Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Whirlpool gold I have a whirlpool gold and the clean light keeps on blinking also wont work at all, can you help?
  • mikkee777 Dec 16, 2008
    thanks it worked have a Merry Christmas to you and your family.
    Problem Solver:
  • 9 Answers
First press your "Sani-rinse" button and the your "Heat Dry" button and toggle between them a couple times. This will reset your control module. If the clean light continues to blink then it means that your heating element needs replacing.  This is not a big job, either. You will need to order a new element and come back for instructions if you can't figure it out quickly....
Posted on Dec 16, 2008
Whirlpool gold gu180esjs. start light blinking won't go through cycle, keeps stopping. tried killing the power and restarting, filter is clean, no obstructions. no helpful info online for this model....
Remove the bottom kick plate. There you should find the Whirlpool factory technical data sheet. This sheet will guide you through the diagnostic process.
Mar 25, 2015 | Whirlpool Dishwashers
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Control clean light keeps blinking and dishwasher will not function
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Clean light wont stop blinking
This is a code that the water is not being heated. this could be caused by a bad heating element, lack of water, computer control problem or an inadvertant error. all things involved with heating the water need check. the computer has to be reset using a diagnotic mode. wiring info usually behind toe panel may help to solve the problem. please include model # if further info needed.
Mar 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Duet HT Blinking Lights at any cycle and won't work
get a repairman to look at them most likely the moters have either drawn moisture or stopped working period
Jun 22, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Dishwasher will not work
This usually means a couple of things there could be a heater problem, water valve , or pump problem.
Jan 11, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to...
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to keep restarting it. can anyone let us know what the problem may be. Thank you
Jul 17, 2008 | Whirlpool Dishwashers
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
1,222 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
