Question about Microsoft Office Outlook 2003 for PC
Synchronisation between 2007 & 2003 task lists
Between three of my collegues we share a joint mailbox where our tasks are schedule. Since one of us has been upgraded to office 2007 we find that when he looks at the list, the tasks refresh and all tasks that have been maked as complete by other people on 2003 are now changed to incomplete and visa versa.
  • 41 Answers
Hi t_kingston
Just one more of the incompatibilties between office 2007 and 2003. You will either all have to upgrade to 2007 or the one person will have to down grade back to 2003.
Regards
Go-tech
Posted on Dec 16, 2008
Can't find AsusSetup.ini: C:\Windows\Chipset\AsusSetup.ini
Open the control panel, click "system & security", click "management instrument". Open the "Task Scheduler", on the left side you will find "Task Scheduler Library". Click the Triangle of "Task Scheduler Library" and the list of task will show up. Delete "ASUS" folder and quit. Reboot and you won't see that annoying same "Can't find...." message again. Cheers~
Feb 13, 2013 | ASUSTeK COMPUTER Asus P8p67 Pro Rev 3.1...
Tip
Speed up your browsing of Windows 2000 & XP machines.
Here's a great tip to speed up your browsing of Windows XP machines. Its actually a fix to a bug installed as default in Windows 2000 that scans shared files for Scheduled Tasks. And it turns out that you can experience a delay as long as 30 seconds when you try to view shared files across a network because Windows 2000 is using the extra time to search the remote computer for any Scheduled Tasks. Note that though the fix is originally intended for only those affected, Windows 2000 users will experience that the actual browsing speed of both the Internet & Windows Explorers improve significantly after applying it since it doesn't search for Scheduled Tasks anymore. Here's how :
Open up the Registry and go to :
HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/Current Version/Explorer/RemoteComputer/NameSpace
Under that branch, select the key :
{D6277990-4C6A-11CF-8D87-00AA0060F5BF}
And delete it.
This is key that instructs Windows to search for Scheduled Tasks. If you like you may want to export the exact branch so that you can restore the key if necessary.
This fix is so effective that it doesn't require a reboot and you can almost immediately determine yourself how much it speeds up your browsing processes.
Thanks
Have a great day.
Bhautesh
on Feb 24, 2010 | Computers & Internet
Tip
Speed up viewing shared files across networks
Speed up viewing shared files across a network
Windows 2000 & XP machines delay as long as 30 seconds when you try to view shared files across a network because Windows is using the extra time to search the remote computer for any Scheduled Tasks. Here's how to prevent this remote search for Scheduled Tasks:
HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/CurrentVersion/Explorer/RemoteComputer/NameSpace
and delete it.
If you like you may want to export the exact branch so that you can restore the key if necessary. This fix is so effective that it doesn't require a reboot and you can almost immediately determine yourself how much it speeds up your browsing processes.
on Dec 01, 2009 | Computers & Internet
Schedule task
format ur pc....or go to run command then search .....
Feb 17, 2012 | WYSE V90L Thin Client 1GB Flash/1GB RAM,...
Vista Home....Automatic restore points are not being saved....I can manually enter them and they show up on the drop down table....I have both drives checked off to allow automatically creating restore...
Hi g502,
Here are some helpful tips that you may use on how to Change the Automatic System Restore Point Settings in Vista Task Scheduler.
By default System Restore is scheduled to create a restore point at 12 AM every day (Daily trigger) and at every system startup (At startup trigger) in Task Scheduler if any system changes were made from the last time it checked. This will show you how to change these schedule settings, or disable one or both triggers.
Warning:
System Restore will need to be turned on for this scheduled task to be able to run.
1. Open the Start Menu.
A) In the white line (Start Search) area, type taskschd.msc and press Enter.
B) Go to step 3.
OR
2. Open the Control Panel (Classic view).
A) Click on the Administrative Tools Icon.
B) Click on Task Scheduler.
3. Click on Continue in the UAC Prompt.
4. In the left pane click on the triangle next to Task Scheduler Library, Microsoft, and Windows to expand the folder tree. (See screenshot below step 5)
5. Click on the SystemRestore folder.
A) Choose a option or options below to do.
OPTION ONE
To Disable or Enable this Task Completely
6. To Disable this Task Completely -
NOTE: This will disable both the Daily (OPTION TWO) and At startup (OPTION THREE) triggers regardless of how they are set individually. You will not have anymore automatic restore points created with this task disabled. You can still manually create a restore point though. For how, see: How to Create a System Restore Point in Vista
A) In the middle pane, right click on the SR task and click on Disable. (See screenshot below step 5)
B) Go to step 22.
7. To Enable this Task Completely -
NOTE: Check to make sure that each Daily (step 12 in OPTION TWO) and At startup (step 17 in OPTION THREE) trigger is also set as Enabled.
A) In the middle pane, right click on the SR task and click on Enable. (See screenshot below step 5)
B) Continue to OPTION TWO.
OPTION TWO
To Change Only the Daily Trigger Settings
NOTE: You will need to have the task enabled in step 7 to use this trigger. This is the trigger that creates a restore point at 12 AM every day by default. If you do not want to change these settings, then continue to OPTION THREE.
8. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)
9. Click on the Triggers tab. (See screenshot below step 10)
10. Click on the Daily trigger to highlight it and click on the Edit button.
NOTE: These are the default settings for the Daily trigger in the screenshot below.
