Question about Whirlpool GHW9400 Duet Washer
The door on my Whirlpool duet sport won't close / lock ..
The door on my Whirlpool WFW 8400TW02 Duet washer won't close / lock . It's brand new and it was the first load of laundry ...
  • 2 more comments
  • Anonymous Mar 15, 2014
    how do i unlock door on whirpool duet wfw?
  • Anonymous Mar 29, 2014
    what steps do you take after you install the cpu.
    how do you install the cpu unit?
    how to install cpu into whirlpool duet sport
  • 85 Answers
Its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Posted on Dec 16, 2008
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
WFW 9400SW01
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WFW+9400SW01
and click on your model number. In the new window click on a diagram in the left-hand side of the window to show the location of the bellows seals. I believe you want the Door and latch parts diagram.
Mar 23, 2009 | Whirlpool WFW9400S
Brand NEW Whirlpool Duet Sport
After six failed attempts by your machine to lock the door F22 flashes.
Causes & Procedure:
Door lock mechanism is broken or removed from door.
Door switch or door unit failure.
1 Unplug / disconnect washer.
2 Check door switch lock unit.
3 Check wire harness connections to door switch/lock unit & the
Central Control Unit (CCU)
Fault 22
Push the door to make sure it is locked firmly (try some WD40 on the door mechanism on machine, not on door, to ease out any lock jam & try the door open/close with the power off the wall) I'm giving you tips to avoid the so-called techs zooming for your wallet.
Fault 28
The communication between the CCU & the MCU (motor control
unit cannot be sent correctly.
1 Unplug washer / Disconnect power
2 Check wire harness connection to the MCU, the motor & CCU
Check communication of the CCU board within the housing.
Make sure all grounding switches are engaged.
3 Check the drive system for any worn or failed components
4 Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
5 Verify CCU operation by running the Diagnostic Test or any
cycle after plugging in.
Will try getting back re the door lock. Desperate i know, so am i.
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Electronic control panel stuck on Whirlpool Duet Sport Washer
it looks like the panel switch is brooken . if you take the panel off and see if the switch.it may get stuck.
Feb 16, 2008 | Washing Machines
Washing Machines Logo
573 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
