Question about Intel Dot Station (INTC300AIO) PC Desktop
System display problem and i want to short onboard on/off connection without assemble pc
    Genius:
  • Intel Master
  • 1,274 Answers
No clue what you're asking here, you want to short 2 pins via jumper? how will that fix your display? please explain further
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Posted on Aug 02, 2012
SOURCE:
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Have Leadtek PX9800 GX2 on a Tyan S5397 Windows XP Pro X64. Not found at boot (long beep followed by two short)- no POST video from card or MB port, but operates when Windows boots. It appears OK in...
I think the video card is doing some conflicting on your system, so if you have a spare video card that you can try that will be better.
Hope that helps........
Jul 19, 2008 | Computers & Internet
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
No display
Your system is not receiving the POST signal from your motherboard. Make sure you have connected the display cable either to your onboard graphics or your graphics card.
If you previously had your VGA cable connected to a graphics card, remove the card and plug into your onboard graphics. Then power up and see if you get signal.
If you get signal after plugging into onboard graphics then this means that your graphics card has failed and you will need a new one.
If you still don't get signal then you will need to take your system to have it checked out by a qualified PC technition to see which components have failed.
Feb 14, 2011 | Intel D845GVSR Motherboard
Hey, my computer screen doesn't work when my computer starts ?
If you have hooked up the computer to another monitor and you still have no display, then your video might be bad. If you have display with another monitor, then you know your monitor is bad or the connection is bad. Be sure to check the connection, sometimes the video cable loosens and if that is the case you won't have any display.
I haven't looked up the "specs" on this system, but if you don't have any display with another known good monitor that works, you will have to determine if you have a video card or onboard video. If you need to replace the video, and have onboard, you need to have an open slot on the motherboard, there should be an open PCI or VGA slot available for a video card. In any case, if there is onboard video, you need to disable it in the setup after you install the new video card. Good luck hope this helps.
Feb 10, 2011 | Acer Aspire G600p PC Desktop
How to disable onboard display adapter without accessing BIOS?
Disable the motherboard device in the Device manager
Mar 27, 2010 | ASUS M2NPV-VM Motherboard
How do i disable the onboard video so i can install a video card
Depending on what type of computer you have there's several options but the easiest route would be this....
1) Turn your computer completely off and on.
2) When the computer is booting up look for "SETUP" or "ENTER SETUP" and press whatever key is required. (Doing this will take you into BIOS)
3) When you are in BIOS just look around for "Onboard Video:Enabled" and change it to "Disabled"
4) Save your settings and turn your computer off.
5) Install new video card.
If you have any other questions feel free to ask.
Dec 30, 2009 | Compaq Evo D310v PC Desktop
Vga
try to connect PC speaker and listen his sounds for diagnostics
  1. one short - system is good
  2. one long, three short - poor video card
  3. three ore more long - poor memory RAM module.
Mar 01, 2009 | Asrock P4VM8 Motherboard
M2a-vm mother board
Hi auriaskate,
Currently you are using the onboard PCI video adapter. This graphics adapter uses you're system memory to function.
If there is a problem with you're system memory the beeps can lead one to think there is a problem with the onboard video.
You can not remove the onboard adapter so there may be a problem with you're system memory. (I doupt you're memory is bad) but on the other hand it might not be fully installed correctely. Power off the PC & unplug the power cord from the PC.
Please remove you're system memory & firmly reseat it.
Plug the power cord back in. Start the PC & listen for any beeps except the 1 normal beep known as P.O.S.T = Power on self test. Any beeps after that there is a problem with a device connected to the board.
You're Asus M2A-VM uses an Award bios. Click on the link below to see what Award beeps mean.
http://www.bioscentral.com/beepcodes/awardbeep.htm
Try the memory reseat & check. Let me know if this helped.
Mike
May 03, 2008 | ASUS M2A-VM (0610839149438) Motherboard
Intel Dot Station (INTC300AIO) PC Desktop Logo
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
