Question about Memorex MLTD2622 26 in. LCD TV
The yellow, white and Red plugs .....
I'm not sure what area on the tv these plugs go in to. I've tried all of them and still " No signal!" Please help.
    Genius:
  • 1,139 Answers
Hello policelady17,
The Yellow is your Composite Video Cable, The Red is your Right Stereo Audio Cable and the White is your Left Stereo Audio cable.
Connect the Yellow cable to the output of the Set Top Box and the connect the other end of the cable to the input of the TV, Do the same with the Audio Cables. The place on the TV will be called Composite Video Input (The two audio jacks will be near it).
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 16, 2008
How can i connect a video camera to play through tv. my camera cables are red-white-and yellow. tv. is white-red- green-green-and red.
Your camera has three cables, red and white for stereo audio, and yellow for what is called composite video. Composite video puts the three color signals into one composite signal. Your TV sounds like it has a component video connection, which wants all three color video signals separated onto three plugs. They are usually color coded green, blue, red. Not sure if you mistook a blue outlet for green..... In any case, on my TV, it will allow me to connect a yellow composite signal to the green component jack, the first (leftmost) of the three component video jacks. Not sure if your TV will work this way, but it is worth a try. Otherwise, you can look up accessories for your video camera and see if it can output true component video and stereo audio, but I tend to doubt it will.
Aug 27, 2014 | Televison & Video
Can I hook up my roku device to this tv If so what kind of cable do I need?
On the back of the TV/VCR unit there is an input for audio & video plugs. These will accept a composite video signal and mono audio signal. I'm not sure if newer roku has these outputs as they are low def only signals. The roku would need to have have red, white & yellow sockets. (Old Roku's had these....) Yellow is video, red and white are L & R audio. Use a y adapter to merge red & white together, and use a standard RCA patch cord to connect the roku composite outputs to the TV VCR inputs.
May 01, 2014 | GE 19TVR62 19 in. TV/VCR Combo
What if the Seiki Tv do not have the white plug in? Please show details I do not know what a 1019 is u miss under stand the ? I ask how to hookup a DVD player to the Seike Tv that do not have a white...
You seem to think you are talking to someone you have spoken to before? This is not the case.
Do you not have an HDMI socket? The model number of the television is always useful in questions such as yours. I could find the instruction manual for it.
The connection is called Composite Video, using three plug, one is for the video signal and the other two are for left and right audio.
In home applications, the composite video signal is typically connected using an RCA connector (phono plug), normally yellow. It is often accompanied with red and white (or black) connectors for right and left audio channels respectively.
Look for any markings around your
red, yellow, red, like LEFT and RIGHT or L and R. That is the audio.
Oct 07, 2017 | Televison & Video
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
Samsung tv plugging the red white and yellow cables but getting only sound and black and white picture
Hi,red-blu-green is a component signal....but red-white-yellow is a video and audio signal....component and video-audio is a different signal.You can not
Apr 14, 2013 | Samsung Televison & Video
I bought a brand new xbox 369 last night. i also bought a brand new 32" flatscreen emerson le320em3. is this tv not compatible with an xbox 360? i was able to get the tv hooked up to cable and the...
Your problem is in the TV. I'm not familiar with your TV, but you should look for an option to turn it to normal or to try and scan for channels with xbox plugged in and running. I'm pretty sure that if you get HDMI cable, your problem should be solved.
Feb 06, 2013 | Video Game Consoles & Games
No signal fromdvd player video 1 (av)
yellow is video and red and white are audio you a get by with one audio. i think you are missing your video cable you can get by with two cables just use the white cable as a yellow and plug it into the yellow dvd plug and tv yellow plug and the red will stay hooked up for sound ( you wont have stereo but it should work)
Aug 05, 2012 | Audio Players & Recorders
I purchased a 32" Dynex
You only need to plug in the Red/White/Yellow plugs. Make sure you plug them into the correct colors on the TV. Most HDTVs have Red/Green/Blue ports. DO NOT use these ones, they are for receiving HD video signals. A lot of HDTVs also have the Red/White/Yellow plugs on the side of the TV (often labeled "Game", maybe something like "Video 3")
The Red/White/Yellow cables are known as RCA cables or Composite cables so look for any ports with those labels as well.
May 09, 2011 | Nintendo Super NES Console
Wii Signal is not found by TV
First check the basics:
1. make sure video cable from back of unit goes to inputs on back of TV, each color should match (yellow to yellow, white to white, red to red)
2. make sure unit has power cord, plugged in, turned on (blue light)
3. make sure TV is selected as the correct signal input, (many TV's have several inputs Input1, 2, 3, etc.) try them all. To change this look for "source" or "input" on your remote.
Jan 01, 2011 | Nintendo Wii Console
No sound on tv and black & white
The red, blue, and green are the component cable hookups. What you have w/ red, white, and yellow is called composite or on most TV's (AV) See if the TV has a side port for like a camcorder, etc. It will not work by hooking into the red/blue/green as they are different signals.
It is possible that your yellow jack may be separate from the red/white audio left/right jacks.
May 04, 2010 | Sony PlayStation 2 (PS2) Console
Memorex MLTD2622 26 in. LCD TV Logo
95 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
