Question about HP Photosmart A440 Printer
HP A440 series printing with green tint
I just got a hp A440 series as a gift. I went through the setup process, but everything it prints has a very green tint. I've went through the cleaning process the printer has. Any help would be very appreciative?
    Problem Solver:
  • 32 Answers
The first thing I would do is run a calibration utility, sometimes the printer doesn't know it is using too much (or the wrong) ink.
If calibrating the printer doesn't seem to work I would remove the ink\toner cartages and clean the pads and contacts of the printer to ensure that no green residue is causing your tint problem. Rubbing alcohol does the trick nicely. (if you don't have any on hand, nail polish remover works as well.)
Posted on Dec 16, 2008
HP Photosmart A440 Printer showing Incorrect or missing print cartridge flashing up even though print cartridge is installed
Try carefully clean the contacts in the printer. I would use cotton sticks with a little Isopropanol.
Sep 26, 2017 | HP Office Equipment & Supplies
Why has my hp designjet 1055cm has started printing everything with a red tint
Check helth condition of print heads, per form align print heads if nozzles are clogged replace print heads & cleaners..
Sep 09, 2011 | HP DesignJet 1050c plus InkJet Printer
HP Deskjet 3500 series, my printer keeps telling me that is is off when the light is green, keeps stating it is offline. When I installed the printer everything was fine, now when i print the printer...
Hi
HP Deskjet 3500 serie --
There could be a Software issue or hardware issue --
1) To check the software issue
Print a Test Page -- from the computer
2) To check the hardware
Press the Power button to turn the product on.
Press and hold the Power button
Open and close the front cover four times.
Release the Power button. The self-test will print
and it it is printing the hardware is fine ...
3) Then you can check by changing the USB Cable connection
Jan 01, 2010 | HP DeskJet 3520 InkJet Printer
I have an HP Photosmart Premium C3009 all-in-one printer. Sometimes it refuses to print with a message that says: The process stopped unexpectedly with status 1. I've looked in the manual and find no...
I also experienced the "process 'mdns' stopped unexpectedly with Status 1" message a few days ago with my new HP 7250, and found two solutions. Here are a couple of potential cures:
I downloaded the shareware program 'Printer Setup Repair', then ran their 'Reset and Backup' routine. Restarted, and bingo! Printing was successful. But trying to run either the HP scan software or the HP Ink Widget from Dashboard were not so successful. Got a 'Scanner not found' message. I then went to the printer, tried doing a manual scan there, sending the scan to my PowerBook. Once again, bingo. The scan was sent to my computer, and now the HP software could see the printer. I've since restarted both my computer and the printer several times; printing and scanning are working fine.
Now the second way to fix the problem. It's kind of hokey, but it seems to work, and is what led me to the The process 'mdns' stopped unexpectedly" with Status 1" problem in the first place. What you do is just add an ethernet router, that one you have lying around the house somewhere, between your DSL or cable modem and your Airport modem. Huh?
Here's the deal: when I first bought my HP multifunction printer, my wireless setup was this: Cable modem>Xsense ethernet router>Airport extreme. Unpacked and hooked up the HP printer, and it all worked immediately, perfectly. Print, scan, check supply levels, all no problem. Way too easy. Then, about a week ago I realized that the Xsense ethernet router that I had in the chain was really superfluous, as we no longer use ethernet in the house; might as well eliminate that unnecessary link in the chain. So I changed my setup to a simple: Cable modem>Airport extreme. At this point printing stopped. Tried everything I could think of, no go. Always got the "process ' mdns' stopped unexpectedly with Status 1" message. Put the ethernet router back in the chain, printing/scanning went perfectly. This made absolutely no sense to me, but it worked.
Left my setup with the extra router for a day or two until I remembered about the shareware program 'Printer Setup Repair', described above.
Before doing any of these steps it's probably a good idea to run Disk Permissions (I always run it before and after any installation), just to be sure you're authorized to be using the HP software.
May 04, 2009 | HP Office Equipment & Supplies
I have an HP 6180 that works fine except the colors are WAY off -- everything is muted and dull and the blacks are very weak. I've tried everything in the print dialogue box -- switching to application...
Bugger! HP wants your printer to work, so you buy more ink! Mine works beautiful
Scan a good photo and print it out or insert SD card and print photo on PHOTO paper GLOSSY SIDE DOWN Inkypete
Apr 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
D-Link DP-301U Print Server
try to do a normal install first. once that works you'll be able to use the driver that is installed to install via the print server.
Jul 30, 2008 | D-Link DP-301U (790069251979) Print Server
Green Tint Over Entire Printed Picture
I had a very similar problem and found out that the problem was the quality of paper I was using. Remember, a photo printer is expecting high quality results. Cheap, low quality paper will not accept the ink as well as higher quality paper. I can't guarantee this will solve your problem but I have not had any green tints since switching to a higher quality photo paper.
Jun 27, 2008 | HP Photosmart 8150 InkJet Printer
How do i install hp laser jet 1018 printer
hi johnboy
you can download the driver from here hp 1018
select your windows to download .
riz.
Jun 09, 2008 | HP LaserJet 1018 Printer
Hp lj1160 wont print
Printers can be tricky. My first suggestion would be to uninstall the printer from the computer. Then to reinstall, I would go to the HP website (they have many pages on installing printers, here is one about network printers at random) http://www8.hp.com/us/en/campaigns/wireless-printing-center/printer-setup-help.html
I prefer to use the drivers from the website rather than from the setup disk myself.
Dec 02, 2017 | Office Equipment & Supplies
HP Photosmart A440 Printer Logo
248 people viewed this question
Clive
Clive
