My printer stopped printing in BLACK. It's printing like sa light maroon color instead of black. When I copy something in "Black Only" the copy comes out blank. I changed the black cartridge and the same thing happens. On the diagnostic page the black section is in a mint green. Status of ink level is 1/2 full.
  • 3 more comments
  • Suze Adams Dec 16, 2008
    I cleaned the Black cartridge and changed it. It still won't print in black.
    iT STILL WON'T PRINT IN BLACK ONLY. cLEANED THE CATRIDGE AND REPLACED IT. UNPLUGGED AND POWER DOWN NAD HIT # & 6 WHILE PLUGGING IN WITH NO AVAIL!
    DID THAT 3X'S
    HP PHOTOSMART C6100 ALL-IN-ONE SERIES
    Unplugged everything on the printer an replaced the refilled cartridge with aa HP and it still won't print in black
  • 728 Answers
There is most likely something wrong with the way you installed the printer cartridges or there is something wrong with the black part of the printer head that reads the cartridges because you said that the status of the black ink is half full, but you said you had gotten a new cartridge and changed. You might need a new printer head.
Posted on Dec 16, 2008
    Genius:
  • 1,199 Answers
Remove all ink cartridges and clean unit! (are these refills or orignal ink cartridges? may have to redownload printer software
  • 275 Answers
Uninstall the printer and install back. might be a wrong configuration, if you cant figure it out , reinstalling it will fix the issue
  • Alan R
    Alan R Dec 17, 2008
    change settings in printer configuration to adjust color print out .
  • Alan R
    Alan R Dec 17, 2008
    select print only in black see if it comes out black eventually
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 90 Answers
What is the model of your printer?  This will help determine if the print head might need changed.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
  • 136 Answers
Run the diagnostic that cleans the print heads. The black may be clogged and the other colors are being used to get as close to black as possible.
  • 13,433 Answers
to test, remove all cartridges expect the black cartridge and print a black and white page and see how it comes out.
Also what is the model of your Hp printer?
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls wet a paper towel with warm water. Thereafter place the cartridge(s) on top of the wet paper towel for about 15 minutes. You may need to put books on the side to keep the cartridge(s) upright. Re-insert back into the printer and perform another head cleaning. try again.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 17, 2008
    clean the little gold contact pins of the cartridge and the cartridge holder with cotton buds and isoprophyl alcohol.
  • 19,396 Answers
Do the clean head procedure from printer utilities a couple of time, if this des not work, try using an head cleaner cartridge, or replace the print head.
  • Ginko
    Ginko Dec 16, 2008
    You can buy cleaning cartridges here HP CLEANING CARTRIDGES
    If the cleaning cartridge is not available, the only alternative is removing the printhead and soaking it in isopropyl alcohol overnight, or replacing it.
I have a dell p513w printer, and recently it stop printing color copies. I have replaced black and color ink, cleaned and deep cleaned pinhead.
You said the device will not "print" color copies. Have you tried to make a copy of something in color?
Recommend printing out a demo page that should show all colors listed, also do a print head alignment that would show the colors too.
Mar 16, 2014 | Dell V313w AllInOne InkJet Printer
I have a Samsong CLX-3160 FN printer. Not too long after refilling the black toner cartridge, I noticed that the black printing was not an even black. I followed the instructions that you provide for...
the problem okurs when the drum unit is not work 100% this is normal after a number of copys, I had the same problem in first stage I reset the color management to a higher denesity but this worked only temporary, so I renwed the drum unit, now works as new.
Apr 20, 2011 | Samsung Office Equipment & Supplies
How can I make the MP560 printer print "Black
there are many ways to do this. u can go to the print settings, or take the picture and paste it in word and right click and make it black and white or take the pic into photoshop or windows picture viewer and make it greyscale or something
Mar 07, 2011 | Canon MP560 All-In-One InkJet Printer
Hp j6450 all in one prints a black page when i copy?
when i copy something the page comes out all black
so how do i fix it?
Mar 11, 2010 | Office Equipment & Supplies
Prints color, not black. I have changed the
Please check your printer setup. from the document you are printing. Choose the printer from the FILE menu (depending on what program you are running) Printer SEtup or Properties, somewhere you will find an option, Print in color? or Black, Click on the Black., come out of the menu and then print, I am pretty sure you have chosen color.
Hope this will fix your problem.
Aug 18, 2009 | Office Equipment & Supplies
Can the copy setting be defaulted to black and white document?
You can set it to B+W but it will revert to its default setting the next time you print.
Jun 30, 2009 | Lexmark X1150 All-In-One InkJet Printer
My printer is printing everything black when using feedtray only
Their should be a Black Copy button and a Color Copy  Button . When wanting to copy a document in color you must choose the color start button.. Good Luck
May 04, 2009 | Dell 962 Photo All-In-One InkJet Printer
I just got a hp photosmart c4480 printer and it makes black and white copies, but I can't figure out how to print in black and white like when I am on a web site.
OK, Whe you select Print from the File Menu and the Print window opens, selct the Color tab.
There should be an option to Print in Grayscale. Check the box beside it and click OK at the bottom. Then back at the Print window, click Print.
(Note: If this option is not on the Color tab, or you do not have a color tab, look on the Advanced tab for the same thing.)
Need additional help...use the Comment link.
Thanks for using Fixya.
Apr 22, 2009 | HP Photosmart C4480 All-In-One InkJet...
Cant print in black
If try try to run cleaning cycle and it still does that it can be 2 things either the ink is dried or the print head is not functioning properly and if that's the case it will need to be serviced
Mar 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
k24674
jasbo
jasbo
Marvin
Marvin
