Question about Innovera Wireless Keyboard/Optical Mouse IVR63100
Just received my IVR-63100 keyboard/mouse combo - do not work
I plugged the mouse in to the usb port earlier today to charge it. The wire became very hot and I had to unplug it. My keyboard and mouse will not turn on.
2 Suggested Answers
SOURCE: wireless keyboard and rechargeable mouse IVR-63100
need to sell ph products
Posted on Dec 23, 2007
After plugging the receiver into your computers USB port and making sure you've got good batteries in the mouse you'll need to do two things:
1-Make sure the power switch on the bottom is ON.
2-Press the pairing button next to the power switch just after you press it on the USB plug, if it has one.
Oct 04, 2015 | Innovera 61025 Wireless Optical Mouse...
Hi, Ausus Laptop Gaming. Use to use Logitech wirelewss keyboard and mouse over 3 years no issue. Just today only the mouse stop working, change battery, restart comp., not even the laptop mousepad...
Make sure your mouse and keyboard are close to the receiver (the thing you plug into a usb port). Also make sure you plug the receiver into another usb port because maybe some of those ports are incompatible with the receiver or some ports may be failing. Last, make sure you install the driver (program that came on the cd for your equipment) on the computer.
Aug 28, 2011 | ASUS Eee PC 900HD Netbook
Wireless keyboard and mouse works fine with computer but when I attempt to use it on the f1dh104l switch it does not recognize the mouse or keyboard. it is a dell e6400 laptop that i'm attempting to...
the problem is that most Wireless Keyboard and Mice combos use Composite USB, the KVM however is expecting one signal on each entry port (one for mouse, and one for Keyboard).
replace yoru wireless Combo for a standard Keyboard and Mouse to make this work.
A work around would be using a MS Wireless Mouse and a different brand of Wireless Keyboard using both Wireless receivers and plug them into different ports on the KVM
Jun 05, 2011 | Computers & Internet
I bought a gateway zx series computer 3 weeks ago. the wireless keyboard and mouse that came with it has stopped working for no apparent reason. the computer says that it doesn't recognize the device. i...
hi Karnarc.
How do I troubleshoot my Gateway wireless keyboard and mouse? How do I troubleshoot my wireless keyboard and mouse?
If you are experiencing issues with your wireless keyboard and mouse not working properly, perform the following steps to troubleshoot the wireless keyboard and mouse.
  1. Make sure the USB connector from the receiver is properly plugged into a USB port on the computer. Some systems ship with the receiver already preinstalled in the unit itself. Please check your mouse to see if there is a receiver inside of the battery compartment door.
  2. Make sure wireless keyboard is not on a metallic surface.
  3. Ensure that the receiver is 8-inches from other electrical devices.
  4. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
  5. Check the batteries in the keyboard and mouse to make sure they are installed correctly.
  6. Test the batteries to ensure that they still have a charge.
  7. Verify the On/Off switch on the keyboard and mouse are switched to On.
  8. Some receivers, keyboards, and mice may have a connect button. If so, follow the steps below:
    1. Plug the USB receiver into a USB port on your computer.
    2. Press the connect button on top of the receiver and the button will blink.
    3. Press the connect button on the bottom of the keyboard to activate the wireless connection.
    4. Press the connect button on top of the receiver and the button will blink.
    5. Press the connect button on the bottom of the mouse to activate the wireless connection.
Dec 03, 2017 | Gateway Computers & Internet
Cannot get mouse to work
If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
Restart the computer. This can resolve the problem, at least temporarily, so that other troubleshooting steps can be applied.
Move the mouse or keyboard closer to the receiver
The receiver is the hardware that receives the wireless signals from the keyboard and mouse and communicates the data to the computer. Most receivers connect to a USB port, either directly or by a cable, but a few types of receivers connect to the PS/2 ports.
. Make sure that the keyboard and the mouse are within 100 centimeters (39 inches) of the receiver. If the receiver is attached to a cord, position it so that it is on the same level surface, close to the mouse and keyboard.
4. Replace the batteries with a fresh set of alkaline batteries and make sure they are correctly installed. If the mouse or keyboard is not working, then replace the batteries, even if the mouse/keyboard software indicate the batteries still have a charge.
Remove the battery cover to access the batteries. For keyboards, the battery access cover is found on the underside of the keyboard. When replacing the batteries look for the positive symbol (a plus sign +) imprinted near the battery compartment or battery cover. Make sure the positive end of the battery is oriented to the positive side of the compartment.
If you have a USB receiver, unplug the USB receiver, wait 10 seconds, and then insert it into another USB port - preferably into a USB port that is closer to the mouse and keyboard. For example, if the USB receiver was plugged into a USB port on the back of the computer, unplug it and plug it into a front USB port.
Resync the wireless keyboard and mouse connections.
Resync the keyboard and mouse connections for receivers with a connect button .
Resynchronizing the keyboard and/or mouse causes the devices to reconnect to the receiver using new identification numbers.
NOTE: The following connection sequence must be completed within 60 seconds. If the sequence is not done in 60 seconds, start over.
Sep 10, 2010 | HP Wireless Optical Mouse
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked...
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Feb 17, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
I just received my Innovera IVR-63100 wireless desktop keyboard/mouse combo today, and when I plugged the mouse in to my usb to charge, the wire got very hot. Now I can't get the mouse to respond (and have...
Yes... it sounds like the charger was defective and fed too much power to the mouse. It has very likely fried the chip on the mouse. Warranty time. (happened to me as well... different device but same symptoms)
Nov 29, 2017 | Innovera Wireless Keyboard/Optical Mouse...
Wireless mouse not picking up
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Feb 25, 2008 | Fellowes Manufacturing 99666...
Innovera Wireless Keyboard/Optical Mouse IVR63100 Logo
71 people viewed this question
Top Innovera Computers & Internet Experts
Mister Danger
Level 1 Expert
Are you an Innovera Computer and Internet Expert? Answer questions, earn points and help others
