How do I get the wheel off the axel?
Your car should have a Jack located in the trunk (search for it, it may be hidden on the sides or with the spare). The Jack will have with it instructions on to specifically remove your vehicle's wheel. It will also have with it the necessary equipment (usually just something to remove the lug nuts). Jack up the car (place jack correctly), remove hub cap or wheel cover as necessary, then remove lug nuts to remove the tire. Pressure wash as desired, then place back on the car. Lower the car, but don't tighten the lug nuts fully until the car is back on the ground. Repeat for each tire.
I did figure out that there is a retainer at the end of the axle, under the cap. Using a wheel puller I pulled the retainer and the entire assembly came off. The job is done. Thanks for responding.
