Question about Onkyo TX-SR503 Receiver
Distorted Front Right channel
Hi i Have a nice onkyo reciever and i need some tech help i cant figure what it is sound is distorted even in the headphone jack too its getting a clean input ie digatal it does it in all modes i havr traced it down to being in the output section either pre or main i want to know if you techs think its a cap causeing a mis match audio signal to the transisters going bad thanks for any help dan
  • dan dak Apr 26, 2007
    ok i need more help i was looking things over and hear a pop and seen smoke not good i know but now i have a 50v 47uf cap that vented and found the two driveing trans that drive the output trans are shorted the out put trans are checking good the a1930 and the c5171 are the two that shorted if i replace these will the fix my problem as i cant find anything ele blow or bad also may these trasn been weak and finally went thanks for any help oh yea where is a good place to order these from
    Genius:
  • 1,074 Answers
Check some caps in the aduio section alon with transistitors
Posted on Apr 04, 2007
My 787 receiver is 10 years old. It worked excellent all these years . It developed distorted sound in the front left channel. I swapped speakers and confirmed that the problem is with the receiver front...
The problem will be in the power amp for the the left channel. One you have identified this on the circuit board you can compare the channel with the right. As they are both the same. Start with a visual check. If anything looks odd compared with the the right replace it. Distortions are often caused by a burned resistor. Though the main power transistors or IC can cause it too. If you can't find anything visual I would replace the main output device(s) for the left channel.
Nov 21, 2017 | Audio Players & Recorders
Tv picture is distorted
If the picture is the only thing distorted meaning audio sounds good and clear. It would be the connects between ur tv and reciever.
Sep 13, 2010 | Onkyo TX-DS484 Receiver
Right channel sound is distorted
You most likely should remove the casing of your reciever and take a can of compressed air to clean it out start with that and also while you hvae it open look for any solder that looks messy or melted
May 24, 2010 | Audio Players & Recorders
My Harman Kardon AVR 220 reciever's front-right channel isn't working. I have switched the two front speakers and the right speaker works on the left channel so it is not a problem with the speakers or...
if front left is working it is possible u have a dry solder on ur right channel line. try resoldering or if u want to know exactly where dry solder is, shake gently every right channel components and connections. if resoldering does not work it is possible u have a faulty ouput amp for ur right channel. if ur not sure about this i suggest u get it checked by a qualified tech.
Apr 05, 2010 | Harman Kardon AVR 220 5.1 Channels...
Left front channel has stopped working
if you are sure you swapped speakers and its still the same, get a refund the unit is bad.
Charles
Dec 16, 2008 | Onkyo TX-SR606 Receiver
Distorted right channel
There is a problem in the pre-amp section of the receiver. This is most likely a bad transistor. FIgure on about $5-$15 for parts for this repair.
Dan
Sep 11, 2008 | Onkyo TX-SR600 Receiver
Center speaker
I had the exact same problem. In order to "almost" balance the center with the other channels I had to give the center +12db gain and the other channels -12db. So after I got that far with level calibration I tried some tv sound, well the center although was playing sounded like the highs were missing and a bit distorted. This is the good part, I turned the volume all the way up real fast, somewhere near max something fixed itself, the center became very loud. Now it works just like new. Hope this helps. BTW, the problem existed the same for sub channel, so when the center started working so did the sub.
Jan 08, 2008 | Onkyo TX-NR801 Receiver
Onkyo TX-28 Receiver Output Problem
You may be confusing +/- power supply rail fuses with left and right speaker fuses.
Sep 02, 2007 | Kenwood VR-305
Distorted sound on all right channel inputs
yep but if your not a tech you should take this easy repair to a pro. Your problem is an open emitter resitor and happens when the units over driven or a speaker is bad for a while while it was working. if your a tech then check all of the emmitter resistors. also it could be a bad output device. Good Luck
May 27, 2006 | Yamaha RX-V496 Receiver
Onkyo TX-SR503 Receiver Logo
111 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
