Question about Protron PLTV-32 Television
Volume control on my Verizon remote stopped working
I had the code for my Protron 37C programmed into my Verizon remote, it worked for more than a year and just the other day it quit working for no apparent reason. I then tried the remote that came with my Protron and it too is not working - at all. I know the Protron remote is sending out a signal becuase I put new batteries in it and I tested the beam by looking through a digital camera.
I have two questions: 1.) Does anyone know what the problem could be, and 2.) does anyone have the four digit code for my television so I can try to reprogram my Verizon remote?
Thanks.
SOURCE: Protron television remote control
No universal will work.. I'm making a remote for this TV that people can buy on ebay-- by july 1st 2007 search ebay for pltv-32 remote and you will find a programmed, ready to go remote for less than $25 that will work well with other devices (comcast cable box, sony audio systems, etc..)
Posted on Jun 22, 2007
  • 21 Answers
SOURCE: remote control not working
if you still have a problem (and the tv!) email me at gmail.com
Posted on Aug 31, 2007
SOURCE: Replacement remote or code
Punch in the code #0003 to program a universal remote...
Posted on Dec 21, 2007
SOURCE: Programing codes for a Protron TV
The codes for the 32' Protron are 1004 or 1011. However be aware that this may disable your defaults permanently. When we had the cable installed they changed the codes but on doing so, the TV was useless. On power up the led will go from red to green, then go back to red instead of giving a source option. Customer service is agravating and useless; this is Chinese company that is using the name ProtRon to ride on the better make of Proton. We bought it through ShopNBC, definitely a big mistake since they are of no help either. We have taken the TV to a repair shop; they say its a main board but they are having extreme difficulty getting help from Protron; only delays and excuses. There are more issues riding on all this that has prompted my wife and I to seek a class action.
Posted on Mar 02, 2008
SOURCE: Remote control programming- Directv
if you have gone through all of the programming codes; you will just have to use the remote that came with the TV set. there is no way to program more codes into the remote, due to its list of codes it was made with can not be updated. i hope this helps
Posted on Feb 02, 2009
Protron pltv 37c
Check this code [1288]. If you wish to get more, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 29, 2013 | Protron PLTV-32 Television
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
Having problem to use the Verizon FIOS Remote control to control the volume of my Sceptre X42 LCD TV. The FIOS remote is able to turn On/Off the TV though. Any idea what is wrong with this?
program the remote to control tv volume by 1. Press and hold the STB key. 2. While holding down the STB key, press OK. 3. Release both keys. The Device Keys will blink twice. 4. Press 9 - 5 - 5. The STB key will blink twice. 5. Press TV. The TV key will blink 3 times to indicate success in programming. try the remote after that . if the volume still doesn't work check to see if there is another code that also works with your TV. (on my Sony TV one code works everything while another code only turns it on and off. for my Epson S3 the remote will not work with it at all.) here is the manual for the remote: http://www22.verizon.com/NROneRetail/NR/rdonlyres/2DEF67C9-87F0-4B46-B1BD-A40472BC281A/0/PhilipsRC144RemoteControlUserGuide.pdf
Dec 07, 2009 | Televison & Video
Cant use fios remote to power/volume
Yesterday I called Dynex at 1-800-305-2204. The rep gave me 0463 which didn't work when I called VERIZON FIOS but the Dynex rep did inform me during the call that if it didnt that Dynex is comparible with Orian, Emerson, Memorex, Sansui, Sylvania and Zenith. So any of these tv codes should work. The code of Orian which is 0490 indeed worked!!!! And when you call Verizon make sure when they help you program your remote that they do the second step if they dont tell you which is add the code 799 which will let you just push STB then Power to cut on/off the tv. My bedroom tv, I always pretty much had to use the tv remote to cut on and off but when the Verizon rep gave me that step for the original tv I was having problems with told me this step, I had her walk me through the other tv remote and add that code and its great. She said that alot of technicians just been taught the other way. Hope this info help you.
May 23, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Can only turn tv on manually
what kind of universal remote did you use? I am having the same problem. I use my dvd/vcr remote but i have to get up to adjust the volume.
Jun 15, 2008 | Protron PLTV3250 32 in. LCD Television
I have a protron 32 inch tv
I have 32 ILO flat screen TV does anyone have the code for this tv on the direcctv remote (white remote)
Mar 10, 2008 | Protron PLTV-32 Television
Protron pltv 32 directv remote code
Protron 32", new Directv R66 receiver/remote. Code is 10030. Works
Feb 02, 2008 | Protron PLTV-32 Television
Protron 37" LCD, PLTV-37C
You can look it up under the Spectroniq PLTV-3750 TV. Protron changed their name but kept the set up the same. Hope this helps...
Jan 18, 2008 | Protron PLTV-37 37 in. LCD Television
Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Jan 03, 2008 | Televison & Video
Remote code for PV-M1349
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
Nov 25, 2007 | Panasonic PV-M1349 Combo
Protron PLTV-32 Television Logo
225 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
