Question about Kenmore 15218 Mechanical Sewing Machine
(1) bobbin does not supply thread (2) cant switch to stitching mode
Hi, I bought this product more than a year ago and unfortunately could not use it even once, till date. I am a learner not a sewing expert. Apparently I am facing two problems : 1. Needle keeps hitting at one place only, cloth does not move. 2. When I put the thread into needle and try to get thread from bobbin, it does not happen. Please help me to resolve my problem. If Kenmore has any support/training or repair centre in Fremont CA or close to Fremont, please give me the name of contact person, address and phone number.I can vist them and get my problem solved. OR I can buy if you have some user manual or guide lines available. Would appreciate a solution to my problem ASAP Thanks and Regards, Manju Mishra
  • Kenmore Master
  • 12,729 Answers
If the machine has been used, it may be worthwhile to take it for service and make sure the machine is operating properly. Nothing is more frustrating to a new user than trying to make a faulty machine perform. (One assumes a new machine should be ready out of the box, but frequently there are defects or mal-adjustments.
A couple of simple hints:
Install a brand new needle every 8 hours of sewing use. A needle is a very inexpensive fix for a lot of sewing problems.
Verify that the needle is installed facing the correct direction. Needles have a flat side that needs to be installed in a certain direction or the needle will strike other parts of the machine.
When threading the top thread, ALWAYS RAISE the presser foot so the thread will seat properly in the tension disk. Start out with the top tension set at the midway point and then tweak it for your machine.
VERIFY the thread path is correct! A mis-threaded machine will cause a load of frustration!
Tension is accurate when the top and bobbin threads meet in the middle of the fabric.
Be sure to clean and oil your machine regularly. Use only fresh, good quality sewing machine oil and apply 1-2 drops each place specified (pg 76). The troubleshooting section is on pg 78 as a quick reference to any issues with the machine.
Here's a manual:
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/15218_1.html
You may check with stores like JoAnn's if they offer beginning sewing classes. Stores will frequently offer classes, especially for children to learn how to sew. Adult education classes used to offer sewing courses. Even some craft stores offer classes.
Posted on May 02, 2017
    Problem Solver:
  • 8 Answers
Check out if the needle is faceing the right way, otherwise when the needle goes down it will be hit by the rotary hook when it starts comeing up .
Posted on May 01, 2017
    New Friend:
    Problem Solver:
  • 17 Answers
If the needle keeps hitting at one place only, make sure the feed dogs are UP, these are the little teeth you see just level with the metal plate under the needle. If they are below the plate, you need to press a button or lever to bring them up level. Make sure your bobbin is wound evenly and not too tight, or loose, make sure you have inserted it into the bobbin case the right way round, with enough spare thread at the end, about four inches. Hold the thread coming from the NEEDLE in your left hand, do not pull too tight, just a little slack. It has to go down into the bobbin area and pick up the bobbin thread. Now turn the hand wheel at the right end of the machine slowly, until you see the bobbin thread come up through the plate. Pull both threads towards the back of the machine, and you are ready to sew. I do not know the Kenmore, but this is basic advice for most machines. Good Luck.
Posted on Apr 05, 2017
manski
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
lavon82931
  • 17 Answers
SOURCE: needle won't grab bobbin thread
Check the position of the needle. Some machines have to have the needle in a certain way or they won't pick up the thread from the bobbin. Make sure the screw on the bobbin is tight but not to tight you may have to adjust it a few times to get it where it needs to be. Also make sure the bobbin is wound tight
Posted on Oct 14, 2008
SOURCE: can't wind bobbin kenmore 16221 sewing machine, no manual
On the right side of the machine there is a large knob at the top. Pull that out and you can wind your bobbin. Don't forget to push it back in so you can sew :)
Posted on May 02, 2009
SOURCE: my needle keeps hitting the bobbin casing...have
Your timing is off. There should be a ruber belt behind your hand wheel, if you take off the case around it; you should be able to adjust your timing of the bobbin casing.
Posted on Jul 31, 2009
  • 980 Answers
SOURCE: Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Posted on Jun 26, 2010
I just bought a Pfaff 7570 New needle, new thread ut the bobbin thread is still breaking after about 2 inches of stitching
put the bobbin in the bobbin carrier correctly so that the thread unwinds in the right direction
Sep 18, 2017 | PfaFF Sewing Machines
I have an older Bernina 830. I am having what seem to be tention broblems with the stiches not forming and lots of thread being produced. The adjoining problem is that there is a rattling when I attem
What you're describing is commonly called a 'bird's nest' for fairly obvious reasons. There are, unfortunately, a number of things that can cause it.
Troubleshooting steps:
1. Clean it! I've seen machines that haven't been properly cleaned for years. If there is lint, dust or dirt in the bobbin area especially, the looper won't work correctly and the stitch won't form. Be sure to take out the bobbin when you do this.
