Question about Evga e-GeForce 6800 (128 MB) Graphic Card
Is the 350 watt power supply unit ok for EVGA Geforce 6800 graphics card ?
Can anyone tell me, is the 350 watt power supply unit OK for EVGA Geforce 6800 graphics card ?
  • AKM Asaduzzaman Mar 20, 2007
    Thanks Noggin. In fact I have many accessories in my item like, 1 CD Rom, 1 DVD rom, 1 CD writer, 1 SCSI card, 1 Sound card, 1 agp card, 3 USB device, 1 Casing fan, 1 processor fan etc. This is 3 ghz processor. I have 1 GB dual channel ram. The other agp card which has a fan, it runs fine in this computer. So, now can u tell is the power supply is ok or not ?
    Sorry, I forgot to tell you one thing, I have also a 1394 card for transferring video from a digital video camera.
  • 944 Answers
The big issue with a power supply unit rating is the total peak load that it has to deal with, which you calculate by adding all the rated loads of all the parts of your pc that are connected to it, and add yourself an extra 20% for luck. The motherboard, the HDD, the fans, the drives, USB devices, modem, and many more. If you have enough wattage left to accomodate your graphics card then it should be fine. If in doubt, for the cost it is always better to upgrade your power supply to a larger rated one, rather than overloading a smaller supply or causing low voltage problems with all your peripherals. Here is the link for your graphics card manual if you need it; http://www.evga.com/support/manuals/EVGA_GraphicsManual.pdf Check page 5 reference the supplemental power adaptor, and check your power supply has an connector for it. If you want to identify the power consumption ratings for each part of your pc, most will be written on the component somewhere, some in the manual, and some you have to guess by checking similar items ratings online. If you want help with this please post again and we can certainly try. Looking at the card, my guess is that a system that can justify such a nice card is likely to be pushing a 350w supply already, I'm guessing what your system could be like and I would put a 600w or more supply in it as soon as i had the cash to do so. post back all the details of your machine and i can figure it out if u like. This link takes you to some other interesting info about your graphics card. http://www.evga.com/support/knowledgebase/ Mostly a power supply that cannot deal with the demand will inform you by shutting down or committing suicide, although occasionally other components can be damaged by poor power supply, the chance is minimal with many newer items, and it should be worth trying. The fan performance of a power supply often governs how well it can deal with long periods of high load - give it a proper clean, and remember to check always that it is running. if you want, you can install another fan on the outside (blowing the same way), but unless you power it from a different source then you don't really help much. Instead of getting a larger power supply, you can just get another (perhaps from an old pc) and only use it to power the graphics card - best left outside the case for overheating reasons. Hope this all helps :)
Posted on Mar 20, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 21, 2007
    From what you have said, without doing the research and the maths, I think 350w would do the job, but don't wait too long to get a bigger one. 350 will do most machines like yours, depending on the draw from the USB devices - also remember that with a smaller power supply, you can get away with it so long as you think about what is running and don't turn everything on at once - if you don't want to have to think about it either get a new powerpack or wait until it struggles or dies and hope nothing else suffers from it - if you keep a good eye on temperatures and noises then you may find 350 is fine for a while - remember though that graphics cards need a much cleaner power source than most of the more basic bits of a pc, so more is better as far as graphics performance is concerned, hence the second power connector on the card.
    Either way, good luck, but remember that if it worked before with no obvious problems, it is probably best to try it and see with what you have, but keep your eye on the power pack fan and any random shut-downs.
  • Nigel Ridehalgh
    p.s. I have a very similar setup, but with a 3.6 chip, and i have a 500w supply that sometimes struggles, especially when usb devices are plugged in and it's summer.
What is the minimum power supply required for this card?
  • Hello limkweenan, the "Minimum Power Suppy" requirements for the [XFX - 7 Series] is 350 Watts, the 'Minimum Power Supply" requirements for the "Newer" [XFX - AGP Series] is 1000 Watts. "I hope this information is helpful? Thanks for using FixYa, paul7of9"
Feb 04, 2011 | Pine Technology XFX GeForce 7600GT, (256...
What graphics cards can i use on this pc?
Hello
Although the system is not a new one to use PCI express card but you can use any AGP 8x Graphic card.
My recommended AGP 8x graphic card is eVGA e-GeForce 6800 GT/ultra 256 MB.
Hope this helps
Feb 02, 2011 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Where can i find graphics drivers for FX5200 128mb ddr 128bit+tv? how to change screen resolution? all things on decktop are very big.
Driver can be found here
http://www.nvidia.com/object/winxp_175.19_whql.html
To change the resolution right click on the screen , select Settings and move the resolution slider to the right, click Apply, click OK twice.
Jan 30, 2011 | Evga e-GeForce FX 5200 ,128MB/128 Bit DDR,...
