Question about Abit KV-85 V2.0 (KV85VERSION20) Motherboard
After loading screen of windows appears the screen goes black
I recently changed my processor from a sempron 3100 to an athlon 64 3200 and also changed my graphics card from an agp ati radeon 9550 to an agp ati radeon X1650 . Both of these worked for a couple of days, then when i tryed to power up my computer for the first time one day, it shut down after a second of being on, and the second time i turned it on, it started up normally, except it didnt show the log in screen after the loading windows xp home edition screen was done, it was only a black screen. when i shut the computer down, and started it back up, a screen appeared to change the settings back to the best known working settings, so i tryed and it still wouldnt show the loading screen, i tryed loading it normally several times, but it hasnt changed. i have checked the connections from the power supply, and they all are connected, i dont know if the problem is with my power supply, it is 480 watts or my motherboard, an abit kv-85, or my graphics card, because the graphics card had worked for a couple of days before.
  • Howard Lester May 11, 2010
    Take the 1650 out and set it back to the onboard graphics and see if it comes back. Post what it does and I will try to help you out.
3 Suggested Answers
  • 6 Answers
SOURCE: Power On trouble with Computer
If don't you have any beeps check maybe the power button stack.
If the power button pressed for four seconds then the computer normaly shut down.
Posted on Jan 11, 2008
enuro12
  • 116 Answers
SOURCE: changing processor results in windows xp pro failing to install
Sounds like the 1000mhz processor either overheated at some point and was damaged, or its trying to run on a different bus speed.
Copy errors (random) normally point to bad ram. But being that it works fine with the other CPU, you can only have 2 possible problems :)
A bios upgrade may fix the bus issue, and a hammer will fix the damaged cpu issue. (Ok, so you'll feel better)
Posted on Feb 26, 2009
Wanted to know what year it wasand if anygood?
Made in mid-year of 2005.
Any good?
Depends on what you wish a computer to do.
ONE:
The AMD Sempron line of Processors, are a Budget line of Processors.
Equate to comparing an Intel Celeron to an Intel Pentium.
(Celeron's are Budget/Starter processors)
[ The 'Sempy', and the 'Celey' have half of the Cache, that a comparable Athlon, or Pentium has.
(Cache for a Processor, is the first memory area that the Processor accesses.
The Cache operates at the same frequency rate as the Processor.
Cache for a Processor is a small memory area for the Processor)
Crude explanation of a Processor's cache;
You are writing a paper for college. You need more information for it.
Where is the information?
In a book, down in the basement, under the stairs, last book on the bottom in a box, and there is no basement light.
Down the stairs you go, flashlight in hand. Dig the book out, back up the stairs, open the book to the page you need.
You find you need more information, but it isn't in that book.
Yep, back down the stairs you go, flashlight in hand.
OR,
You could click a couple of keys on the keyboard in front of you, and have the information in seconds on your computer.
Basement scenario = Small processor cache
Computer scenario = Large processor cache ]
AMD Sempron:
http://en.wikipedia.org/wiki/AMD_Sempron
List of AMD Sempron microprocessors,
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors
2) HP Support > Compaq Presario SR1403WM desktop computer > Main Menu,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00257657&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=501310&lang=en
Note the supported Processors.
Note the processor socket type used; Socket 754.
Note the maximum Total amount of ram memory.
(2GB's of PC3200 ram memory will get you by just fine.
PC3200 is DDR Sdram at 400MegaHertz.
{400MHz)
Me?
Again, depends on what you wish to do with the computer.
The AMD Sempron 3000+ processor, (That uses a Socket 754 processor socket), can operate at a maximum frequency rate, ('Speed') of 1.8GigaHertz.
(1800MegaHertz)
I would try to find an Athlon 64 that uses a Socket 754 processor socket.
