Question about Mitsubishi WS-65807 65" Rear Projection Television
Mitsubishi WS-65807 convergance issue, intermitant
My tv sometimes works PERFECT and if you give it a small BANG, it works. I sometimes get a smaller screen with yellow bands on both sides of the picture. ANY idea of whats going on. I LOVE this tv and want to get it done, Id like to try to fix on my own if its a simple fix... thanks...MJ
  • 301 Answers
SOURCE: Mitsubishi WS-65807 and blue-ray compatibility
that tv set is only good enough to receive a 1080i signal at the DTV INPUT. unless you can change the output of the blue ray it will be outputting 1080p
Posted on Mar 29, 2008
scottyfixit
  • 186 Answers
SOURCE: mitsubishi ws-65807 no sound or picture
Something related to the video boards. Check all inputs first, then check ribbon cables to the video board. Be careful of high voltage if you open the cover.
Posted on Apr 25, 2008
yankeegurl
  • 121 Answers
SOURCE: mitsubishi ws-65807 v17 chassis
go to this websight leave an e-mail with your model number and let them know you need a signal board and they should be able to help you plus there prices are very reasonable and they also offer free online tech support to their customers
http://servicemanuals.vstore.ca/
Posted on Apr 29, 2008
Relmdrifter
  • 6 Answers
SOURCE: Mitsubishi WS-65807 blinks '22'
I replaced the pico fuses and the convergence IC's. fuses poped right away code 22 . Further inspection of the board showed the coolant had leaked out of the center projector and fried the board. Not willing to pay $300. Passed it on to someone else
Posted on Nov 18, 2009
ladywinn
  • 5138 Answers
SOURCE: I have a WS-65807 Mitsubishi Big Screen HD TV and
No, you need to replace your convergence ICs STK392-570 Call Mats Electronics 1-800-628-1118
Posted on Dec 31, 2009
Picture curved horizontally at both ends of a Sony Trinitron TV
Just about any tube TV is a 4:3 picture shape and most current TV is 16:9. so there is a compromise to get them to work together. Unless you are viewing retro TV shows, you should adjust your Digital converter so that you have a black band top and bottom (yes you are giving up screen). The alternate is to keep 16:9 and give up left and right sides of the program. Or properly recycle the TV and buy a LCD screen. Even used, smaller ones can be had for 20 bucks. I bought a 32" for 30.
In case I have this wrong and this is a new screen problem, make sure there are no magnets anywhere your TV. They distort. Have you tried back adjustment screws? Use a mirror or have a friend help. Look especially for pincushion adjustment.
Mar 08, 2018 | Sony Televison & Video
WHY DID MY VIORE SCREEN RESIZE TO SMALLER SCREEN
Screen size depends on the broadcast signals aspect ratio, the TV adjusts for that automatically, the picture can have no bands or be banded top and bottom or on both sides.
Jan 07, 2017 | Viore Televison & Video
Mitsubishi ws-55515 intermitent blurry picture
A bad connection somewhere--when it happens if picture is 3d look in menu for convergence and call up the grid of lines--if they are not perfect you have convergence issue which usually requires parts to be replaced.
In this set sometimes the chips will become flaky and convergence will jump in and out.
May 05, 2012 | Televison & Video
How do I hook it up to a TV so that we can watch a movie on the TV instead of the small screen
On the side there is a video out socket ( sometimes marked AV out and yellow in color ). You will have to get an interconnecting cable to link it to your TV. The back of the TV will have corresponding yellow/red/white sockets. The yellow is for video and the red/white is for left/right audio. Your player comes with this cable along with the AC adapter . bobhifi_56.jpg
Aug 16, 2011 | Mintek MDP-1770 7 in. Portable DVD Player...
I have a Fisher Compact 5 cd changer Model DAC 197 . Manufactured in 1988. Are the small rubber drive belts available , if not, are there any that are inter changable?
I had the same problem. I took the cover off and tried to eject a tray and saw that the small rubber band was slipping. I simply got a smaller rubber band and replaced it. It works perfect now. It takes longer to unscrew the case than it does to fix the problem.
Dec 28, 2010 | Audio Players & Recorders
Faulty power supply
Hello.
There is no separate power supply in your TV.
It is integrated into Deflection Board.
I would recommend you have real professional diagnose your TV, power supply section is rarely goes bad, it could be convergence or some other issue.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WS-65807 65" Rear Projection...
My LG 42 Plasma works sometimes then half the screen goes black but the right side stays perfect???
have almost the same problem left side is black with sometime blue line red lines or a whole bunch of different lines some one help please have sound and right side of tv works fine
Sep 26, 2010 | LG 42PC3D 42 in. Plasma Television
Hitachi rear projection LCD with yellow blobs on screen
I have the same tv and the same problem, but my yellow is a cloud around the outside of the screen. My tv was recently moved, and a repair shop told me that sometimes in a move these tvs light engine takes a shock and causes a yellow "band" on the screen. I am hearing that these light engines are not cheap either. Hope this helps you.
Dec 01, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
