Question about Microsoft Xbox 360 Console
My xbox 360 game tray will not open
It wont open using the button or the main menu command to open it.
  • cristybaby55 Dec 16, 2008
    I got the tray open but it won't play the game the light just flashes.
    Guru:
  • 859 Answers
This solution is:
Tech Level: Med
Mechanical Reasoning: High
Tool Skill Level: Med
Total Time: 1 to 1/12 hours
You will need to remove the front bezel. This may require removing the sides of your console, looking for locking tabs seated in the metal frame that hold the bezel in place. This is where your mechanical reasoning come into play. You will need to ferret out the method to get the front bezel off, along with the sides.
After this, you need to extract the Drive. This may involve releases latches that hold the drive in place. Removing the power plug and data transfer cable . Be careful when removing these cables pull gently but firmly backwards from their seat.
Once you have the drive removed, you will want to remove the top of the drive, its cover, from the base unit. This will then expose the drive motor, drive belt and drive pulley that operate the drawer. You probably have one of these two scenarios:
a broken belt or slipped belt.
a shattered disc.
If you have a shattered disc, there will be shards everywhere. These things, discs, do not break in two. They shatter like glass and can be just as sharp. Remove all shards carefully and in this case, USE SAFETY GLASSES.
Hopefully you do not have a shattered disc but this is more common than you may imagine.
If you have a broken belt. You will need to replace it. You can often go to your local electronics store where they stock belts for VCRs and DVD players. Or, as I have done successfully, I've found O-rings at a hardware store that can suffice. These belts are measured differently than you may guess, they have their width diameter measured in the stretched position. That is if you were to insert two fingers in the belt or o ring and then stretch the belt across a ruler until its gently stretched wide. This is the belt length.
It can be a real Bear to get to and resolve this type of problem, especially when a replacement drive is usually less than $40. But your choice of what to pursue is dependent on your personality. There are plenty of people who love to tackle a do it yourself projcect like this and there are those who loth it. Its up to you.
A local PC tech can also do this for you and the fee won't scare you. So long as you stay away from repair depots like Geek Squad where they have to charge you a Bench Minimum that will scare you or have you pay a minimum for a tech to knock on your door. Your friendly neighborhood tech is probably your best bet.
Good luck,
Worldvet
Posted on Dec 16, 2008
  • 275 Answers
CAUSE Typically, this problem occurs if a game disc, a DVD, or a CD is stuck in the disc tray. However, this problem can also occur when a disc is not stuck in the disc tray. THINGS TO TRY Make sure that you remove the clear plastic protective strip from the front of the disc tray. This protective strip prevents the disc tray from opening. 1. Determine whether the Xbox 360 console is functioning correctly. a. Press the power button, and look at the lights on the front of the console. ?If no lights are illuminated on the front of the console, make sure that the power cord is connected and that the power supply is working. ?If only red lights are illuminated on the front of the console, the console is not working correctly. For more information about what you can determine from the lights on the front of the console, click the following article numbers to view the articles in the Microsoft Knowledge Base: 907535 (http://support.microsoft.com/kb/907535/ ) One of the lights on the Ring of Light on the front of your Xbox 360 console flashes red, and you do not receive an error code 907536 (http://support.microsoft.com/kb/907536/ ) One of the lights on the Ring of Light on the front of your Xbox 360 console flashes red, and you receive the error message "System Error" in multiple languages 907533 (http://support.microsoft.com/kb/907533/ ) Two of the lights on the Ring of Light on the front of your Xbox 360 console flash red 907534 (http://support.microsoft.com/kb/907534/ ) Xbox 360: Three red lights flash on the Ring of Light 906652 (http://support.microsoft.com/kb/906652/ ) Four of the lights on the Ring of Light on the front of your Xbox 360 console flash red b. If no picture appears and the disc tray eject button does not work, contact Xbox Customer Service to get the console serviced. 2. Press the eject button on the console to open the disc tray. 3. If the disc tray does not open when you press the eject button, try to manually open the disc tray.For more informationon about how to manually eject a disc from the Xbox 360 console disc tray, click the following article numbers to view the articles in the Microsoft Knowledge Base: 906935 (http://support.microsoft.com/kb/906935/ ) How to manually eject a disc from the disc tray of your Xbox 360 console 4. If these steps do not resolve the issue, your console may require a repair. For information about how you may be able to create your repair request online and for information about how to contact Xbox Customer Support, visit the http://www.xbox.com/support (http://www.xbox.com/support) Web site
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it is similar to the operations of a desktop computer's CD/DVD drive except for the front plate. Whereas the computer's DVD drive would have a small pinhole for the manual eject, the XBox has not out front hence the faceplate to be removed. Once removed, you can push with a narrow dull end tool on the square opening that will push the gear/lever/mechanism to partially eject the tray. Thereafter, you can simply pull it out.
