Question about HP Pavilion dv6000z Notebook
Laptop freezing My laptop freezes anytime you start it about 10 min after starting it up....so I have to shut it down and restart it to get it to unfreeze.
    Guru:
  • HP Master
  • 829 Answers
Check the system status go to the Task Manager and check which are the services running check for CPU speed if it reached 100% then you need to kill some services which is not running , sometimes it happes due to a virus attach , run antivirus and check for space and clear temp files and at last defrag the drive.
Posted on Dec 16, 2008
How to unlock a keyboard on a dell inspiron 5737
I would like to have more info, but, you can try these steps. After
each step try keyboard for operational.
1-remove battery, open pc and hold power button for 10-15
seconds. This resets system board. Replace battery and restart.
2-restart pc clicking F2 key to access BIOS, choose default settings,
restart.
3-remove battery, with plastic flat scribe pry top of keyboard down
and up from casing, disconnect ribbon cable, remove keyboard, clean
keyboard thoroughly under keys. Replace in reverse order.
4-replace keyboard. Free if under warranty. Less than $100 if not.
Jun 09, 2014 | Dell Latitude D600 Notebook
No start or quits going down road then re starts after 10 mins no spark
a bad crank sensor will cause car to shut down, and restart in about 10 minutes.while driving down the road.
Mar 13, 2014 | 2004 Chevrolet Impala
1994 f150 6 cyl engine shuts down every 10 min restart after 5 min
Sounds like the module inside the distributor. Have to be replaced.
Sep 29, 2012 | Cars & Trucks
Window hanging
Wait a few minutes for the non-responding program to start responding again. Be patient and give it some time. This is the easiest way to salvage any work that you did not save before the freeze. If, after waiting, the computer does not unfreeze, move to the next step.
Press and hold the "Ctrl", "Alt" and "Del" buttons in that order. This may unfreeze the computer, or bring up an option to restart, shut down or open the task manager. Open the task manager and note if a program is listed as "not responding." If there is one, click that program title and click "end task." The computer will end that task and break it out of the freeze. If this does not work, open task manager and go to "processes." Look for a process toward the top of the list that is using a large amount of resources. The number next to the process indicates how much of the resources are being allocated for that program. Pick one with the highest number (towards the top of the list) and choose "end process." If your computer still is not unfrozen, move to the next step.
Change the power source of your laptop. For example, if the laptop was plugged in to the wall, remove the plug and allow it to run on battery power. If this does not work, proceed to the next step.
Remove any devices, such as thumb drives or memory cards, that are plugged into the laptop. If this does not unfreeze the computer, move to the next step.
Close the lid of your laptop. Open the lid again. This may snap the computer out of its frozen state and back to the login screen. It may also put the computer into hibernate mode. If this does not work, move to the next step.
Hit the power button. This might bring up a menu asking you if you want to restart or shut down. At this point you will need to restart or shut down the computer. You will most likely lose what you were working on, unless the program has a recovery process to save your work if this situation arises. If the menu does not pop up, hold the power button until the computer shuts down. Wait 30 seconds, then boot the computer up again
Jan 21, 2012 | LG Computers & Internet
The engine does not start on hot weather. it start in the morning and evening but bot not in the afternoon. I've been to different places but nobody knows why
Engine main relay. Were talking crank no start correct!
If you were to start car coldlet it run for 10 min. then restart say in 5 min anytime of day will it restart. If answer is no then its the main relay. Contact on the relay are worn and seperate when they are hot.
Apr 19, 2010 | 2003 Honda Odyssey
Dryer noise sounds like bearing out or a roller is bad model # 417-98702891
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Feb 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Sceen freezing after 10 min
just check ur power options .
may be turn off monitor after 10 minutes is enabled.
change it to none
Mar 26, 2009 | Toshiba Tecra 9100 Notebook
Wireless card freezes my computer
This may be a driver glitch, uninstall the drivers and reinstall. If it still freezes, then it will be the card. Try a different card.
Jul 03, 2008 | Dell Inspiron 1000 Notebook
HP Pavilion dv6000z Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
