Question about Gateway M305CRV Notebook
Charging my laptop is plugged in, has the picture of the battery with the plug, but is not charging????
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
Problem sounds like the power pin ... where the AC cord connects to thecomputer. That particular component is very fragile. The part torepair it runs between $ 5-$15 but the labor to repair it will costanywhere from $ 100-$250. It can be repaired by you if you are verycareful taking the system apart. Just pay attention to every detail ofyour dis-assembly. I also recommend you get one of these to stop the problem from happening a 2nd time.
Posted on Dec 17, 2008
Laptop plugged in but not charging
Does the battery get hot when it is on the charger. Possibly a bad battery.
Sep 10, 2013 | Lenovo Computers & Internet
PLEASE HELP!! I am going on a business trip tomorrow and ALL of my requisite files are on my Dell Latitude D610 that won't power on. PROBLEM: once I removed it from my docking station at work, it won't...
When you say you "tried turning it on with the battery removed", did you leave it plugged into the wall with the charging adapter at the time? Please clarify that you tried to use it while plugged in without the battery and it would not power up? When you plugged it in without the battery, was the green charging light on? Or did you get no power light at all?
With your battery in, try using a different outlet to plug into. Plug it into another outlet and when the green charging light comes on press and hold your power button on your keyboard and do not release it for 30 to 45 seconds. Tell me if this boots up the pc even if just for a moment?
There are three lights on your keyboard that should come on when the laptop is plugged in and turned on. One is the power light, the other is the battery charging light and the last one is the hard drive indicator that looks like a round cylinder on the picture. Tell me when you plug it into the outlet and the battery charge light is on, does the hard drive light come on and/or flicker when you try to power up the laptop? How many lights come on when you press and hold down the power button with the cord plugged into the wall?
Jan 09, 2011 | Dell Latitude D610 Notebook
Hello, this is roger, my toshiba laptop showing battery filling sign for 5 second ,however , after 8 hours of charging battery capacity still showing 0% available . i have done solution with device...
Hi Roger,
There are a couple of problems that may be causing your laptop not to charge, the most likely are listed below.
1) Ensure that the battery icon in the bottom right hand corner has a picture of a plug next to it.
If this is not showing there is a problem with the connection between the charger and the laptop. This can be checked by "wiggling" the connector between the laptop and the charger to see if it shows the plug symbol in any position.
The charger can be ruled out as a problem by borrowing a friends charger if they have one to see if that works and to try your charger on their laptop.
2) Ensure that the battery icon in the bottom right hand corner does not have a picture of a red cross.
If this is showing it indicates a problem with the laptops battery and will need to be replaced in the near future. Unplugging and plugging the charger back in can sometimes remedy this but it is only a temporary solution.
3) If none of the above work it is also worth powering off the laptop completely and removing the battery overnight. Then trying to charge the battery the following morning. This can give the laptop time to "reset" itself and cool down.
It is most likely a problem with the battery as they tend to have a shorter lifespan than the chargers (unless the charger is physically damaged by cutting the cable)
Regards,
sjstore2
Dec 18, 2010 | Toshiba Satellite A205-S5823 Notebook
Battery of laptop not charging
If the laptop works when plugged in, the power supply is OK. The battery controller is probably the problem, which would mean replacing the battery.
Apr 17, 2010 | Computers & Internet
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
MEDION MD96640 - plugged in, not charging
There is a possibility that the battery is defective.
Turn the laptop off and remove the battery and AC power. Clean the brass contacts on the battery and the laptop.
Plug in AC power only, boot the laptop up without the battery and go into the BIOS and set the BIOS to default settings. Save the changes and let the laptop boot into Windows. Once in Windows power down the laptop again and remove the AC power.
Reinsert the battery and AC power and boot the laptop up. See if that has helped.
Good luck.
Sep 21, 2009 | Computers & Internet
I don't know how to charge my battery
Its ok. Um just leave the battery plugged into your laptop and the power cord plugged into the laptop as well and the laptop will charge it for you. If it won't, the battery is no good and get a new one but you don't need a external battery charger to charge your laptop battery.
Nov 21, 2008 | Dell Latitude D600 Notebook
Acer laptop power problem
Does not switch on from mains.?????????????
PLEASE EXPLAIN..........
Is the laptop lights not coming on when you plug it in? If not refer to the following.
Are you sure that your power plug has not broken loose. You will have to take the laptop apart to find this out. Sometimes the solder joint will come loose. Do not take this laptop apart unless you know what you are doing. The manual can give you step by step directions sometimes. It is not easy to take it apart without breaking the little things. If you do take it apart, take pictures of every step and take notes and even draw picture so you will know where everything goes. You can touch the plug where it is soldered and re-solder the plug. Please be careful. This takes someone with good solder skills to do.
May 30, 2008 | Acer TravelMate 2300 Notebook
Gateway M305CRV Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
