Question about E-Machines eMachines Desktop PC
Computer will not powerup
I've replaced the power supply, however the PC (a T2792) still will not turn on. The power button lights flashes on/off and the unit make a rapid clicking noise. Any ideas?
    Problem Solver:
  • 8 Answers
Try removing any add on cards and also all the hard drives and cd/dvd drives and see if the symptoms change. It could be a bad component. It may also be a bad motherboard, but removing everything else will help to narrow it down.
Posted on Dec 16, 2008
    Novelist:
  • 159 Answers
Apparently you're not alone. If you search on your model number and the words "power on," you find lots of discussions, such as this one:
http://discuss.pcmag.com/forums/thread/1004375440.aspx
Is that your actual problem? I don't know. If you're not actually getting to the BIOS POST -- power-on self-test -- that's not a good sign.
If you can diagnose the problem accurately, I'd suggest you evaluate what it's worth to you to resurrect that computer especially in light of the potential for future problems and the value-benefit of a new box. I paid $429+tax for an eMachines T5246, which is incredibly strong and big for my needs. If you go the replacement route, just make sure the new computer has an IDE controller card built in (most should, on the motherboard, mostly to support a floppy drive) so you can wire up your old hard drive and get the stuff off of it.
The light on the power supply (back of tower) and light on the front button that turns on the computer flashes. This is with the power cord plugged in. The computer does not turn on when I press the...
try removing the front panel make sure the button isnt clogged with dust or disconected failing that it may well be your power supply internal fuse which can be repaird but a trick job if youare not very good with a soldering iron you may get a replacement one on ebay.
Oct 06, 2010 | HP Pavilion a622n (PC108A) PC Desktop
Lights come on but no fans or powerup
Please follow the steps below.
1. Please removed the battery and unplugged the power supply.
2. Held down the power button for 45 seconds.
3. After 45 seconds reinstalled the battery and the power supply and pushed the power button and if it works then you don't need to replace your motherboard.
4. Else try it couple of times or up to five times before it worked if worst comes to worst.
Thanks
Aug 26, 2009 | Acer Aspire 5050-3242 Notebook
Getting power but wont boot up or anything
pull out everything in the computer except what's required to boot...so any pci cards or video cards (if you have onboard video). you can also try pulling out the ram (while unpowered AND unplugged) and then booting to hear beeps...if you pull the ram out and the computer doesnt make a sound, its probably a bad motherboard and needs to be replaced. if you hear beeps, try replacing the ram or disconnecting other parts...like harddrives, optical drives, modems and what not.
Apr 26, 2009 | E-Machines T2792 PC Desktop
Laptop Dead, Wont power up
its power button doe not work please change it as soon as possible
Apr 14, 2009 | Acer Extensa 5420-5687 Notebook
Processor?
The power box is going bad. It's a matter of time before it will not turn back on. you will see. i would get a new one from ebay and replace it.
Apr 04, 2008 | E-Machines eMachines Desktop PC
Hard drive light stays on and system freezes
You may have a hardware problem of some sort. The first place I'd start is to check the power supply voltages. If one or more voltages is off tolerance, this will cause all sorts of symptoms. if you have a voltmeter check especially the +5, +3.3, +12, & +5 standby voltages. Use this site as a reference http://pinouts.ru/Power/atx_v2_pinout.shtml If the supply checks out faulty, buy a replacement, or, if tech savvy, you might repair it-- probable component defects= one or more electrolytic capacitors. Other possible problems are Memory errors (try subbing a RAM stick), hard drive developing errors, or a bad chip on the motherboard. If you have some spare parts, RAM, hard disk, you can try subbing parts and narrow down the problem.
Apr 27, 2007 | E-Machines T2792 PC Desktop
E-Machines T2792 PC Desktop is not booting
This could be a corrupted bios, look on the motherboard for the 'JBAT1' terminal and put the plastic jumper cap from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. Start the pc hopefully and press F2 or DEL to enter the bios and set the time and date in standard bios settings and look for the auto detect drives and select it. press ESC and and save settings and it will re boot and go into windows if the softwaere was not corrupted when it was turned off at the button.
Jan 30, 2007 | E-Machines T2792 PC Desktop
PC totally locked
The flashing power switch and power supply LED on the rear in conjunction with a power failure or surge indicates that there is a defective component; typically the power supply, motherboard, memory, processor or modem. -Disconnect all the power supply leads, drives, and motherboard as well as any USB, firewire and other external devices. -Plug in the 115v power supply cable and look at he LED on the back of the power supply. If it is still flashing the power supply is bad and needs to be replaced. -If it isn?t flashing then unplug the power supply plug in one device, plug in the power cord and watch for the flashing LED again. If it?s flashing you?ve found your culprit, if not move on to the next component and repeat the process until you?ve found it. Don?t forget your plug in cards could also be the problem. Good luck and let us know if you have any other questions. As always please don?t forget to rate this posting.
Jan 27, 2007 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
E-Machines eMachines Desktop PC Logo
82 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
