Question about HP Vs17 17" LCD Flat Panel Monitor
My Computer I took the cable wire off and still it's doing the: VGA input; no input signal, after I keep turning it on and off I do finally get my computer to come on though. I didn't know how to take the back of it off though to try that. Please assist. Thank you.
  • cutebear2 Dec 16, 2008
    My monitor says VGA input: no input signal...
  • Ron Roske May 11, 2010
    Although I seem to remember your screen name, this problem is not ringing a bell right now.. Can you please refresh my memory or let me know when you originally posted a request?
    Then maybe I can be of some assistance.
    Ron
    Sergeant:
  • 324 Answers
OK. Thanks for the response. That message is telling us that the monitor is getting no signal from the computer. In your case, it sounds like it is working part of the time. So, here are the things that can cause the problem, starting with the monitor and working backwards.
1) The monitor may have an internal problem.
2) The cable connector that goes into the monitor may have a loose connection or be bad. Check for loose or bent pins in the connector plug and socket, and that the plug is seated properly and is tight.
3) The cable itself could be damaged and have a wire that is cut or pinched. Look for cuts or heavy crimps on the cable.
4) The cable connector that goes into the computer may have a loose connection or be bad. Check for loose or bent pins in the connector plug and socket, and that the plug is seated properly and is tight.
5) There could be a problem with the computer that is internal. If there is a video card that plugs into the mother board, you could unplug it, clean the dust and such from the contacts on the card and around where the video card plugs in the mother board and reinsert the video card. Also, the video card itself could be bad,in which case it would need to be replaced. Some systems have the video function as a part of the mother board. If that's the case, the mother board would need to be replaced.
One thing that you can try when it is failing. While watching the monitor, firmly wiggle the cable and each of the connectors to see if the signal comes and goes. You may want to enlist someone to watch while you wiggle, or wiggle while you watch (That sounds kind'a bad doesn't it? <Grin>) But, that could tell us something.
Hope this helps and will be waiting to hear back from you on this.
Ron
Posted on Dec 16, 2008
No signal
Press the Function Button to open the short cut menu. Locate the Input graphic and press the button for it. Each time you press the button, it will cycle between DVI and VGA input jacks. Allow a few seconds for the display to switch inputs. Make sure that cable is connected securely to the associated jack in the back of the monitor and the computer (or other source). If either VGA or DVI input is selected ,but the VGA and DVI cables are not connected, a floating dialog box indicates:
"No Cable Connect" or "No Signal"
Your manual can be viewed here:
http://www.manualslib.com/manual/268264/Acer-S201hl.html#manual
Apr 07, 2014 | Acer S201HL BD Refurbished LCD Monitor
No vga input on working monitor
Turned on computer (Pavilion a1657c), HD light operates, Monitor has little window saying:
HDMI Input: No Input Signal
VGA Input: No Input Signal
Recommended Settings: 1920x1080 - 60hz
Changed from the monitor that came with it (HP f2105 digital ouyput) to my Samsung analog and same message comes on dark screen.
Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Computer Support
Mar 21, 2014 | HP Media Center m7657c home PC - RC640AAR...
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
I have a HP m7570n. How do I use a flat screen tv as a monitor
This depends on the TV's available inputs. The Pavilion m7570n has only a VGA output in the standard configuration.
Thus if the TV has a VGA port, turn off the computer and the TV. Then connect a standard VGA (RGB or D-sub 15-pin) m/m cable between the computer and the TV. To use the TV speakers, connect a 3.5 mm audio patch cable between the computers Line-out (green speaker port) to the VGA audio in. Turn on the TV and set the input to VGA (with the Source or Input button on the remote or the TV). Then turn on the computer. Windows XP should find the correct resolution to work with the TV. (If you turn on the TV after turning on the computer, you may get an unsupported signal. Press Ctrl-Alt-Del twice to restart the computer.) If it doesn't work, you may need to connect a different monitor and set the computer to a low resolution before connecting the TV and the computer.
If the TV only has composite or component video inputs, you will need a VGA to video converter (http://www.svideo.com/pctocomponent.html for example). A VGA to component cable will not work; those are for projectors that read an RGB input. TVs interpret YPbPr.
If you have added a video graphics card, you may have an HDMI and/or DVI port(s) on the card. In that case, check the specs of the TV. Some TVs will support HDMI or DVI-HDMI inputs from a computer. Others will not (since computer video signals are not the same as the signal from a set-top box). If you use a DVI-HDMI connector, make sure to use the HDMI port labeled for DVI and connect the audio cable as with the VGA connection. If you use an HDMI connection, you may need to set the sound properties to that of the HDMI port. (Find the control panel item for sound (under Hardware) and then select Manage Audio Devices. Set the Playback properties. If it doesn't work, use an audio patch cable.) Some TVs have RCA audio inputs for the HDMI-DVI connector. In that case, you will need a female 3.5 mm to RCA M/M adapter (if you use a 3.5 mm patch cable). There is a similar device if you want to use an RCA audio cable. You may need to enable the video ports on the graphics card before swapping monitors.
Some video cards have a TV out. In that case, connect the appropriate connector (should come with the video card). Then connect to the component, composite or S-video input on the TV.
Again turn off the TV and the computer before making any connections.
You will probably need to provide your own cables for must of these connection options.
I hope this helps.
May 12, 2011 | HP Pavilion m7570n (EX331AA) PC Desktop
What do i need to attatch lg model# lh40 or 1080p to ny computer?
U have a VGA signal cable right there out of ur computer LCD monitor used that.Used a VGA signal cable connected to ur computer and than to ur tv VGA input than find the tv input like in 1,2,3,4 find the computer VGA signal that it.If u have new and a recent computers like a DUO CORE processor 2 or 3 it have a HDMI cable hub design in this computers.Just used a HDMI cable connected between the computer and tv to for work the best in HD.
May 09, 2011 | LG Televison & Video
Moniter keeps turning off saying no video imput
Hello and Welcome to FixYa!
Check that the Input signal cable is properly inserted in the VGA socket. Secondly the Primary VGA is properly giving display signals to the Monitor/LCD. Because there are cases in which VGA is the bottle neck of the trouble you are facing.
Cross check and update me with the status,
Best of Luck,
Do RATE the solution, If found Helpful,
Concerned.
Jun 13, 2010 | HP vp17 Monitor
No Signal/VGA Input
use the " input " button on the remote control to select the input you are using to watch tv. she has accidently switched it to the computer input jack which is located on the side.
Jan 22, 2009 | Insignia IS-LCDTV32 32 in. Television
HP Vs17 17" LCD Flat Panel Monitor Logo
111 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
