Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Do you put hot water in the tank
Do you put hot water in tank
  • 35 Answers
It would depend on whether you machine preheats the water or not,and what kind of machine,Bissell,GE,etc..If your machine doesn't heat the water,then I would use hot water.Do not boil water,tap is fine.
Posted on Dec 16, 2008
How do you put water into the tanks for cleaning. I see the 2 in 1 tank but can't figure out how to get clean water into the reservoir>
easy one the tank separates , there a clip that is on the flat side of the tank assembly, there is a handle to pick it up, half round handle. On the flat edge you"ll see the clip., unfasten the clip and the top and bottom separate, below is what looks like a hot water bottle,you fill that bladder with hot water, the outside plastichousing stores the dirty water, once full, a level sensor will rise and the vacuum will stop sucking! thats it!
Aug 16, 2014 | Vacuums
My bissell9200 sraying wont stop
line is clogged put hot water in tank take it outside and run the hot water through it. Keep hitting the trigger.
Nov 10, 2013 | Bissell 1699 ProHeat Clear View Upright...
Does it heat the water? when I empty the holding tank the water appears not to be hot.
I believe it does not heat water. you put hot water in w/cleaning solution. it is cool by time you empty holding tank.
Sep 03, 2011 | Hoover SteamVac F5914-900 SpinScrub...
There are two containers, where do I put the water and solution
The upper tank holds the cleaning solution. Mix 5 oz. of Hoover detergent to 1 gal. of hot water. The line on the tank indicates 1 gallon.
Apr 10, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Wear do you put the water
Inside the main tank is another container for clean water.
To fill it, lay machine all the way down. Lift handle and remove container. Take to sink, turn handle, and remove lid. Fill with hot, clean water. Replace and lock the lid. Place container back into tank and put handle down.
Sep 29, 2010 | Bissell 1699 ProHeat Clear View Upright...
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaning solution will not dispense
After sitting for a period of time, some of the solution may have dried in the inner walls of the feed tube from the solution tank. What I would suggest is to empty the solution tank and then fill it with hot tap water, put it back on the Floormate, and hold the solution "feed lever" on until it starts dripping water. The hot water will hopefully disolve the dried solution and allow it to flow again.
I hope this helps! :)
Sep 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Filling the cleaner
cleaner goes in little tank on side. Hot water only no soap goes in the big tank in middle
Jun 25, 2009 | Bissell 1699 ProHeat Clear View Upright...
My scooba 5810 won't run
Fill the dirty water tank with hot water and giving the tank a good shake then pour the water out. Continue to do this until the water coming out of the dirty side of the tank is clean.
Jan 18, 2009 | iRobot 5800 Scooba Vacuum
Bissell 9200pro heat2x
Wouldn't be the pump, the pump pushes the water out when you are spraying. If a suction problem check for clogged filters, is the tank sitting down tight?
Mar 04, 2008 | Bissell 9200 Upright Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
62 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
