Question about Aiwa AV-D67 Receiver
Static comes from speakers
I have an aiwa AV-D67 and sometimes while watching tv or a dvd, static will start coming out of the subwoofer, center and right channels, the static is relative to the volume (if you turn up the volume it gets louder). I can still here the movie/tv when this occurrs as well as the static. I have checked all of the wires and connections and they are fine. Its starting to do it more often and it is driving me nuts. Sometimes if I slap the receiver it seems to make it stop for a little bit (this may be purely coincidental) any help would be greatly appreciated.
  • 56 Answers
I think it's a grounding problem. Actually, it's a necessity for all audio-video equipments to get grounded properly. If you don't have a ground connection in your AC plug, your receiver will collect more and more static electricity. As a matter of fact, it decreases the sound quality that you can get from your equipment. I think that the effect of your reaction (slapping the receiver) isn't coincidental. When you touch any metal surface on your receiver (even while slapping) you condact the static electricity to the ground. I've had a same sort of problem with my receiver. Especially when I connected my laptop computer to the receiver, I heard an annoying distorted sound from the speakers. I found out that it was ground loop, which occurs when the negative (common) signal of the source coincides with the one of the receiver's. As a solution, I grounded my amp, changed all wires with new and shielded ones, and purchased an AC filter. Then, I got rid of the noise. I have to say that the AC filter (Belkin Pure AV Surge Protector, it also includes an AC signal filter)benefited me the most.
Posted on May 03, 2007
How do I watch a DVD with this tv. It seems like it is connected right but just showing static
Hi. By static, do you mean 'snow' image ? DVD players must be connected to AV inputs and selected as an AV signal, either by using the remote control, either using the local controls in the set itself. If you see, what you call static, means that your TV is on "a" channel without areal input. (antenna inputsignal).
You can use the local TV channel button (-), go all the way down below channel 1. There the AV inputs are located. Good luck.
Oct 13, 2014 | GE 27GT616 27" TV
Alot of static or interference through speakers
Check all leads are plugged in the right spots and are in good condition. Sometimes "static" is caused by plugs not connecting properly.
Nov 29, 2013 | Altec Lansing Audio Players & Recorders
There is static coming out of my speakers on my stereo. I I checke to make sureall the wires are connected properly and the power is plugged in securely. There is static with the sound on all...
Don't worry, it's more possible that you have the static electricity and through your stereo this electricity goes to the ground. Try touching another metalic surfasce (refrigirator, oven etc), try to change your shoes (especialy if your stereo is on a carpet floor and you walk on it) Sometimes when we are very nervous the static electricity on our body is higher. So keep calm.
Stelios.
Feb 20, 2010 | RCA WSP155 Main / Stereo Speaker
TURNING ON, BUT NO OUTPUT TO SPEAKERS.
Try making sure tape monitor is in off position. Also I assume front speaker button is engaged. Another option is that analog setting needs to be changed to digital if digital output
Apr 22, 2009 | Aiwa AV-D67 Receiver
Speakers work only on DVD
You might have connected your TV/Stereo Receiver up to the wrong audio outputs of the DVD player. Make sure you are coming out of the FRONT left/right audio outputs and not the CENTER?REAR left/right audio outputs.
Mar 13, 2009 | Panasonic SB-TP55 System
Need replacement remote
Hey Look at www.remotes.com I think they can help you !
Please rate my response!
Thank You!
Jan 16, 2009 | Aiwa AV-D67 Receiver
Speakers making a constant poping noise.
this could be due to some static  please get your electrical point checked up 1st  is your tv hooked to watch television thru RF or AV please have the interlink cables if this does not help get back with more details
Oct 15, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Volume high but no sound only a very low static sound
Make sure the unit is not swiched to tape monitor. Check to see if all inputs and outputs are wired properly. Unplug unit and let it sit unpowered for a half hour to reset micro-processor which may have locked up. When you power it up again, listen for click of speaker relays. Make sure to turn volume down BEFORE you power up. If none of these work, take unit to pro tech for check up. It just might be a simple fix, cheaper than replacement. Good luck.
Apr 02, 2008 | Aiwa AV-D67 Receiver
Cant find remote and subwoofer is off.
I had the same problem, lost the remote during a move. I ended up using a really cheap GE (general electric) universal remote. It's a blue and silver remote that cost $5 at bestbuy. Programming code for Aiwa is 839. Then, pressing the "enter" button on the universal remote brings up the subwoofer menu, and pressing it repeatedly will scroll through the individual volume controls for the other speakers.
As far as I know, there is no way of accessing this menu without a remote. Aiwa dropped the ball on that one.
Nov 03, 2007 | Aiwa AV-D67 Receiver
Aiwa AV-D67 Receiver Logo
311 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
