Question about Magic Chef CER3520 Electric Kitchen Range
Need operation manual
When I moved into my place there was no operation manual for the range, which I am having trouble understanding. I would just like to download an operation manual please. Thank you.
My oven was turned on and then i heard a loud pop and then nothing cameon ,my oven orthe top burners.
Posted on Dec 16, 2008
  • 8,197 Answers
Here is the manual.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=CER3520&siteCd=MCF
please rate if it is helpful when done. good luck
Jon
How do you replace a neutral safety switch on a saturn sl1 2001
It 's a Transmission Range Switch , it tells the pcm more then just park or neutral positions !
Transmission Range Switch Replacement
Ensure the ignition is OFF.
Remove the air cleaner and duct assembly. Refer to Air Cleaner Housing and Duct Assembly Replacement in HVAC.
Disconnect the transaxle range switch harness connectors.
Place the control lever in the full clockwise position.
Notice: If manual shift shaft is rotated excessively, internal damage to the transaxle range switch may occur.
Prevent the manual shift shaft from rotating by holding the control lever while removing the retaining nut from the manual shift shaft. Remove the control lever.
Remove the 2 switch-to-transaxle case bolts and remove the switch.
Install the cable to the control lever and adjust the cable. Refer to Shift Control Cable Adjustment .
Before tightening the transaxle range switch-to-case bolts, proceed to the Adjustment procedure.
Adjustment Procedure
Important: While adjusting the transaxle range switch, always rotate the switch towards the engine to achieve continuity. A diagnostic trouble code DTC P0706 could result if this procedure is not followed.
Important: Digital volt/ohm meter (DVOM) with audible continuity test is preferred. Do not stick the probe in the transaxle range switch terminal hole; use male terminals on the transaxle range switch or faulty readings could occur.
Place the transaxle in Drive (D). Use an ohmmeter or continuity tester to check for continuity across terminals on the selector switch. Rotate the transaxle range switch from the left fender towards the engine until continuity is achieved.
Notice: Refer to Fastener Notice in the Preface section.
Tighten the switch-to-case bolts. After switch-to-case bolts have been tightened, check continuity.
Tighten
Tighten the transaxle range switch-to-case bolts to 14 N·m (10 lb ft).
Connect the transaxle range switch harness connectors.
Install the air cleaner and duct assembly. Refer to Air Cleaner Housing and Duct Assembly Replacement in HVAC.
Using a scan tool, ensure each gear position reads correctly while manually moving through all gears.
Dec 15, 2016 | 2001 Saturn SL
TEKA TKX13wd. Where can I get operating instructions?
ask the owner of the place where the instructions are .or try Google
Jun 23, 2015 | Washing Machines
Tell me how to bake on a frigidaire Gallery
Hello jsorrell506 - I understand that you will like instructions on how to use the bake feature on your range. I found the manual and operating instructions on the Frigidaire website. Here is the manufacturer link and hope you find all the information that you need. I will recommend taking off the last letter of the model number so you can pull up the information.
http://b2b.frigidaire.com/support/manuals.asp?NewSearch=New+Search
Dec 19, 2012 | Frigidaire Gallery GLEFM397DS Electric...
1996 ford contour transmission range sensor
Transmission range sensor and neutral safety switch are the same thing (when you go to buy the part). It's at the top of your transmission. You'll see the shifting cable connected to it. Here are the instructions for adjustment:
Shift Control Linkage
The transmission shift linkage adjustments must be performed in the order in which they appear.
Column Shift
Place transaxle range selector lever in (D) (OVERDRIVE) position or D (DRIVE) position on vehicles equipped with a transmission control switch (TCS). A weight of 1.4 kg (3 lb) should be hung on the transaxle range selector lever to ensure the lever is located firmly on the (D) (OVERDRIVE) or D (DRIVE) position on vehicles equipped with a transmission control switch (TCS) detent.
Loosen manual control lever-to-control cable retaining nut.
Move transaxle manual control lever to OVERDRIVE position or D (DRIVE) position on vehicles equipped with a transmission control switch (TCS), second detent from most rearward position.
Tighten retaining nut to 17-23 Nm (13-17 lb-ft). Check operation of transaxle in each transmission range position. Make sure that park mechanism and transmission range (TR) sensor are functioning properly.
Floor Shift
Position transaxle range selector lever in DRIVE position against rearward stop. The floor transaxle range selector lever must be held in the rearward position using a constant force of 1.4 kg (3 lb) while linkage is being adjusted.
Move transaxle manual control lever to DRIVE position, second detent from most rearward position.
To take it off, it's a couple of retaining bolts and a wiring harness.
Jun 28, 2009 | 2000 Ford Contour
Need User Manual for Hoover 800F1 Washing Machine
Hello, my name is Peanutbut70, and I will be assisting you in findin a manual for your washing machine. I understand you to say that you just moved to a new place and have a Hoover 00F1 washing machine that does not work and you are looking for a manual or help. Is that correct? My solution to your problem is that you can look on ebay.com and find the manual that you are looking for. I have seen it there for myself. I hope this solves your problem. It was a pleasure talking with you. Have a nice day
Mar 26, 2009 | Washing Machines
LG RHT397H DVD Timer record problem
Sorry used wrong site have moved to LG DVD forum. Ta
Jan 17, 2009 | LG Corbel A- Accessory Range Hood
Frigidaire Stove
you may have to adjust the flame size so you can simmer.
Nov 05, 2008 | Frigidaire FEF355 Electric Kitchen Range
I need a manual
The model number should be posted on a nameplate near the oven door opening and/or lower drawer opening (if equipped). Sometimes the model number is located along the back of the operator console. You will need this model number in order to ensure you are getting the correct manual as all appliances are not the same with operation and features. Go to geappliances.com and click on the "Service and Support" link. On the next page is a heading for "Use and Care Manuals". Click on the link, type in your model number, and there should be a manual available for you to download in .pdf format (Adobe). I hope this helps you.
Jul 18, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Oven door locked?
i suggest that you try and use the manual to run the self clean cycle for the shortest time if still not call serviceman .Rember to wait the time it takes to COOL DOWN before it will unlock
Eggman
Mar 10, 2008 | KitchenAid KESC307 Electric Kitchen Range
Magic Chef CER3520 Electric Kitchen Range Logo
272 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
