Washer keeps throwing off the drive belt and is making intermittent grinding noises when the drum is turned as if something is trapped- I suspect drum bearings.
    Problem Solver:
  • 17 Answers
IT IS THE BERING GOOD LUCK
Posted on Dec 16, 2008
Samsung waching machine won't drain
If you don't have the DIY skills to fix what is probably the drum bearings or water pump gone then an appliance engineer is your next bet. Is there excessive movement in the drum itself? Does it turn smoothly? Switch off at the wall, remove the access panel and see if the drive belts are OK. The grinding noise could be a coin trapped between the drum and the drum casing. None of this is an easy fix. Keep in mind the age and usage if you get an estimate, maybe cheaper to buy new?
Aug 12, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
Making loud noise
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
The drum rollers or idler pulley/belt would be suspect. The link above will help on all makes and models.
Oct 19, 2017 | Haier HLP140E Electric Portable Dryer
Dryer making a grinding noise when turned on. How do you get the top off to check the barrel motor?
Clanging Sound
1. If the noise coming from your dryer can be described as a clanging sound, the solution is probably well within your grasp. This common sound is typically the result of loose debris accidentally put in with the load of laundry. Change may be left in pockets of pants or other objects may be dropped in the laundry basket by children --- perhaps a toy car. The objects may not be noticed when put into the wash, and the water in the washer may have dampened the sound. Simply remove these items, and restart the dryer to resolve the issue.
Sometimes the clanging is from snaps or buttons that are actually part of the clothing. If you are drying a jacket with metal snaps or another garment with metal attached, you should expect this clanging sound as they tumble and strike the inside of the dryer tub.
Humming or Whistling
2. Many Roper dryer models are equipped with a safety feature known as a lint signal, which is usually a light that often accompanies a warning signal, telling the machine owner that the lint trap has become clogged. When the dryer cannot pull adequate air through the lint filter, it can overheat and become a fire hazard. The warning alarm may sound like a hum or whistle to get your attention. Look at the lint signal light, clean out the trap and the noise should stop.
Thumping or Grinding
3. If the noise you are hearing can be described as a thumping sound or a metal grinding sound, the device that turns the dryer drum, known as the drum rollers or glides, can be worn out. As the drum turns, there may be a constant and rhythmic thump each time the drum rotates. A severely worn or broken roller could cause the metal of the drum to rub against the metal housing of the machine, causing a louder grinding noise. The rollers will need to be replaced to remedy the problem.
Squeaking or Squealing
4. Most dryers work by using belts to turn the rollers, which in turn make the drum rotate and tumble the clothes dry. When these belts get loose, a worn belt or a malfunctioning tensioner spring may keep the belt tight. In either case, belt slippage may occur and will produce a squeaking or squealing sound that is easily recognized. The problem is likely to be the tension on the belt since most belts will break before wearing out to this degree.
Feb 24, 2011 | Whirlpool Dryers
Very noisy on spin
hello there.....the noise you hear is most likley due to failed drum bearings or something trapped in the drum....test as follows....isolate machine....open the door...test the drum for up and down lift...there should be no movement at all....if all is well here...remove the lid and remove drive belt....spin the drum by hand and listen for any bearing noise (rumble). or metallic sound of something trapped in drum..if all is well here refit the lid temp...Then select spin and start machine...if motor is noisy then the problem is with the motor bearings
regards Sir Galahad
Sep 21, 2009 | Hotpoint WMA64 Front Load Washer
'Grinding noise when drum alternates direction
you have a bearing thats bad on drum or something is stuck between drum
Jun 10, 2009 | LG WD-16115FD Front Load Washer
Washing machine noisey when drum turning
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | GE WJSE3110A Top Load Washer
Broken washing machine
the machine water ceal and bearings must be changed before it spoil the drum.there is small metal under washer drum to give u sine noise if the drum unstable.and if you keep using the the machine,drum get demaged.mostly all front loading machines are like that.the test is,open back cover check if there is rust on the centre shaft,that means leaking throw the ceal and bearing.open the door and try to list up the inner drum if plays means problem with bearings as above.
Jan 08, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Makes clunking sounds & throws belt off pulley.
I think you have the answer. I suspect it will be the bearings that have seized up. Or possibly the spyder / drum axle broken
Oct 19, 2007 | Frigidaire GLTF1670A Front Load Washer
Grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Oct 04, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
