimes there is a green led that will light up when power adaptor is inserted. you can use that as a reference.
Jun 03, 2009 | Computers & Internet
Keeps powering on and off.
Keep in mind since you cleaned it out, only have the AC adaptor hooked up to rule the battery out. If the laptop stays on with only the ac adaptor hooked up and doesn't shut off then you know that the battery is faulty. If it still shuts off even with just the ac adaptor hooked up then it could be the ac adaptor.
Also check one more thing, with only the ac adaptor hooked up, wiggle the cord where it plugs into the laptop and see if the laptop shuts off, if it does then the dc jack on the motherboard is loose and needs to be resoldered back into place so it stays put.
May 13, 2009 | Dell Computers & Internet
Toshiba satellite m115-s3094,no power
try to turn on your laptop with ac adpater plug in only (no battery)
if this thing work, download the BIOS update..because all battery have smart sensor this might be the reason.
after you install the updated BIOS plug the battery and power supply and turn on your computer
if you did this and still getting the same issue call your manufacturer support...it might be the motherboard.
Jan 28, 2009 | Toshiba Satellite M115-S3094 Notebook
Erratic Touchpad on Toshiba M50 Notebook
if the touchpad is working fine with the battery and if it is not working with the ac adaptor then in this case u can try with the different ac adaptor and still if it does the same thing then uninstall and resintall the toouchpad driver and restart the computer and still if it does so with the ac adaptor then u need to open the laptop chasis and then u need to fix up the power supply connector in the motherboard where the power supply from the ac adaptor is not getting the adequate response from motherboard.
Dec 21, 2008 | Toshiba Satellite M50 Notebook
ToshibaSatellite M115-S3094 won't turn on
Pull the ac power and battery out. Wait about 15 minutes and replace both. Try to power back up.
Nov 18, 2008 | Toshiba Computers & Internet
Power on problem
First that u need to do is to remove the battery from your toshiba laptop. Plug in the AC adapter alone and power it on. If it works, then u need to check your battery. If the notebook wont power on with the AC adapter alone, then i think its a NO POST issue. The motherboard needs to be checked.
Sep 17, 2008 | Toshiba Satellite M115-S3094 Notebook
Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Mar 14, 2008 | HP Pavilion dv6000z Notebook
Toshiba Satellite 1405 - Power problem
Hi Don
Although symptom is showing that AC Adaptor is not working as its not providing power to the unit. I will suggest you to perform some basic troubleshooting steps. Check if outlet is working if not check with known working outlet. If you have a multimeter you can the output of the AC adaptor.
Also you can perform full power cycle and component discharge. Take the battery out and disconnect the AC adaptor press the power button and hold about 7 seconds. After that put the AC adaptor in and test again.
If issue persist take to nearest Service center check with known working AC adaptor. After that I believe you will figure out the best solution.
Good Luck
Jan 21, 2008 | Toshiba Satellite 1405-S151 Notebook
Toshiba Satellite M115-S1061 Notebook Logo
140 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