11. To Disable the Daily Trigger -
NOTE: This is if you only wanted to have restore points create with the At startup (OPTION THREE) trigger instead.
A) Uncheck the Enabled box and click on OK. (See screenshot below step 12)
B) Continue to OPTION THREE.
12. To Enable the Daily Trigger -
A) Check the Enabled box. (See screenshot below)
B) If the default settings for the Daily trigger schedule are not what you want, then make any changes that you would like.
NOTE: For more details about each of these settings, see STEP FIVE here: How to Create a Task in Vista Task Scheduler
C) Click on OK.
D) Continue to OPTION THREE.
OPTION THREE
To Change Only the At startup Trigger Settings
NOTE: You will need to have the task enabled in step 7 to use this trigger. This is the trigger that creates a restore point at every system startup by default. If you do not want to change these settings, then continue to OPTION FOUR.
13. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)
14. Click on the Triggers tab. (See screenshot below step 15)
15. Click on the At startup trigger to highlight it and click on the Edit button.
NOTE: These are the default settings for the At startup trigger in the screenshot below.
16. To Disable the At startup Trigger -
NOTE: This is if you only wanted to have restore points create with the Daily (OPTION TWO) trigger instead.
A) Uncheck the Enabled box and click on OK. (See screenshot below step 17)
17. To Enable the At startup Trigger -
B) To Speed Up Startup Time - Make sure that under Advanced Settings, the Delay task for box is checked and you have an amount of minutes set that you want for System Restore to run after startup.
C) If the default advanced settings for the At startup trigger schedule are not what you want, then make any changes that you would like.
D) Click on OK.
E) Continue to OPTION FOUR.
OPTION FOUR
To Change the Conditions for the Task
NOTE: You will need to have the task enabled in step 7 first. This will effect how both the Daily (OPTION TWO) and At startup (OPTION THREE) triggers run. If you do not want to change these settings, then continue to OPTION FIVE.
18. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)
A) Click on the Conditions tab. (See screenshot below)
NOTE: These are the default settings for the Conditions tab in the screenshot below.
B) Make any changes you would like.
NOTE: For more details about each of these settings, see STEP SEVEN here: How to Create a Task in Vista Task Scheduler
C) Continue to OPTION FIVE.
OPTION FIVE
To Change the Settings for the Task
NOTE: You will need to have the task enabled in step 7 first. This will effect how both the Daily (OPTION TWO) and At startup (OPTION THREE) triggers run. If you do not want to change these settings, then continue to OPTION SIX.
19. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)
A) Click on the Settings tab. (See screenshot below)
NOTE: These are the default settings for the Settings tab in the screenshot below.
NOTE: For more details about each of these settings, see STEP EIGHT here: How to Create a Task in Vista Task Scheduler
C) Continue to OPTION SIX.
OPTION SIX
To See the Task History
NOTE: This will show you what the run and error history for this task is. This can be handy to help troubleshoot any problems with the task, or you just want to see when it ran. If you do not want to see the history, then go to step 21.
20. In the middle pane, right click on the SR task and click Properties. (See screenshot below step 5)
NOTE: You can also just click on the History tab in the bottom half of the middle pane instead.
A) Click on the History tab. (See screenshot below)
NOTE: In the bottom pane you can get more details about a selected history event listed in the top pane.
B) Go to step 21.
21. Click on OK. (See screenshots from below either steps 10, 15, 18B, or 19B)
22. Close Task Scheduler.
Hope it helps
Thank you for using FixYa.
Aug 31, 2011 | Computers & Internet
Tip
and delete it.
on Mar 15, 2009 | Microsoft Windows Vista Ultimate Edition
Printer not printing.
Follow these steps to resolve the issue. Windows XP
  1. On the Windows taskbar, click Start, and then click All Programs.
  2. Click Accessories, and then click System Tools.
  3. Click Scheduled Tasks. The Scheduled Tasks window opens.
  4. Under Name, click and delete any task that starts with Webreg (for example, Webreg 20031218075500).
  5. Close the Scheduled Tasks window.
Windows Vista
  1. On the Windows taskbar, click the Windows icon (c01319360.gif).
  2. Right-click Computer, and then click Manage. The Computer Management window opens.
  3. In the left pane, click the arrow next to Task Scheduler, and then click Task Scheduler Library.
  4. Under Name, find and click any task that starts with Webreg (for example, Webreg 20031218075500).
  5. In the Actions pane, click Delete.
  6. In the Confirm delete dialog box, click Yes.
  7. Close the Computer Management window.
Windows 7
  6. In the Task Scheduler dialog box, click Yes.
Jul 19, 2010 | HP PSC 1510 All-In-One InkJet Printer
Windows 2003 Server Task Scheduler Exit Code (1)
Have you tried to use robocopy.exe instead of copy? Robocopy have a logging option and is a lot more powerful. It's available in Windows Server 2003 Resource Kit Tools.
May 26, 2009 | Microsoft Windows Server 2003 Enterprise...
the exit code of 1 or 0x1: Incorrect function called or unknown function called.
check your backupRBase.cmd file. one of the URL or function need to be modify.
Mar 04, 2009 | Microsoft Windows Server 2003 Enterprise...
How to schedule system shutdown in windows xp
Go to Start >> Run type CMD and click Ok
in the command window
just use the AT command:
AT 9:00 SHUTDOWN -f
the schedule service must be running while using the AT command.
But normally it word well
Dec 30, 2008 | Microsoft Windows XP Professional
Microsoft Office Outlook 2003 for PC Logo
56 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
