Question about Canon PC160 Black and White Copier
Personal copier problem
I have a Canon PC1 personal copier that actually hasn't been used much but was to my knowledge still in working order. I recently ordered a new toner cartridge for it and replaced it. I assumed it was working before I did this but since the cartridge was empty I didn't have a way to test it. Now that I have spent a fortune on the new toner it isn't copying. Everything appears to work correctly except the copy comes out blank. The original is face down so it is not that. When looking inside all appears to be ok, bnothing broken or loose. I have gone to the Canon site but they no longer have a manual for this product. It was I believe the very first personal copier they made. HELP!
  • Brandy Paterak Mar 21, 2007
    It does not make any fizzling sounds when it copies.
  • 163 Answers
The PC1 was many models (and years ago) for me but the basics haven't changed much. I'll try my best. First, was the original cartridge giving completely blank copies also, or just poor copy? If it was blank also, the unit may not be bad (empty) depending on age. Take the old unit and slide open the shutter that covers the length of the drum. The drum may be brown green or purple but white jagged lines coming in from the end are a good sign of determination on organic drums. If the copy went from poor to blank the transfer corona is an excellent place to look. When you open the machine and can see the paper path, the transfer is located directly below where the drum would come down. The transfer wire is very thin (60 micron) and would run from front to back, usually inside a silver 'tray'.
Posted on Mar 23, 2007
  • John Byse
    John Byse Mar 23, 2007
    In this scenario, the blank copy would be caused by a shorted wire. At either end of this silver tray look for black toner build up. Sometimes the end contacts are covered with plastic covers and can be removed. Gently clean these areas with canned air but be careful, this wire can break easily. Also inspect the ends for any burned/melted areas.
    Check copy. If it is still blank try this..
    1) Make another copy but turn the copier off about halfway through the scan.
    2) Open and gently remove paper
    3) Remove cartridge
    4) Open the drum shutter as I described before
    5) Check for any toner/image on the drum unit
    After that things can go many ways so let me know what you find out.
    mediaman85@mchsi.com
    New Friend:
    Problem Solver:
  • 19 Answers
Hi,,Could be the Transfer Corona unit that is shorting out through the end blocks.[High voltage unit] You get a fizzle sound most often when it is copying.. You can remove the unit and scrape the burnt track from the plastic end block. Dave,, Ulster,, Northern Ireland,,
Posted on Mar 20, 2007
How to reset anti theft system
KEYLESS ENTRY SYSTEM You can use the keyless entry keypad to:• lock or unlock the doors without using a key.• open the trunk.• recall memory seat/mirrors/steering column/adjustable pedals positions1 or 2. The keypad can be operated with the factory set 5-digit entry code; this code is located on the owner's wallet card in the glove box, is marked on the computer module, and is available from your authorized dealer. You can also create your own 5-digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation. Programming a personal entry code. To create your own personal entry code: 1. Enter the factory set code. 2. Within five seconds press the 1 • 2 on the keypad. Note: The lock motors will cycle, locked then unlocked 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other. 4. Enter a sixth digit to indicate which personality feature should be recalled by the personal code. Note: The lock motors will cycle, locked then unlocked. • 1 • 2 recalls driver personality 1. • 3 • 4 recalls driver personality 2. • 9 • 0 does not recall a driver personality. Wait 5 seconds without pressing a keypad button in order to store a personal entry code. Tips: • Do not set a code that uses five of the same number. • Do not use five numbers in sequential order. • The factory set code will work even if you have set your own personal code. • If you set a personal code and store it over an existing personal code it will erase that personal code only. Erasing personal code 1. Enter the factory set 5-digit code. 2. Press and hold the 1 • 2 for two seconds and release; this must be done within five seconds of completing step 1. 3. Press and hold the 1 • 2 for two seconds to erase the customer programmed code; this must be done within five seconds of completing step 2. Your personal code is now erased and only the factory set 5-digit code will work.
Feb 09, 2011 | 2002 Lincoln LS
Where i got the driver for canon PIXMA MP287 inkjet printer ??
http://support-sg.canon-asia.com/?personal
download here
i hope this helpfull, if you think this helpfull please rate very helpfull
thanks for using fixya
Jan 22, 2011 | Canon Office Equipment & Supplies
Printing with Black only mode is not working
There is an extensive support document for your question at Canon support: (copy and paste link into your browser)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=11642
Type question: "How do I print using only the black ink and not the other colors"
Read solution(s).
Dec 05, 2009 | Canon PIXMA iP1600 Printer
I need a technical manual for a Canon Copier PC720
Scroll Down put in the 4 digit code, click download
http://www.devicemanuals.com/guide/Copier/Canon/Canon-Personal-Copier-PC720-User-Guide-TkRBNU9UYz.html
Oct 20, 2009 | Canon PC150 Personal Copier (PC 150,...
Canon Imagerunners 2270 and inbound email.
i know that "Mailbox" on Canon copiers is used just for storage personal scans and modify.
You can try to send an email to canon address, see what happened.
For your question, i don't know  it is possible. In this case Canon copier should be an email server.
Oct 04, 2009 | Canon imageRUNNER 2270 Copier
Need cd and user manual for canon Ir 2270 copier/printer
the cd is not needed goto canon and download driver for printing. as for manuals if you dont have them only an authorized tech can get the actual manuals do to canon putting them on the tech site. but you can find websites that will charge you and you can get a manual
Apr 03, 2009 | Canon Office Equipment & Supplies
I'm suddenly getting uniform black lines on copies when using my canon pc 425 monochrome personal copier
remove toner cartridge, and look at the drum (on the bottom of cartridge). If there are toner streaks on it, it is failing and needs to be replaced.
*please rate me :)
Mar 26, 2009 | Canon PC-425 Color Copier
New router no printing
ann..that's a tall order...it will require some intervention, actually, from a knowledgable tech person..
Apr 25, 2008 | HP Deskjet 6980 InkJet Photo Printer
Canon PC1 personal Copier -- Printing
when you making copy if the lite comes on. than you dont need any bulb. if not you need it
Jan 28, 2008 | Office Equipment & Supplies
Canon PC160 Black and White Copier Logo
94 people viewed this question
Clive
Clive
old marine
old marine
