Question about HP PSC 1315 All-In-One InkJet Printer
I attempt to print, but it will not print. When clicking on the printer icon, it is telling me there is a paper jam
  • Anonymous Dec 21, 2008
    My printer will not print either. I click print on the program I am using at the moment, and it will not do anything. No cables are unplugged, and for a while it had worked correctly. I moved it and then it had quit. It prints the sheet that comes out when it starts up, but afterwards it won't do anything. It scans and copies fine.
  • 69 Answers
Have you gone to HP and downloaded the full software package which includes the HP solution center. then click on the help and support tab? Steve
Posted on Dec 19, 2008
Paper gets stuck in Epson S/C 900. Laptop XP reinstalled. I will pay the $30 if you can get it to work. Drivers installed by Epson. Cisco says it isnt them. Dell too. Printer on for a year but not used....
inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.)
Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers
If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper
you can also you a light blower or vaccum to clean the printer be sure to remove the ink catridge from the printer before using them
after doing so click the printer icon in the task bar and click open it and delete all the files in them
then click start settings click printer and faxes then make your printer default then switch of the printer and the computer remove the power plug and the usb cable wait for few minutes and replug them then restart your computer and the printer then click start setting printer and right click the printer and click properties in the printer properties click the print a test page and your printer will be ready to print
Apr 20, 2011 | Epson Office Equipment & Supplies
I CAN HEAR THE PRINTER WORKING, IT DOES NOT TELL ME THERE IS ANY PROBLEM, LIKE PAPER JAM OR ANYTHING, I DOWNLOADED VERSION FOR WINDOWS THE PAPER DOES NOT GO THROUGH
Hi
If you downloaded and install the new windows operating system or upgrad your OS, your printer driver will not work as it is just configure to the old operating system. You need to reinstall the printer driver and set it up again.
Post comment if you need more help. Regards
Apr 01, 2011 | Canon Office Equipment & Supplies
My HP Laser jet P1006 will not print. when I click printer and faxes on my computer it is showing me that I have a paper jam. I have checked the printer and this is not the case. The computer has allowed...
1) open printers and faxes.... right click on the printer icon... click on pause printing... and then click on cancel documents.... when that is cleared... right click and delet the printer icon while u have the usb cable unplugged... once that is gone... plug in the usb cable... wait for few seconds and then try to print....
2) if u are not able to delete the printer icon by following the above step... click on start and then run... type in services.msc and hit ok.... in the services window stop the service called print spooler and then start it again.... and then follow the step 1... it should get deleted
3) even after completing the step 1 and when u try printing... if u r getting paper jam error message then thoroughly look for any jammed paper... even a small piece of paper will cause this problem... so check out thoroughly... and if u dont find any... reset the printer by following the below link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01174212&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=3435684&lang=en
you can also go through the following document
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01179923&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3435684
Mar 18, 2011 | HP LASERJET P1006 Printer
Has paper jam on printer selection, I kept hitting print before I figured it out. I am wanting to cxl all print jobs in the memory, or the ones waitung to be printed there is like 15 of them
if you have paper jam message remove the paper carefully and check the printer for tiny piece of paper you can also use a vacuum which having low pressure to flush out the tiny paper then go to printer icon in the task bar and click it open and delete all the contents in it remove the usb cord and the power plug to printer and wait for some time and plug them in then click start settings printer and click open the printer and make your printer default then right click the printer and click print a test page
Mar 01, 2011 | HP Officejet 5610 All-In-One InkJet...
HP 1610 printer photo paper jams
Right click on default printer icon select printing prefrences,click on advanced tab,select the size.or
Click on start menu then click on control panel.
Click on classic view on the left pane.
Double click on printers and faxes from the top toolbar.
Click on add a local printer.
Select the USB 001 virtual printer port from the “Use existing port” and click on next.
Select the manufacturer as HP and printer as Deskjet 990c and click on next.
We are using the generic driver for HP printers.
Use the default name for the printer, or you can change to your printer name and click on next.
Select yes to print a test page and click on next.
Select yes to set as default and click on next.
Select no to “do not share” and click on finish.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
The computer icon is trying to tell you something, all you have to do is right click the icon and open it up or double left click it. Either way the software driver will usually tell you what is causing the problem.
The 4 most common problems are;
1. A paper Jam is present.
2. The ink /toner cartridge is missing or empty.
3. A cover is not closed all the way
4. No paper is in the input paper tray.
Good Luck!
Rich Lilja
Dec 12, 2008 | HP LaserJet 1320 Printer
Load mpf paper
Your printer is set to default to the Main Paper Feeder, which is probably set for letter size paper. You must tell it to feed cards. On your Windows Desktop, left click mouse on START. left click on CONTROL PANEL, and left click on the PRINTERS icon. On the PRINTERS screen, RIGHT CLICK on your Dell printer icon. On the drop down menu, left click on PRINTING PREFERENCES. On the PRINTING PREFERENCES window, left click on the PAPER/QUALITY tab. Under TRAY SELECTION, choose the PAPER SOURCE where you want your business cards to feed from. Left click on APPLY button. Next, left click on the ADVANCED button. On the ADVANCED OPTIONS window, use the drop-down box next to PAPER SIZE to choose the paper size you want to feed. Press OK button. The PRINTING PREFERENCES window will now reappear. Left click APPLY, then OK buttons. After you have printed your cards, be sure to restore the printer defaults back to their original state, or the printer may jam because it must be programmed for the paper size being used. If you reload letter paper without resetting the paper size, the printer will think there is still card sized paper in the tray, and it will issue a jam or error code until the paper size is set properly.
Jul 30, 2008 | Dell 3100cn Laser Printer
Phaser 860 Printer posting a paper jam at start up.
Sounds like printhead needs replacement.
Moving these printers without cool down is known to destroy printheads and of course wax goes everywhere and then everything else fails.Think about replacement
Jul 02, 2008 | Xerox Phaser 8400 Laser Printer
HP PSC 1315 All-In-One InkJet Printer Logo
18 people viewed this question
Ben Johnson
