Question about Toshiba 43H71 43" Rear Projection Television
How to adjust red blue green
I have a service manual for 43h71 but can not totaly understand how to get blue red and green together to properly converge colors. Please help with proper way to do remote for proper alignment, Thanks
    President:
  • 1,284 Answers
One or both of the convergence IC's has probably failed and will need to be replaced. Check the circuitry around them as well for bad fusable resistors etc. The drive settings won't help on a convergence issue.
Posted on Mar 24, 2007
  • 49 Answers
If ur in service mode already..turn down all drive.green first turn it up until the desired intensity is achieve.then blue all the way until it almost blend the green.u must not see one color either too much green or blue.turn up red now,let it blend until u see a perfect black and white.note:make sure that the color level is set to minimum and tint to center. ihope i help u..
The tv has red images, I cannot get the red convergence line vertically to straighten, it is squiggly, the horizontal is straight, and the blue and green lines are both okay
the 43h71 has a pair of convergence ics that commonly go bad and cause this problem. replace original stk392-110 with stk392-120. the upgrades have a collector rated at 4 amps vs the 110's 3 amps and should be more reliable.
also know that they hyperboard in this set can cause squiggly lines throughout but will not affect the convergence.
Jul 06, 2010 | Toshiba 43H71 43" Rear Projection...
RED Convergence Alignment issue
Replace both STK392-110 Convergence IC's with Toshiba or Sanyo quality................No cheap IC's !!!......................T.
Aug 16, 2008 | Toshiba 43H71 43" Rear Projection...
CONVERGENCE PROBLEM IN TOSHIBA 43H70
Replace both STK392-110 convergence IC's with Toshiba or Sanyo brand........no cheap junk IC's !!!.................T.
Pcture problem
Sanyo brand...............no cheap junk !!.............T.
Aug 04, 2008 | Toshiba 43H71 43" Rear Projection...
My hitachi 50EX16B is messed up
green is not adjustable only through the service menu. if the green yoke hasnt been turned then you most likely have a faulty capacitor or resistor in the green convergence circuits causeing the green projectors image to be skewed. without the service manual and some tv repair troubleshooting skills you will probaly need to call a tv tech
Jan 21, 2008 | Televison & Video
Convergence
you can replace IC stk 392-110 (one or all) and tray to adjust R_G_B
Nov 25, 2007 | Toshiba 43H71 43" Rear Projection...
43H71 Toshiba
Change both IC's at same time is SOP ( standard operating
procedure) Note: Poor soldering from factory can lead to IC
failure, so, at the very least, hand solder all pins.....
Verify which is red chip by Service literature or follow red plug-in
traces to red IC.................................T.
Nov 23, 2007 | Toshiba 43H71 43" Rear Projection...
43H71 43 In Projector
Use Toshiba STK392-110T X 2 for exact replacement..........T.
Nov 21, 2007 | Toshiba 43H71 43" Rear Projection...
43H71 43 in
Look up and read about the convergence amplifiers on this website. I just helped a friend repair his 53H71. We replaced the STK392-110 IC's on the signal board. The shop quoted him $400 for the repair. We replaced them for $35. If you're not comfortable soldering then this might not be a good repair for you to try. Good luck.
Nov 18, 2007 | Toshiba 43H71 43" Rear Projection...
Green and red shadows
try adjusting the color purity knob.one by one,or if it is really bad tube u can extend it by rejuvinating it.
Mar 24, 2007 | Toshiba 43H71 43" Rear Projection...
Toshiba 43H71 43" Rear Projection Television Logo
147 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
