Question about Clarion ABD340MP AM/FM CD/MP3/cassette player
How do I adjust the Chime Level on an ADB340MP?
Now that the chimes are connected to my new ABD340MP, the door chimes are extremely loud. How can I lower the tone?
  • connie_slye Dec 18, 2008
    Now I know I can't make an adjustment via the radio buttons like I could with the factory radio. So, now I have to remove the dash cover and the newly installed radio to get to the chime box. Good to know for this vehicle as well as others so I can lower that annoying chime. Thanks.
  • 8,197 Answers
Pull off the front cover of chime unit and turn down the volum control knob
Posted on Dec 16, 2008
Where can i find Heath zenith SL-6273 manual or how do i make the product play mp3
Most Heath Zenith product manuals are available here: https://www.heath-zenith.com/support/owners-manuals . Searching for the SL-6273 found two versions of the wireless MP3 door chime. The direct link to the manual for the SL-6273-00 is https://www.heath-zenith.com/system/spree/documents/attachments/000/000/839/original/205371-02A.pdf?1436551434 .
Put the batteries in the door chime. To transfer an MP3 to the door chime, connect it to a computer with a USB cable. Open the folder to view files and drag the new (short, <= 20 seconds long) tune into the folder. Eject the door chime (like any USB hard drive) and remove the USB cable from the door chime.
Next press the Tune button to cycle through the tunes on the door chime for the front door chime. Stop when the desired tune is played. That will be played any time the front chime is pressed. If you add the jumper to pin 8, the door chime will ding as that is the rear rear door sound. For the front door, make sure that the switches (1-7) on the push button match those for the door chime.
I hope this helps.
Jun 02, 2017 | Heath Zenith Home Security
I want to turn off the alarm chime on 2016 1500 ram
door chime or headlight reminder chime ??? as im not in the knowing that the headlight chime can be shut off as for the door chime they can be tuned down by simply adding a few pieces of thick tape overtop of chime under dash (I know there loud)
Dec 16, 2016 | Dodge Ram 1500 Cars & Trucks
98 Ford Explorer. No chime sounds when keys left in ignition and driver door open. Also no chime that lights are on. Passenger door chimes when opened and key in ignition.
Bad door switch, or it may be dirty and "stuck" in the recessed position as it would be when the door is closed. I find WD-40 or equal is a good solution for this. Otherwise the switch's connections are bad (corrosion) or the switch itself is bad. More extreme is a break in the wiring to the switch and or connection near the fuse.
Mar 26, 2015 | 1998 Ford Explorer
Adjust the chim on a model ffw 5000qw drigidaire washer
Hey friend, thank you for your inquiry!
I see that you would like to adjust the chime on your Frigidaire washer. I researched the model number you provided, FFW5000QW but was unable to locate any information on it. Could you verify the model number for me please? You can locate your serial tag (which lists your model number) on the door frame of your washer with that information I can double-check to verify if the chime can be adjusted. -Matt
Sep 29, 2014 | Frigidaire Washing Machines
The chimes on my new jvc cd receiver are too loud
It's not the receiver, it's the interface. If you recently had this unit installed with a door chime or, some other type of LAN data interface to replace the door chimes, the adjustment is off. The interface/door chime needs to accessed to turn the volume down.
The interface is neccessary because when you remove the factory stereo from a newer GM vehicle you lose the door chimes, accessory 12 volt power source, ON Star, etc. The LAN data interface replaces these features when adding an aftermarket stereo.
Oct 15, 2012 | JVC Kda525
Chimes whenever the drivers door is open, even if the key is out. It is also really loud, want to turn the chime down also
My van chimes also with the key out. I think it is a reminder to lock the car as you leave. I don't see any way to reduce the volume.
Sep 07, 2012 | 2002 Buick Rendezvous
How do I disconnect the warning chime?
Key in ignition chime ?
