Question about Astar LTV-27BG 27 in. LCD Television
No picture Turn the power on and the green light comes on, but there isn't any picture.
Our LCD television did that and we had to replace the picture bulb in front. It was about a $200 item. Good luck. Does the green light flash intermittently? If so, it's the main bulb that brings you a picture. When you get the bulb, get instuctions on how to get to it. Be careful pulling panels to get to it as they will break if you're not careful.
Posted on Dec 16, 2008
42 inch Akai plasma - no pix no sound
i think your power board has some serious problem
May 21, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Why my almost 2 year old 20" lcd tv will not come on?
If the green light is on, power is getting to the TV but there may have been an internal power supply failure
Feb 10, 2013 | Sanyo DP26640 LCD TV
Tv green light comes on but no picture
You have a Power supply problem replace the Module.
Oct 31, 2012 | Coby TF-TV3201 32 in. LCD TV
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
My Magnavox TV give sound but no picture. When I turn it on the light in the bottom right hand screen goes green, then flashes to yellow and goes back to green. The screen does not change it is constantly...
You need to replace your backlight inverter.
Check that all voltages are coming from the power supply as they should. The power supply will be stamped with the correct amounts, and you just read with the multimeter to confirm.
After those check out ok, you will need to replace the inverter to "light" your screen again.
You can hear sound because the tv is ON, but the inverter isn't lighting the screen!
Hope this helps, please rate!
May 11, 2011 | Televison & Video
When I turn my Sanyo DP37647 TV on the green light comes on but there is no picture or sound.
When there is neither picture nor sound you're likely in need of a service or replacement of the main board.
Service is usually the way to go as replacement is unable to find or too darn expensive, at least in the past year or so.
The typical indication of this problm is that the front light doesn't just stay green, but actually blinks for a second every 15-20 seconds.
If it does that you're definitely in for service.
See more at
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
The DP37647 model isn't listed there as we're planning to post about it in a separate article...however it has the same symptoms as some of the others.
If you want to send the board in for repair , shipping instructions can be found at http://www.coppelltvrepair.com .
It really isn't a simple DIY service like a fuse or capacitor replacement.
May 26, 2009 | Sanyo DP37647 37 in. LCD TV
Tv will not turn on
I turn on tv green light comes on and gos off and no picture.
Feb 04, 2009 | RCA D52W19 52" Rear Projection Television
Picture wont come on screen
this problem is in the power supply.the red lights indicate as the standby mode.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv wont power up makes a noise but no picture
Your power transformer is likely shot. It'll cost at least $200 to have it replaced. Someone can come to your house to diagnose it. Usually costs around $65.
Nov 03, 2007 | JVC AV-56WP74 56" Rear Projection...
Astar LTV-27BG 27 in. LCD Television Logo
133 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