Here is one example I just found from searching, (Not advertising for this person, or website. Just an example of what to look for)
http://cgi.ebay.com/AMD-Athlon-64-3200-Socket-754-CPU-BRAND-NEW-/320559466147?pt=CPUs
AMD Athlon 64 3200+ (Socket 754)
Can operate up to a frequency rate of 2.2GHz
Has an L1 cache of 64KB, and an L2 cache of 512KiloByte's.
http://www.cpu-world.com/CPUs/K8/AMD-Athlon%2064%203200+%20-%20ADA3200AIO4BX%20%28ADA3200BXBOX%29.html
(In comparison, the AMD Sempron 3000+ can operate up to a frequency rate of 1.8GHz.
Has an L1 cache of 64KB, and an L2 cache of 128KB.
http://www.cpu-world.com/CPUs/K8/AMD-Sempron%203000%2B%20-%20SDA3000AIP2AX.html
Bump the Processor up, max out the Ram Memory, (2GB), install a decent PCI graphics card, and you'll be okay for basic internet, and watching a few movies. Even game playing if the game isn't too intense.
(War of Worlds at low settings, mmm okay
CS:S? Mmmmm, no)
Around my area, the computer tower by itself would sell for around $100 USD. With monitor, (Depending on type), keyboard, and optical mouse, (Throw the roller mouse in the trash), the price goes up.
Refurbished?
1) Generally means the inside of the computer, and the inside of the Power Supply, has been cleaned out. (May be a new cheap quality generic Power Supply installed instead)
2) Thermal paste in-between the top of the Processor's case, and the bottom of the Heatsink, has been replaced. (Better be)
3) New Harddrive, with a fresh GENUINE copy of Windows installed.
This bumps the price up. Especially if Windows 7 has now been installed.
[Microsoft makes one master disk of an Operating System. Then GENUINE copies are made from it, and sold]
Look up the price of an IDE (PATA) harddrive, with the appropriate size. (150GB, 250GB, and so on)
Then find out which version of Windows 7 has been installed, and look up that price. Or whatever Windows operating system has been installed.
Add these two prices to a base price of $100 to $150, and see how the price compares to what is being offered to you.
Aug 08, 2010 | Compaq Presario sr1403wm AMD Sempron 3000+...
I am using amd sempron LE-1100 i want to upgrade to a gaming pc so that i can play the sims3. so if i like to upgrade to amd athlon x2 how to know my socket type. please help
Your socket is AM2. You can put any AMD processor that has AM2. If the processor is AM3 just upgrade the bios of your motherboard and it should work. If you need further assistance, just leave a comment. Cheers
May 24, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Which is better processor between amd athelon ,sempron, turion 64
Hello rakeshmedita,
The Turion is more of a mobile processor meant for laptops since it uses less power while the athlon is for desktops and uses a bit more power. The Turion might edge out the Athlon on performance but will beat the pants off it in power consumption. The sempron is a low-cost processor meant for entry level desktops. So, to answer your question it goes Turion, Athlon, Sempron.
Hope this helps, if so please leave some positive feedback. Thanks.
Feb 16, 2010 | Dell Laptop InspironTM 1501 PC Notebook
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Dec 22, 2009 | HP Compaq Presario SR1920NX PC Desktop
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
Fast processor's speed
Your motherboard accepts Socket AM2 for AMD Athlon™ 64FX / 64X2 / 64 and Sempron processors
The board has safe overclocking - so unless you know what you're doing I would stay away from changing any settings manually or you could fry the mobo.
How much memory do you have - more memory can increase speed. Faster HDD
If you want you could go for the Athlon 64,
The Sempron only goes to 2.31 so there wouldn't be much difference in speed.
Apr 25, 2009 | Computers & Internet
Maldonado223
best processor
AMD Athlon, Athlon XP, Duron, and Sempron processors
200 / 266 / 333MHz front side bus
for further information visit the link
http://www.biostar-usa.com/mbdetails.asp?model=M7VIG+400
Jun 26, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
How to upgrade
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
Apr 03, 2008 | AMD Duron , 750 MHz Processor
Abit KV-85 V2.0 (KV85VERSION20) Motherboard Logo
59 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
