Question about Western Digital 500GB My Book Pro-External 500 GB Hard Drive
Hard drive will not power ON
My WD500GBPro has been working fine it seemed. Until it stopped running. It wouldnt power on. Tried several outlets. Tried a different power cord. NO lights. No action. The drive is still under warranty. WD said there was nothing more to do. Sent drive to third party approved data recovery company. Based on many conversations with them it seems the drive's power supply is bad. IS there a way to remove the drive from the casing, attach it to another power supply, move the data to a new drive, and be done with it? Is this something I can do on my own?
  • herrodjoseph Dec 16, 2008
    Thank you very much for the reply and the advice. Your experience is most helpful!!!
    Scholar:
  • 40 Answers
I have had my own experience with Western Digital and their policy is to not sell or provide parts in order to replace damaged parts in an otherwise functional device.
Your options would be to send it in to WD for a repair and strictly a repair. They may replace the power supply.
The other option is to buy a used/off-market case or power supply which matches your drive's supply.
I had a harddrive burn a hole through one of the interface chips on the bottom of the HD and was told there was no way I could get it repaired or recover the data as it was. However, I found an exact match for model and type of the drive and a near enough year to the one I had and exchanged the interface boards on the drive, and I'm using the drive today as my main boot disk.
All you need to do is replace the power supply. Try Ebay for your external drive model number, there may be cases with no drives which you could buy that have functioning power supplies, or power supplies alone.
If all else fails, you can do what I did - buy another, matching product, exchange the broken part from the new one you get with the old one, recover data, and swap the power supply back again, then send the old drive to WD for replacement. You can attempt to resell the RMA'd (returned to WD drive) on amazon/ebay and use the new one, or keep the new power supply in the old device and use it, and sell the drive out of the case, or keep the drive and use it. I expect the drive inside the external case should work as a normal drive.
Posted on Dec 16, 2008
Gears slipping
Smell the transmission fluid, if it smells burnt then you have clutches in the transmission slipping. Also check and see if there are any code for the powertrain.
Dec 10, 2013 | Goodyear 1987 BMW 325e Accessory Drive...
I dont know how to summarize the problem.
It sounds like the hard drive is bad. You might be able to run chkdsk (or whatevers its called; check disk) to scan/fix errors if possible.
A different issue but:
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 16, 2010 | Western Digital Passport WDXML800UE...
My seagate 500 gig free agent desk external drive has suddenly stopped working. It was working fine 2 days ago and then yesterday it apparently wasn't connected so I reconnected it and then it seemed to be...
Do a FULL POWER DOWN Reboot. and try a different USB outlet in the PC... same Laptop to see if it is in your PC that is causing the problem.
Note: Most of those Drives do stop unless they are connected to the PC... energy savings.
If that didnt work... you could have a failed drive. Seagate should help you do some diag if it is in warranty... typically 3 years.
Dec 31, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My external hard drive won't turn on
Ok, this just happened to me, my western digital my book studio external drive was not booting up, i could hear the disk spinning, but it would then cut out and the light on the drive was never turning on. i called Western Digital customer support and found out that the proper way to connect a drive is to plug in the power cable FIRST then the data cable. Also, with the My Book Studio Edition you should never have to press the power button, the drive just turns on when you plug it in. Hope this helps somebody...
Feb 18, 2009 | Western Digital 500GB My Book Pro-External...
Transfer case /fuse/software for transmission?
thawed it out the next morning-reset codes to standard-viola-all is well. seems ice found its way into switch@transfer case and ran the chips riot-sending tranny into limp mode. cold weather,rrrrrrrrrrrr. june can't come soon enough.
thanks anyway
Jan 29, 2009 | 2003 GMC Sierra
Power button problem
As you said, its 4 months old and assumed under warranty cover. Contact Sony Service Center for repair because if you try yourself, will void warranty.
Aug 15, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
2004 Malibu Maxx
we disconnected the battery to "reboot" the computer?? It worked...seems to be running fine but we are taking it in for the 90,000 mile tune up this week to make sure.
May 26, 2008 | 2004 Chevrolet Malibu Maxx
No power!!!
Do you hear any sound when you plug in ?? any light blinking?
Apr 07, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Open Questions:
See all Western Digital 500GB My Book Pro-External 500 GB Questions
Western Digital 500GB My Book Pro-External 500 GB Hard Drive Logo
295 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
