Question about Kenmore Elite HE4 Electric Dryer
No Heat The dryer turns on but there's no heat. Would that be the element and how would I verify it.
  • Kenmore Master
  • 8,220 Answers
Get an el cheapo ohm meter. Set it on the green ohms setting so that when you touch the the 2 leads together the needle goes over to the right. That means you have continuity or a complete circuit. Unplug the appliance. Remember this: always take one wire off any item you want to check for continuity so that you will not get a false reading. Any item you find open will be the culprit. Start with the heating element. then go for the hi limit mounted on the top of the heater chamber. If the hi limit is bad but the heater is good you have a blocked vent. If the heater is bad you have a light bulb phenom. All things manmade perish. By finding out first what is gone haywire you save bucks right? We know it is not the fuse because the dryer would not run at all if the fuse was blown because its 2 smaller wires connect in with the door switch. All of the stuff you need to check is mounted on the rear of most dryers, some models have a bottom panel which is held by spring clips. The element is easily replaced in that model.
Posted on Dec 16, 2008
No heat
You need to verify the unit has 220 volts supplying it, your heating element requires 220 voltage to function properly. Here a video on how to check it. If your not familiar on how to verify volt at the receptacle DO NOT ATTEMPT THIS - GET A QUALIFIED TECHNICIAN TO IT FOR YOU!
Feb 02, 2014 | Abbaka White Knight 38AW Electric Dryer
Dryer with no heat
If it's a 220vac dryer make sure you hace 220vac at the wall plug. If that's there check the element for breaks and verify there are no burned off wires or loose connections. If element is good (check with ohm meter) check for thermal overload open on the side of the element.
Jan 04, 2014 | Kenmore Dryers
Heater not working. replaced heater still no heat. dryer spins
verify you have 240v at outlet, the dryer drum will turn with only 120v.
check thermal cut offs at the element if they have n continuity, you will not have heat.
Sep 18, 2013 | Zanussi TC7114W Electric Dryer
Kenmore electric dryer #11066512694 no heat & keeps running
Heat circuit also runs through timer and motor
Oct 26, 2017 | Kenmore Dryers
The dryer stoped heating its like its only cold air
I will assume this is an electric dryer.
When asking for help, you should include the brand and model number to help get a great answer.
In my experience, these are the possible problems in order of how often they happen.
1) Thermal overheat sensor fails. This is a small electrical device that will turn off the heating element if it thinks the dryer is getting too hot. It will have 2 wires connected to it and a silver colored round metal piece that senses the heat. When this part fails, the heater will not turn on. Disconnect the wires from this sensor and verify that it has zero (0) ohms across the two connectors.
2) Heating element could be burned out. Disconnect the two wires from the heating element and verify that it has a low resistance. Replace it if there is no resistance.
3) The thermostat has failed. There is a part that monitors the heat in the oven and turns the heating element on and off. You test it the same way you test item #1 above.
4) Some dryers have a FLUFF setting where the dryer only blows cold air. The switch that selects the heat settings could be broken. You will need to test this switch by looking at the electrical schematic for the dryer and testing the switch as indicated.
5) The knob on the switch that chooses the heat setting could be pushed onto the shaft in the wrong position so it points to "hot" when it is actually set to "fluff." The simplest way to test this is to choose a heat setting one click, either direction, from the one it is on now. If you get heat, the knob is pointing to the wrong place.
Jan 14, 2011 | Kenmore Dryers
Dryer will not heat and i cant find how to get to the heating element. Need a diagram of how to get to heating element.
Start at your breakers. Turn FULLY off and back on again, and test. Be sure to verify that you have really good air flow outside of the building, restricted air flow will cause overheat interrupters to open heat circuit, they reset when cool.
Dec 23, 2010 | Frigidaire GLER104FSS Electric Dryer
Replaced Kenmore dryer heating element. Element worked initial after being installed one time. Turned dryer off and moved dryer back. Turned the dryer on a second time and it now wont work. Drum will turn...
I would pull dryer and re-investigate the element to make sure no connection came off and to verify the coil did not burn in half. Hope this helps Tim
Aug 29, 2010 | Kenmore Dryers
ELECTRIC DRYER WON'T HEAT, TURNS ON , BUT WON'T HEAT.
If your dryer runs but doesn't heat, verify that all breakers (or fuses) are fine. If one is blown, the dryer may still operate but not heat.
Another common cause of a dryer failing to heat (or only partially heat) is a faulty element. You will need to replace it.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jun 21, 2010 | Roper RES7646KQ Electric Dryer
Kenmore 70's dryer, not heating,
Maybe timer, try a different heat cycle.
Feb 06, 2010 | Kenmore Dryers
The dryer will spin but will not heat. The heating element works. I have taken it off and verified this. When I reattach it to the dryer I can not see it turn orange while connected however.
test to to make sure there is current and voltage getting to and from the element to much resistence can cause it to not heat enough or even at all do your tests with the dryer unplugged to prevent shock
Dec 21, 2009 | Kenmore 63942 Dryer
Kenmore Elite HE4 Electric Dryer Logo
49 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