Often the problem is a broken or loose belt.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Microsoft Master
  • 19,396 Answers
Try pressing repeatedly the eject button on the console, while you start it at the same time, do this a couple of times until it opens.
  • Ginko
    Ginko Dec 16, 2008
    Now that you got the game out, unplug power and see if this reset the Xbox.
  • Microsoft Master
  • 13,433 Answers
The Drive is stuck or broken,
  1. Remove the faceplate from the console. With the console laying flat, use a flat-head screwdriver to pop in the tab inward on the right side of the console.
  2. Straighten out a length of paper clip as best you can.
  3. Place the long end of the paper clip in the hole on the very left.
    • Note: It's more of a "semi" hole and there is one directly to the right of it.
  4. Using a flashlight, place the end of the paper clip in the teeth on the right side of the gears and push. The tray should slide open a little, and from there you can open and close the tray with your hand.
  • Ekse Dec 16, 2008
    The drive is most likely faulty, how is your warranty?
What do you do when your xbox won't read disks?
The main problem might be a big problem with the disk tray. There might be an faulty wire that has lost connection and if your disk wont event turn on, there might be a problem with the power supply that supplies the cd tray. If the disk opens and closes but doesnt read and wont say tray is in and keeps saying open tray, there might be a small fracture on some of the wires or there is something wrong with the motherboard of the xbox 360. The best way is to buy the warrenty now and send it to the xbox 360.
Jul 27, 2011 | Microsoft Xbox 360 Console
My xbox 360 wont load any games. No red lights but i cant get passed the menu after sighning in. just keeps telling me to open an close tray.
check around the disk tray for dust and use a vaccum cleaner to clean it, then use a wet cd lens cleaner with cleaning fluid a few time.
This should cure the problem but it might be that your drive is dead
Oct 26, 2009 | Microsoft Xbox 360 Console
Wont play any games. says open tray
ur dvd drive is or has gone bad need a replacement if u have warantee send it in to xbox 360 and use ur warantee
Jul 02, 2009 | Microsoft Xbox 360 Console
When i place a disk in my Xbox 360 console it
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
Jun 22, 2009 | Microsoft Xbox 360 Console
Xbox 360 thinks I am opening the tray
your 360 might be jamed in the side get it fixed anywhere where it sells that console
Apr 26, 2009 | Microsoft Xbox 360 Console
When i put an xobx 360 disc in it says to open tray
Follow the steps below, Hope this helps
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Remove the hard drive, turn on your xbox 360 without the hard drive.
3. Re attach the hard drive and turn on your xbox 360
4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
This issue occurs when there is a problem with the lens on your 360 disc tray..
Apr 05, 2009 | Microsoft Xbox 360 Console
I turn on my xbox 360 and it says open tray and wont read disc
Mar 28, 2009 | Microsoft XBOX 360 ARCADE Console
Xbox 360 disk tray is stuck
Go to this microsoft website http://support.microsoft.com/kb/906935 and something goes wrong send me a message
Mar 09, 2009 | Microsoft Xbox 360 Console
Xbox 360: disk drive will get stuck...may be leading to disk not spinning
If you ever open the disk tray and then the power source is cut, the tray will try to ''autofix'' itself by making whatever state it was at the default position. This doesnt sound like whats going on for you, though.
If you can turn your 360 on and go to the main screen, try opening it with the ''open tray'' button on the bottom of the main screen.
If that fixes it, your problem is a faulty disk tray button.
If the tray still does that with the xbox main menu button, then its a mechanical thing with the tray.
Go to walmart and buy one of those air spray bottles (like an airsol can to clean dust out of PCs) and spray it into the 360 tray once it is opened. Aim the spray on the sides, what it sounds like is dust or something collected on the gears of the disc tray. If you have your 360 on carpet or a dusty surface this is probobly the problem.
Thats about the only thing you can do without opening the 360 up yourself (IF ITS STILL UNDER WARRANTY DONT OPEN IT) that will void the warranty. So if the airsol spray doesnt do it, then send it in to microsoft.
hope that solves it
-erk
Jun 18, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
164 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
