Question about Kogi L7CH Monitor
How do you turn off keylock
I cant turn off my keylock on my monitor???
Power off your display monitor then hold down the down arrow key on the monitor at the same time you power on the monitor. This should unlock the monitor keylock alshsh@epix.net
Posted on Aug 23, 2007
Cant get in trunk, release button not working, i removed keylock from trunk no key how can i get trunk open
if you removed the key lock than use a screw driver to turn the latch release
Aug 24, 2015 | Cars & Trucks
I have a Palm Z222. I cannot deactivate the keylock, which makes it impossible for me to use the Palm. Regards, Renate
spacer.gif spacer.gif How to preserve battery charge by preventing your Palm handheld from accidentally turning on via keylock Your Palm handheld is equipped with the Keylock Activation feature to prevent the device from accidentally being turned on (while in your pocket for example) and thereby preserving the battery charge. To access the Keylock Activation settings, follow these steps:
  1. Turn on your Palm handheld
  2. Tap on the Preferences icon
  3. Tap on Keylock located in the General section
  4. Tap on either Automatic or Manual to activate the Keylock functions
Sep 01, 2008 | Computers & Internet
The ignitioe will not turn out of the off position, the steering column will not lock and transmission shifter depresser button presses but will not move out of park.
SOUND LIKE IGNITION SWITCH KEYLOCK CYLINDER BROKEN. IN WHICH YOU CANT GET CAR OUT OF PARK.THE KEY LOCK CYLINDER BY TURNING THE KEY.IT MOVES A GEAR AND RACK ASSEMBLY THAT IN TURN MOVES THE IGNITION SWITCH ACTUATOR ROD AND PLUNGER TO VARIOUS POSITIONS REQUIRED FOR PERFORMING IGNITION SWITCH FUNCTIONS. IF KEYLOCK BROKEN YOU WONT BEABLE TO TURN IGNITION KEY OR GET CAR OUT OF PARK.
Mar 26, 2011 | 1999 Oldsmobile Alero
My 99 Alero doesnt want to start it wont let me turn the key past the off position i have to jiggle the key to get it to sometimes start i also have to spray WD40 into the key hole and it works fine for...
THE KEYLOCK CYLINDER FAULTY NEED REPLACING.IT WILL GET TO A POINT WHERE KEY WONT TURN IGNITION SWITCH. TRY ANOTHER KEY IF KEYLOCK STILL NOT TURNING. MORE LIKELY KEYLOCK CYLINDER NEED REPLACING.
Dec 17, 2010 | 1999 Oldsmobile Alero
How do I unlock the "keylock" Gtc td770a monitor?.. i really need help.. thanks
I read somewhere on another thread that you are supposed to power off the monitor and hold the down arrow while turning the monitor back on and it should reset the keylock. good luck hope this helps you
Dec 06, 2010 | Kogi L9CH 19" Flat Panel LCD Monitor
It tuner half way cant get the key out
Make sure your in Park, you may have to slam it into park to get key out or slightly turn wheel if it is turned. You might even have an keylock override button on the console.
Oct 21, 2010 | Pontiac Grand Am Cars & Trucks
Unlock Sharp XR-10X-L Notevision Proj. says keylock function on
According to pg. 45 in the owner's manual, you turn Keylock function ON by holding down the ENTER key on the projector for about 5 seconds while the projector is being turned on.
To take the Keylock off-- Hold down the ENTER key on the projector for about 5 seconds. If the projector is in standby mode, you can release the keylock by holding down ENTER and STANDBY/ON keys simultaneously for about 5 seconds.
Apr 27, 2010 | Sharp XR-11XC DLP Projector
Key lock on kogi
Turn off monitor, then hold down the down arrow key on the monitor while turn on the monitor. This should unlock the monitor keylock
Dec 15, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Kogi L7CH Monitor Logo
223 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
