Question about Soleus HGW-308 Mid-Size Heater
I have not been able to find an explaination of error code E4. The remote and the keyboard will not override the flashing e4 and the heater fails to operate. The heater did work when I turned it on the first time. Ran it about 3 minutes just to make sure it was ok. Next time I turned it on the E4 flashing started.
Thanks for the help.
SOURCE: No heat generated by Soleus HGW-308 Mid-Size Heater
If you can hear a "click" when you turn the temperature knob, and the unit is plugged in, chances are the heating has failed.
If you have a multimeter, unplug the unit from the wall.
Put the meter on R x 1000 ohms, and put the meter probes on each of the plug blades. Rotate the temperature control through it's range. You should have just a few ohms when the control has clicked (you really don't care at this point), as you turn the temperature control to a hotter temperature. You should have no ohms when turning the other way (this all assumes you are in a typical room temperature environment.).
If no reading is obtained, either the element has failed, the temperature control has failed, the "tip-over" switch has failed, there is a burned terminal in the wiring, or sometimes a heat fuse fails.
If it's the element or temperature control, it's probably best just to buy a new heater. The other three are identify and replace.
Posted on Jan 19, 2009
SOURCE: On soleus ky-32u air conditioner,
The water tank is full the solution is to Empty the water tank.
The water tank is not installed correctly.Just install it correctly.Completely re-insert the water tank again
See page no 14 in the manual.
click here to download the manual.
post a comment for further assistance.
Thank you for using
fixya have a nice day:-)
Posted on Sep 25, 2010
May 26, 2014 | Soleus LX-140 Portable Air Conditioner
Oct 18, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
Jan 23, 2013 | Office Equipment & Supplies
Jan 15, 2011 | Soleus MA-9000AH Air Conditioner
Oct 23, 2010 | Soleus MA-9000AH Air Conditioner
Jul 15, 2010 | Soleus LX-140 Portable Air Conditioner
Jul 06, 2010 | Soleus PH310R03DB Portable Air Conditioner
Jan 19, 2009 | Soleus HGW-308 Mid-Size Heater
Nov 30, 2008 | Soleus HGW-308 Mid-Size Heater
Mar 30, 2007 | Soleus MobilAir MA9000 Air Conditioner
Apr 21, 2018 | LG Heating & Cooling
146 people viewed this question