2. Oil it. Follow your manufacturer's instructions for this. If you don't have a book, contact Bernina and get one.
3. Change the needle and check the tensioning disks to be sure that no lint, old thread, etc. has got caught in it.
4. Adjust the tension. This can be tricky, so take it in small increments. Here, again, a manufacturer's book is a godsend.
5. If none of this avails, or it only partially fixes the problem, take it to a reputable service center (most fabric, quilting, etc. stores have or know someone) and have them adjust the timing. Most machines need this done every 1-5 years depending upon the usage.
Good luck with it. I wish I had an older Bernina, they're good machines.
Feb 14, 2015 | Bernina Sewing Machines
I have dv9117, whenever I use the special stitches or even just the zigzag, it just keep doing straight stitch. Did all the cleaning, re-threading, taking out the bobbin and rewound bobbin thread. Nothing...
aside from cleaning, with a thread bunching problem it's always good to change the needle and make sure the top thread has not come off the thread take up lever and make sure the bobbin is turned the correct way in the bobbin case.
as for the zig zag stitches, it sounds like a gear or cam could be damaged or worn.
if someone brought me a sewing machine with the same problem, the first thing I would check for is a damaged or worn gear..
Oct 01, 2013 | Singer Sewing Machines
Bobbin thread is pulled through fabric on zigzag stitch
You need to adjust the tension of the stitching, it sounds as if the top stitch tension is looser than the lower in the bobbin.
Nov 02, 2012 | PfaFF Sewing Machines
E123@aol.comMy needle on my Bernina 1530 Inspiration just stopped going up and down whether I use the foot pedal or manually attempt to move the needle
This sounds like you have the machine in bobbin winding mode, just refer to your manual to take it out of bobbin winding mode. I'm not familier with your exact model, but the is typically a lever, or button that is used to wind bobbins, so the needle doesn't keep sewing without the bobbin thread in place.
Please rate my solution thanks
Mar 13, 2011 | Sewing Machines
Pfaff varimatic 6091 sew a rag quilt with jean and flannel,I can't get my tension right it seems to be funny on the bottom stitch,where shoulf the top tension be set at 4 1/2 ,when do I adjust the bobbin...
Hi! The bobbin tension rarely needs to be adjusted. First, make sure you're using the appropriate size needle and thread for your fabric (I'd probably use either a 'denim' needle or a universal size 14) and also that the upper thread and bobbin are threaded absolutely correctly. These can throw off the tension! Also, take the time to clean out the bobbin area. That can throw your stitch off also.
If the stitch on the bottom is loose, so that you see the top threads, then the top tension is too loose. If the top stitch is too loose and you see the bobbin threads on top, then the top tension is too tight.
It helps to thread the machine with different color thread on top and in the bobbin, and then stitch an inch or so on the same type of fabric as you're using in your quilt. Check the stitch. If you need to adjust the top tension, make sure the pressure foot is down! Adjust a little, stitch a few inches, and check again. Repeat until you don't see any (or very little) bobbin thread on the top or top thread on the bottom.
If you go through all these steps, and the bobbin thread is still loose (and you've tightened up the top tension), then there is a tiny little screw on the side of the bobbin case that you can use to adjust the bobbin tension. Turn the screw just a little bit (less than a quarter turn), stitch, check, etc. Once the bobbin tension is set, you shouldn't ever have to change it.
Let me know if this helps, ok?
Happy sewing!
Feb 10, 2010 | PfaFF Sewing Machines
Where can i get my sewing machine fixed? i have a Necchi sewing machine, and it does not work. i bought it two years ago and it was working perfectly. i've tried everything it said in the manual, but it...
make sure you have it threaded right and picking up thread at bobbin
brfore sewing i have seen a lot of people put the thread the wrong way through the needle and it will have this problem
Dec 31, 2009 | Necchi Sewing Machines
I have just recently picked up sewing again. Haven't sewn in 30 years. Anyway.... I'm having an ongoing bobbin problem, or at least I think it's the bobbin. When I sew a straight stitch, the top stitch...
I think that is your problem. You should see a little slip in the bobbin holder. Hold the bobbin with one hand and pull the thread through the slot. I think that is where your notches are. The thread should not be real loose coming out of the bobbin. I hope this helps.
Oct 19, 2009 | Singer Sewing Machines
Thread tangling and jamming under the plate
Sorry I do not have a solution but my Euro-Pro 1925 is doing the exact same thing yours is. Are you also getting a clicking sound and loose stitches on the bobbin side of the fabric? If you find anything out please let me know and I will do the same. I love my machine but I will never own another Euro-Pro product. I think the company sucks and does not stand behind their products. You can not find anything on the 1925 model and no one that can service it either. Thank you, Erica my email is erica_jennings@sbcglobal.net Funny thing is my machine is only 3 years old.
Jan 04, 2009 | Euro-Pro 9125 Computerized Sewing Machine
Kenmore 15218 Mechanical Sewing Machine Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