Saturn L-Series ?????? L what ? L100 ,L200 , L300
Audible Warnings
The body control module (BCM) will provide an audible warning for various events relating to the vehicle. The functions that provide an audible warning are the key in ignition, the lights on, the occupant restraint (seat belt) and the park brake.
Key in the Ignition Audible Chime
The BCM will provide an audible chime if the key is left in the ignition in either OFF or the accessory position with the driver's door open. The chime rate for this is 150 chimes per minute. The key in the ignition chime has a higher priority than the lights on chime.
Lights on Audible Chime
The BCM will provide an audible chime if the park lights are on and the driver's door is open. In addition, 1 or 2 other conditions exist. The key is out of the ignition, or the key is in the ignition in the OFF position, and has not been turned. The BCM will chime at a rate of 200 chimes per minute until the conditions are removed.
Occupant Restraint Audible Chime
The BCM will provide an audible chime based on the class II message received from the SDM if the driver's seat belt is not buckled when the ignition is turned to run or crank. The chime rate for this feature is 50 chimes per minute.
Park Brake Audible Chime
The BCM will provide an audible chime for park brake when the park brake is applied and the vehicle speed is higher that 3 mph. The chime rate for this feature is 200 chimes per minute.
You can't disconnect anything . The problem has to be fixed .
Audible Warnings (Chime)
Chime Rate Per Minute
150
200
Occupant (Seat Belt) Restraint Audible Chime
50
200
Content Theft Pre-Alarm Audible Chime
200
Telltale Chimes
The body control module (BCM) will provide 4 chimes for each telltale activation per ignition cycle, at a rate of 150 or 200 chimes per minute. The chimes are limited to 1 chime event per telltale for each ignition cycle. The power up telltale function will not activate the telltale chime function. If the telltale becomes active during a cycle then the chime will sound.
The following telltales will activate the chime function:
• Low Washer Fluid
• Change Oil Soon Indicator
• Brake Fluid Low
• Oil Pressure Low
• Coolant Temperature Hot
• Low Coolant Level
• Low Fuel Level
• Antilock Brake System
• Volts Light (Generator)
• Supplemental Inflatable Restraint System (Air Bag)
• Trunk or Hatch Ajar
Having the vehicle checked for DTC'S - diagnostic trouble code's in the BCM would be the first step in the diagnostic procedure .
DTC B2965
When the ignition key is seated in the ignition switch, the key-in-ignition switch contacts the close, grounding circuit 80. The body control module (BCM) monitors the state of the key-in-ignition switch, the state of the ignition switch (OFF, ACC, or RUN) and the driver's door to control the key-in-ignition chime.
Nov 28, 2017 | 2002 Saturn L-Series
2007 Saturn Aura XE, the audible alarms can hardly be heard
Good news - they're adjustable. The radio is used to adjust the vehicle's chime level. To change the volume level of the chime, press and hold push-button 6 with the ignition on and the radio power off. The volume level will change from the normal level to loud, and LOUD will appear on the radio display. To change back to the default or normal setting, press and hold push-button 6 again. The volume level will change from the loud level to normal, and NORMAL will appear on the radio display.
Note: Each time the chime volume is changed, three chimes will sound to indicate the new volume selected.
Sep 07, 2010 | 2007 Saturn Aura XR Sedan
Battery was draining. Had to jump it with my Subaru.
do you have any subwoofers or a loud sound system in your car? sound to me like inner damage due to vibrations from extreme sounds?
Jun 14, 2009 | MTX Ford Explorer/Mercury...
Disarm door chime
According to my manual.
>Turn Chime Doors on:
1. System must be disarmed. Press Chime Doors button.
panel will announce,"Chimes On". Chime Doors button will be lit.
> Turn Chime Doors off:
1. Press Chime Doors button.
panel will announce, "Chime off". Chime Doors button no longer lit.
Sep 02, 2008 | GE Security Simon 3 Wireless Home Security...
Car Audio & Video Logo
120 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