I have Nvidia Geforce 9500 GT graphics card ...I recently bought my system...4 GB corsair ram....1 TB hard disk...400 W Cooler master PSU...Classic intel H55 motherboard...Still when play Gta or NFS hot...
How can I state this politely?
The Nvidia GeForce 9500GT is a definite step up from using Integrated Graphics.
No debate needed there.
But it only has 32 Stream Processors.
Think of Stream Processors as a 'Graphics Information Highway'.
They are essentially the lanes of the highway.
The more lanes you have, the more graphics information can be transferred from the graphics card to the Processor, and vice-versa.
Having 32 Stream Processors is like having a 'Bottleneck' in the road.
Equate that to a roadblock put up for road construction, where 8 lanes are dwindled down to 1 lane.
Traffic slows down.
This is seen when using intense games. Frame rates drop down, the game freezes, and graphics are poor unless on low settings. (Or not at all)
Here, take a look at Evga's version of the Nvidia GeForce 9500GT graphics card.
Read the Specifications at the bottom, watch the video.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4111742&CatId=3669
However!
A decent graphics card shouldn't 'Break the Bank'.
You don't need a $500 graphics card to slam those games.
You might want to look into an Nvidia GeForce GT 240 graphics card.
96 Stream Processors.
512MB of DDR5 graphics ram memory. (That's DDR5)
550MHz Core Clock
1340MegaHertz Shader Clock
3588MHz Memory Clock
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5516908&CatId=3669
Better than that?
Nvidia GeForce GTS 450 Superclocked.
1024MB of DDR5 graphics ram memory.
192 Stream Processors.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6655890&CatId=3669
For the above two graphics cards you need a decent power supply.
IF, the power supply you have DOES produce an honest maximum wattage of 400 Watts,
AND has at least 30 Amps on the 12 volt power rail. (Or 12 volt power rails), you're okay.
I would recommend an OCZ StealthXStream 2 / 600 Watt power supply though, when you can afford it.
It can produce over 700 watts if kept at a temperature of 48.4 degrees Celsius.
(119.12 degrees Fahrenheit )
Has FOUR 12 volt power rails that can supply up to 18 Amps EACH.
(Total of 72 Amps)
Has all the power cables you'll need, plus ones for the above graphics cards.
(Can handle them with NO sweat)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6491962&CatId=106
Not advertising for Tigerdirect. Just using them to show examples.
Regards,
joecoolvette
Nov 08, 2010 | Evga NVIDIA GeForce 9500GT,, PCI Express...
Which graphics card will be compatible with my mother board
please tell me what motherborard you have and how much you would like to spend. also what power supply you have, i will make a reccomendation then.
Jun 11, 2010 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Upgrading video card
Unless you are working with 3D models your gains in upgrading your VGA card is minimal as photoshop is knowns to be more dependent on the size of memory, speed of memory installed on your machines as well as the speed of the hard disk. The processing power of the CPU also can be an important factor than the graphic card.
However if you are set on going for a new graphic card, I would advise you that you get a new card such as the 8600GT or the ATI 3850 (Similar in price but faster than the 8600GT and 7600GT and uses the same or less amount of watts!, and also does not need a the 6pin connector for additional power).
Going back to your power issue, you have not stated your power supply's wattage or amperage, or if the power supply is generic or branded all which influence the decision to get a new power supply. However if you have a power supply that provides a true 300W you should be fine to run any of the cards stated above.
With regard to the bus issue, if you have a PCI-Express bus you should be fine in getting any of the new cards, but if you have AGP you will be more limited, though i know there are 7600GT (old stock) which are for the AGP slot, and only AMD (ATI) released there R2600 range for the AGP slot.
Hope the information is useful :)
Dec 12, 2007 | Evga e-GeForce 7800 GTX, (256 MB) Graphic...
Evga e-GeForce 6800 GS
okay well the same thing happened to me and no you dont need a new graphics card you need to do the following procedures 1:upgrade youre driver 2:install the latest detonator softwear for youre graphics card. and if this does not work then you need to buy a new graphics card or someone spilled a liquid on youre mother board and will have to be replaced also.
Oct 03, 2007 | Evga e-GeForce GeForce 7300GS, (256 MB)...
Is the 350 watt power supply ok for EVGA 6800 128 mb agp card ?
I would suggest at least a 400 watt power supply as the amount of peripherals you are running will soon take up the 350 watt supply, but go for a 500w as the price difference is negligable.
Mar 20, 2007 | Evga e-GeForce 6800 (128 MB) Graphic Card
Evga e-GeForce 6800 (128 MB) Graphic Card Logo
257 people viewed this question
Top Evga Computers & Internet Experts
 Ian Kayhan
Ian Kayhan
Mike
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
