Question about Inter-Tel 660.7800 Corded Phone
I cannot pick up the rollover lines when my Premier phone rings
I have restricted access to incoming calls. I believe that this is a 660.7800 phone (from 15 years ago).
The main line picks up, just not the rollover ones. However, I can place an outgoing call on all 4 lines.
  • 19,396 Answers
If you need to reset the phone and cancel the settings , all you have to do is unplugging the power cord for ten minuts, it should reset to fatory.
Posted on Dec 16, 2008
My Norstar Phone Won't Let Me Pick Up Incoming Calls
Make sure they are Line Buttons, do FEATURE * 0 then press buttons to see what they are/do
Or maybe the key pad inside has failed.
Mar 04, 2013 | NorStar Lands Phones
My M7310 won't forward a call to the next open line but gives a busy signal
Hard to answer because your problem description does not match the part.
Nortel Meridian M7208 Corded Phone is a digital phone which works off a phone system.Also note that the carrier controls the rollover, not the phone or its system.
Once you have more/proper details maybe you can be helped.
Dec 14, 2012 | Nortel Meridian M7208 Corded Phone
Dell 2135CN cuts-off incoming calls to my home phone number after 2 rings and the call goes to the printer. I hear the ringer inside printer, then hear fax tones, even though the call is not a fax. My...
Hi and welcome to FixYa!
Well if that's the case, the printer should be detached or powered of during call operations. The printer detects incoming calls that's why it triggers it to operate. Turning it off during operation will surely be the solution.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 05, 2011 | Computers & Internet
Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
Aug 04, 2010 | Panasonic KX-T7420 Corded Phone
No ringing sound for second incoming call
On the intercom, if it's a TA or similar phone system, dial 7311# for call waiting on outside lines and 7321# for call waiting on the intercom. (0 cancels).
Carl
May 21, 2009 | Panasonic KX-TS3282W Corded Phone
Receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Aug 26, 2008 | Avaya Corded Phone avaparp18d
Need to reverse line 1 and 2 so that line 1 is the primary number
you could swap at the demarc(where telco responsibility ends) usually a box with screw down lugs one side marked customer the other marked phone co.
Jul 24, 2008 | GE 29439GE2 Corded Phone
Answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
Mar 28, 2008 | Uniden Cordless Phone
Programming a phone to pick up calls
I need more information. When calls come in, does the triangles appear on the phones you want to pick up? Do you have all the lines on the phones? Is sounds like you want only the "ringing sound" to happen on your phone, but have it appear on the others. Is this correct??
Dec 14, 2006 | NorStar M7310 Corded Phone
Inter-Tel 660.7800 Corded Phone Logo
65 people viewed this question
Top Inter-Tel Lands Phones Experts
David Burbee
David Burbee
ray gallant
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
